Question about Onkyo Audio Players & Recorders
No sound on anything on the onkyo 626
I have all speakers hooked up plus sub-woofer I have the main hdmi hooked to tv but cannot even hook up the blu ray player hdmi and get sound
    Problem Solver:
  • 12 Answers
It will shut down if you have the speaker wires touching, or the wrong polarity of your connected speakers. Check the wiring and connect one speaker at a time. (turn off to connect)
Posted on Dec 31, 2013
5 Suggested Answers
  • 5 Answers
SOURCE: What Blu Ray to buy for ONKYO TX-NR801 for Dolby TrueHD, etc???
Hi, as the Onkyo receiver you have does not have HDMI switching, the only thing it will do for you with a Blu-Ray player is process the audio signals.  The video from the BR player will have to go directly to an HDMI input of your hi def TV.  In this case, either Sony or Panasonic BR player will be equal.  Assuming you keep the Onkyo unit you have, you would want to use the optical digital output from the BR player as the audio source into one of the optical, digital audio inputs on the Onkyo.  In an ideal world, your receiver would some that does do HDMI switching.  This way, all the audio and video signals from any audio or video source would be automatically switched and channeled through 1 simple HDMI cable into your hi def TV.  This will make you life simpler as ther would be no need to select an appropriate input on the TV, as well as one on the receiver.  That said, buying a new receiver in addition to a BR player is more costly.  Good luck.  Let us know how it goes.
Posted on Jan 02, 2009
gotgeek2
  • 565 Answers
SOURCE: I have the following hardware:
Remove the HDMI cable (out) to the speakers from the receiver.
Connect regular speaker wire from the receiver to the speakers.
Of course, remove the (now extra) HDMI cable from the tv.
That will remove the loop.
Posted on Jan 25, 2009
  • 120 Answers
SOURCE: Muffled sound from rear speakers why watching TV
switch the HDMI cables around to make sure its not one of them, if the problem is one of them it will move with the cable,if no change i would suspect the coaxial cable next.
Posted on Feb 12, 2009
  • 136 Answers
SOURCE: onkyo tx-sr606 turns off during loud dvd sounds.
It sounds like you have a defective unit. I would contact the manufacturer and ask to RMA it.
Posted on Aug 08, 2009
Sub woofer not receiving signal from onkyo HTR520 , bought it in 2007, it works when hooked up to another source. can it be hooked up without using the sub woofer out put on the onkyo
The best thing to try is a factory reset of the Onkyo. The subwoofer out may be stuck off, even if the settings say its on.
hold down the Video 1 and Power on/ Standby buttons. The display should say Clear, then enter standby
turn it on and try the sub again.
since its a powered sub, you're not going to have much of a choice in other outputs without extreme distortion.
also, if that model has two zones, make sure zone 2 is off.
May 05, 2017 | Onkyo Audio Players & Recorders
How do i hook up a dcm sub 210 to a onkyo tz-rz 810 av receiver with hdmi inputs?
Hello, you do not use HDMI. You connect using an LFE cable from the Sub-woofer output on the receiver to the sub. Thank you, CB
Apr 29, 2017 | Onkyo Audio Players & Recorders
Can i hook up my bose model ps38 powered sub to onkyo reciever
Why not. A speaker system should work with anything that produced sound meant for a speaker.
Don't you think?
find the woofer out on the onkyo and connect the bose sub-woofer there.
Seems pretty simple. If you don't think so, go hide in a closet.
NOW!
Aug 19, 2014 | Audio Players & Recorders
Hookup Blu ray player to Onkyo pre-amp for speakers
If you have audio out jacks from your tv, you would be better served hooking that up to the preamp. If you hook up the blu-ray player separately to both the tv and amp, the audio probably will not sync with the video correctly. The tv takes longer to decode the hdmi input and the audio will be ahead.
Jan 22, 2013 | Onkyo Audio Players & Recorders
Hi My Onkyo TX - SR875 has lost sound from Sub Woofer? not sure if the reciever or the Speaker? Any way to check? Martin
Hook the subwoofer RCA input cable to one of the other Pre-Outs. It won't sound GOOD but it will prove if the sub still works.
Then, if the Sub is alive, reconnect it to the Sub Out.
Get into the SETUP and make sure the Onkyo still knows you have a sub and do all the setup for the speakers.
May 03, 2010 | Audio Players & Recorders
Onkyo HT-S6100 to OPPO Dv 980H to Sony Bravia KDL 40W4100
Make sure none of the Digital or Component Input Assignments are programmed, if you're not using them. Set them to "----". This may help. Some of the Component input assignments may over-ride your other input assignments (perhaps even the HDMI input assignments).
Jan 25, 2009 | Onkyo DV-S353 DVD Player
SA-AX720 no subwoofer signal?
THIS UNIT HAS NO SUB WOOFER AMP IN IT. THE ONLY WAY TO OVER COME THIS IS TO HOOK THE LEFT AND RIGHT FRONT SPEAKERS STRAIGHT TO THE SUB WOOFER AND THEN GO FROM THE SUB WOOFER BACK TO THE INPUTS ON THE BACK OF THE UNIT FOR THE FRONT SPEAKERS. THE SUB WOOFER THIS WAY WILL EXTRACT THE BASS AND THE FRONT WILL RECEIVE THEIR PART. THIS SOUNDS CRAZY AS HELL I KNOW BUT THAT'S HOW I GOT MINE TO WORK. THE OUTPUT FOR THE SUBWOOFER IS USELESS AND PUT THERE FOR YOU TO HOOK UP AN AMP FOR A SUB WOOFER. EVERYTHING HAS SHORT COMINGS, AND THAT'S THE ONE FOR THE AX-720.
Sep 22, 2008 | Technics SA-AX720 Receiver
Onkyo HT-R530 with powered speakers
I would not suggest hooking up powered speakers to your receiver. Only if unit has sub woofer output can you hook up powered speaker
Apr 22, 2008 | Onkyo TX-SR605 Receiver
Sound won't play thru stereo from t.v.
take the main tv digital opti outto sterio ok on ch or from dish box to sterio on a ch
Feb 02, 2008 | Onkyo TX-SR605 Receiver
Home theater set up
I want to download instructions to record tv shows while I am gone for a day or two,on my sony model#kdl-46xbr2. e-mail bmllrctg@yahoo.com
Dec 27, 2007 | Televison & Video
112 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
