Question about Numark Dmc2 Rackmount DJ Software Controller
Numark DMC2 intermittent
When i plug the usb cable into my pc then start pcdj vj is onlt recognizes it is connected 50% of the time.
i know for a fact that the cable is fine and i know for a fact that is is being recognised by pcdj software because when you click o the controller option the dmc2 is highlighted green (if it wasnt connected or recognised its highlighted red.
but the controller either works fine and all the display is correct or it displays "pc no link"
please help not confident taking it to gigs as 50% of the time i take it apart and restart ect takes sometimes up to 1 hour to get it to work :(
2 Suggested Answers
oldmanewtoys
  • 414 Answers
SOURCE: numark Dmc2 issue
It is shutting down the DMC completely as in power? Not completely familar with this unit,but do use numark equipment. Is the software control compatible with your pc? As in 32 or 64 bit . May be a safty shutoff to keep from corrupting you software
Posted on Mar 05, 2010
Corrupt data
PX 410r uses IDES 4.0 downloadable from
http://www.casio-europe.com/euro/emi/specials/ides/downloads/
and not another version.
I suggest you uninstall the Casio USB driver from Control Panel'system'device manager then Reboot the PC without the USB cable.
Download latest USB driver from :-
http://support.casio.com/en/support/download.php?cid=008&pid=20
64 or 32 bits versions are both available.
Load driver first. Plug in the usb cable only when software tells you to do so.
Uninstall Data manager if wrong version.
Install IDES 4.0
Mar 08, 2014 | Casio Music
Hum in speakers using numark c3fx
Or an earth problem (connecting cable problem) or dirth in potentiometers or some leaking or bad capacitors
Feb 08, 2014 | Numark Industries NUMARK C3FX DJ MIXER
Can i connect a numark NDX400 to my sony surround sound its a s master amp?
Yes, you should use CD inputs and should work like a champ, hope it helps..
Oct 16, 2013 | Numark Industries Numark NDX400 Tabletop...
I HAVE A NUMARKKMX01 MIXER WHEN I PLUG THE RED RCA JACK IN TO THE MIXER I GET A LOUND HUM
What is plugged into your Numark mixer when this happens? Try disconnecting ALL audio inputs to your mixer, turn mixer volumes to zero and see if the hum is still present. Adjust the volume and check if the hum you mentioned returns. If it is still heard, try new cables between the mixer and amp...if not then start reconnecting inputs until the hum is heard again. It's a process of elimination but not that difficult to find the source of your problem.
Oct 31, 2012 | Numark Industries Numark DM 1200 Mixer
Hello guys, i have a problem with my midi keyboard. My PC doesn't recognize the USB connection and i can't find any solution.
Well first start by verifying USB port works by plugging in a hard drive or something thus proving you have a good port and USB Cable. At which point hook the keyboard up ( and make sure to properly install drivers provided on cd with purchase) being a pc this may take several attempts to install. What software are you trying to control? Reason? Logic? Fruityloops?
Oct 07, 2011 | Alesis Q49 USB/MIDI Keyboard Controller
My NDX400's display screen doesn't show anything. When I turn it on, all the "characters" flash white, so I know it works. But then, it just goes blank. No matter what I do, nothing shows...
If you was to turn the deck upside down you will see 4 main screws in the corners holding the silver top to the black chassis of the deck. undo these screws and carefully turn the deck over and lift the top off slowly. I say slowly because before putting it down (you might need someone to hold it for you) you need to un-clip the white plug and there will be a data ribbon stopping you from pulling the lid away. this is the strip you need to check both ends that the connections are clean and pushed in properly (the blue strip on the connector should be facing the middle of the circuit board) be careful not to snap the connector and make sure you push it into its socket straight and not at all at an angle or it could snap. put the white connector back in and pop the lid back on and turn it on to see if worked.
Jul 05, 2011 | Numark Industries Numark NDX400 Tabletop...
Numark Dmc2 issue
Mar 05, 2010 | Numark Dmc2 Rackmount DJ Software...
Connections
nuvj connects to your comp you have to supply connections from your comp to a projector
Sep 18, 2009 | Numark Nuvj DJ Video Mixer
Numark Dmc2 Rackmount DJ Software Controller Logo
135 people viewed this question
Top Numark Music Experts
Matthew Spark
Matthew Spark
Pieter Vleeshouwers
Pieter Vleeshouwers
J.D. Browning
J.D. Browning
Are you a Numark Music Expert? Answer questions, earn points and help others
