Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
Turns off and on by itself after a few minutes of being on
When turned on after 3 minutes or so it will turn of by itself only to turn back on after a few minutes and it contiunes.  Thank you for any ideas.
  • minogup Nov 06, 2007
    My tv is having the same problem. It turns itself off and the green light blinks 29 times and then the tv turns itself back on. It does this every minute or so. I have a technician coming to look at it in a few days. Their first thought when I described the issue is that the bulb may need to be replaced. This tv is on 2 years old.
I've just started to have the same problem. I've had the set for about 3 years. I thought it was the bulb too but I noticed that the humming noise from the fan has stopped. Does the fan come back on after the bulb is replaced?
Posted on Jan 27, 2008
  • 3 Answers
I had this problem and the bulb replacement fixed the issue.
Posted on Jan 07, 2008
My TV had the same problem. I would lose the picture and audio and the green light would blink 29 times. Then the pic and audio would appear again. I replaced the lamp and it fixed the problem.
Posted on Nov 13, 2007
Another post above says replacing the bulb is the answer. I have one coming as I am having the same problem. I will let you know if thats what it is.
Posted on Nov 02, 2007
  • derekspudich Feb 11, 2008
    I replaced the bulb and that indeed solved my problem. Not to say its the only problem, but I would start with that.
TV turns itself off after about 5 minutes (green light remains on). I can turn off the TV and turn it back on immediately, however, the TV turns itself back off after a few minutes. It started turning off...
Check and make sure your fans are working and there is sufficiant cooling to the back of the set. Sounds like it is overheating and going into protection mode.
May 04, 2011 | Mitsubishi WS-65513 65" Rear Projection...
Playstation 3 power issue
Your system has overheated. If it doesn't get on at all anymore, you should get it fixed in the place you bought it from. That happened to me.
Feb 14, 2010 | Sony Playstation 3 (PS3) Console
Plasma TV turns off by itself-won't sty on for
when i turn my 32 inch VIVIO plasma tv on it turns pff by itself. i want to know why this is happening
Dec 07, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Nokia 6111 turns itself off after a few minutes when turned on.
You have to eject external memory card and after some time insert in your mobile and start. If this got again problem do it for 2-3 times . After that it will work.
Jul 02, 2009 | Nokia 6111 Cellular Phone
Mitsubishi WS 65513 turns itself off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jan 05, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Monitor goes off after a few minutes of use. when pressing the on/off button, sometimes will turn back on. if left alone will turn back on after a few minutes. when computer is off, sometimes will turn on...
1.check power supply section any dry points
2. To replace all electrolatic capacitors in Power supply
3.Check Connectors Properly connected Or Not.
4.Replaced Microswitches in Front pannle.
Oct 06, 2008 | ViewSonic VX910 19" LCD Monitor
Hitachi 65F59A turns itself off
The power supply may be failing.
Sep 02, 2017 | Hitachi 65F59A Television
Probable four bad caps in DM module = 1000mf/25v
Common repair for qualified Mits tech...........T.
Nov 11, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
119 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
