Question about Pioneer VSX-1023-K
No video received thru VSX 1023k
Cable box is connected to VSX 1023K which is connected to TV. But no video on TV
SOURCE: Receiver: Pioneer Elite 72TXV Verizon
Called Verizon automated help desk. They rebooted DVR remotely and solved the problem.
Posted on Mar 29, 2008
dragonsthatk
  • 547 Answers
SOURCE: No HDMI Output thru' receiver
you most likley blew a fuse . take it to a repair shop it you live in an area that has lot's of storm activitey you might want to look in to getting serg protection on your elect panel to save repairing other thing's in your home. thank you please rate mee
Posted on Feb 12, 2009
SOURCE: Pioneer VSX-D608 Optical connection
The manual states that the default association of each digital input in as follows:
  • Optical 1: CD
  • Optical 2: MD
  • Optical 3: TV
  • Coax: DVD
Use the "Signal select" button to set the receiver to use a digital input, and the Dolby/DTS button (above "Signal select") to enable decoding.
As samz11 stated above, a remote is required to alter the digital input mapping.
Posted on Feb 18, 2009
welcomejee
  • 10594 Answers
SOURCE: No Sound on TV/SAT setting on Receiver.
Most TV has Audio Out RCA jack at rear and it gives same TV Sound as coming from its speakers.
Hook audio wire red white RCA pins at TV Out and plug these pins to TV/SAT input of receiver. Select TV/SAT input in receiver to get TV program sound coming out from TV.
Hope that info will help you.
Posted on Sep 15, 2009
  • 15 Answers
SOURCE: Pioneer vsx-819H: MCACC setup won't display on tv
Its because the pioneer does not display menu options through hdmi. You have to hook up basic yellow composite to monitor out.
Posted on May 03, 2010
I'm having problem with sound when I use my Pioneer Elite VSX-32 receiver. Everything is fine if I directly connect to my TV with HDMI cables from my cable box or my roku box. However, if I use the same...
check the audio output settings of your components. THey may be set for dolby digital which your receiver can process but your TV can not. Try PCM stereo setting or "other".
Apr 29, 2014 | Pioneer Audio Players & Recorders
I am trying to hook my pioneer vsx-455 up to my samsung dlp-hd tv and have no idea which pre-outs to use.any help would be greatly appreciated.or do i need to go through the cable box and if so how?
Ok. Where does the TV programming originate? Antenna, TV, or (usually) the Cable Box. I'll tell you sight unseen, no TV ever adds to the audio experience. many of us watch on monitors so that would suggest that a TV can play absolutely no part in the high-end audio experience. It's specialty is video with basic audio capacity thrown in. A Cable Box is for all purposes a digital audio and video source with separate outputs for each. Keeping with my practice I'd run the BEST VIDEO (and minimum audio in case you want to use TV speakers for that source) from each video source to the TV (it has multiple inputs, right?) and the BEST AUDIO (no video) from each source to the receiver. One video connection from the receiver to the TV for set-up/control. This requires some switching on your part to watch different sources but it eliminates troublesome and unnecessary routing and handling of the individual signals.
Nov 08, 2011 | Pioneer VSX-455 Receiver
I have a Pioneer VSX-D308 reciever and I have... no idea how to hook it up to my big TV (bought receiver used). Do I need the red/white cords? Do I need other cables? HELP! Wanting to hook up to big...
What your unidentified TV >>requires<< is the BEST Video from every video source. That would be the DVD, SAT Box. It probably has multiple high-end video inputs, right?
What your receiver needs is at least a basic composite video connection to the TV so you can set it up and manage it.
A web search for "Pioneer VSX-D308 manual" will find the manual.
ALL of the BEST Audio should go directly to the Pioneer. That includes the SAT and DVD player.
Your TV can exist just fine with basic audio from the video sources. And you could still watch it/them without the Pioneer turned of if you want.
I can't find the exact manual for free anywhere but if you download something similar like http://www.retrevo.com/support/Pioneer-VSX-D409-Receivers-manual/id/385ci977/t/2/ it should give you the basic guidance you need.
I recommend
Do some web searching for what the cables are for. It's all basic and standard.
Sep 07, 2011 | Pioneer VSX-D308 Receiver
Trying to connect a Plasma TV to this receiver which does not have HMDI
What you need to do is connect the HDMI from your source(SAT, Cable box or DVD) directly to your tv. Then, connect audio from that same source down to your pioneer receiver.
Good Luck
Jan 07, 2011 | Pioneer VSX-456 Receiver
I just need the basic wiring instructions for hooking up the direct tv, an x box, and how I'm suppossed to go from tv to reciever and the monitor out cable. I have a samsung txr3079wh flatscreen. I also...
Connect the Direct TV and the Xbox directly to the television by their respective video cables.
Then connect their audio cables to the audio inputs on the receiver.
This connection method does not require use of the monitor out terminal.
Sep 09, 2010 | Pioneer VSX-818V-K Receiver
Pioneer works with cable box but not with new blue
HDMI version is 1.3 in your receiver.The current version is 1.3b. I would suggest calling Pioneer cust assistance and see if there is a firmware update. Your unit has a 2 year parts & labor warranty. Their # is 1-800-421-1404 It sounds like a CODEC issue. Hope this helps
Dec 25, 2009 | Pioneer VSX-92TXH Receiver
Feb 12, 2009 | Pioneer Elite VSX-91TXH
I'd like to know where the vcr cable & cable wire from wall
(I own 2 VSX-D903S Units.)
There are NO optical (Toslink) or coaxial connections for Satellite or Cable-TV on this Pioneer unit.
The coaxial connector on the receiver is for connection to an external antenna for FM Tuner (radio) reception only.
Your cable line from the wall would go to your Cable Box, or a "cable-ready" TV or VCR. You would then connect the composite (YLR) or S-video output A/V (S+LR) connection to the VCR 1 input on the back of the receiver. Connect your TV L/R audio and S-video or Composite video output to the TV in connection on the Receiver. (Connect the Composite TV-out connection to a composite video-in connection on the TV.)
Dec 26, 2008 | Pioneer VSX-D903S Receiver
No sound from digital cable thru AVR3200 after adding HDTV - DVD plays fine
you need a digital coax cable and then connect it to 6.1 also the digital cable type is not a coomon type so check that also
Jan 04, 2008 | Denon AVR-3200 Receiver
Pioneer VSX-1023-K Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
