Question about Garden
Lawnmower repair manuals
How do I remove the spark plug for my firebrand lawn mower?
  • 313 Answers
SOURCE: removal of blade from black & decker lawn mower gx530
i used impact gun with 3<4 socket and run the impact in reverse
Posted on May 29, 2008
  • 45 Answers
SOURCE: Lawnmower Starting Pull Cord Replaement
There will be a piece of casing that holds the starter mechanism in. Usually held by 4 screws (probably torx screws unless it's an old machine).
Undo these screws and you will find the cord carrier inside.
Observe how the starter dogs are located, and how it all goes together.
You may be able to remove & replace the cord without taking the carrier off the casing, but it is probably easier if you do.
Then you simply remove the old cord, thread a new cord through the hole & tie it. Reassemble the carrier onto the casing. Thread the cord out of the casing & through the handle, tie that end.
Then wind the cord around the cord carrier until there is a slight tension on the spring.
Screw the casing back on the mower and you're away.
Posted on Sep 27, 2008
  • 68 Answers
SOURCE: I need to find a repair manual for a craftsman riding lawn mower
SearsPartsDirect.com should have your answers
Posted on Apr 26, 2009
  • 246 Answers
SOURCE: Need an owners manual for a craftsman lawnmower model 917254240
Hello kwoody2315:
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left. You can Also Enter "Owners Manual" in the Search Box and it will Direct you to the Page you Require.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
  • 16 Answers
SOURCE: lawn mower died while mowing and won't restart
check the carb and air filter... also make sure its not gas from last season and make sure the oil is good.
Posted on Aug 20, 2009
Why won't engine start after doing all these repairs
Make sure it is the correct spark plug with the correct gap. Then check to ensure that fuel is being delivered and is not bad
Jul 30, 2014 | Briggs & Stratton Briggs Stratton...
Lawnmower won't spark
check to make sure your safty switch is not engaging causing no spark other than that your coil would be bad but they hardly ever go bad i think your problem is with the safty switch
Apr 13, 2014 | Toro Lawnmower 20099 Mower Mowers Lawn
Craftsman gold 6.0 hp. walk behind lawnmower wont start
Back to basics, is the fuel in the tank good?( fill with fresh fuel ) does it have a spark at the plug?(remove the plug, earth against the cylinder, is there a spark,if not, replace the spark plug and try again ) does the plug wet with fue lafter pulling?( clean/service carb ) is the spark occuring in the correct place ( flywheel key sheard ) has the engine got good compression?
Aug 19, 2013 | Briggs & Stratton Briggs Stratton...
Pull rope will not pull
Remove recoil rope assembly. Ensure rope is properly wrapped around. While recoil assembly is removed use ratchet and socket to rotate fly wheel, remove spark plug first, observe compression and exhaust at spark plug whole during rotation of fly wheel. Clean or replace spark plug. Ensure oil is full. 30w. Set spark plug gap. Always use Stabile in gas. Replace coil rope is required. Purchased by the foot at any mower repair store.
May 12, 2013 | Toro Super Recycler Super Bagger Lawn...
How do you check if a spark plug is good on a lawnmower
take it out and look at it put the wire on the end hold it to metal and crank it over to check for spark no spark doesn't mean the plug isw bad but a bad coil if the plug has build up of carbon replace it
Sep 03, 2012 | Briggs & Stratton Briggs Stratton...
How to fix a 3.5 lawn mower?
HELLO,
You can fix these yourself, all you have to do is to follow the instructions below,
1 Remove the spark plug lead from the spark plug and move away from cylinder head. Always do this before attempting any repairs to a lawnmower.
2 If your lawnmower is a "four stroke" mower (separate gasoline and oil), tip the mower so that the spark plug is pointing skyward. Never tip it on its side with the spark plug to the ground.
3 If your lawnmower is "2 stroke" (oil and gasoline mixed) turn off fuel tap. You can tip a two stroke mower any way that is suitable to you.
4 To change a blade, or blade disc, it is often easier to remove the spark plug and feed a length of string into the cylinder head to 'lock' the piston while trying to un-do the blade bolt(s).
5 Check the motor's "air filter" while doing this sort of maintenance as a dirty or clogged air filter will affect engine performance and increase fuel consumption of your mower. Symptoms of a clogged air filter include inability to start, starting and quickly stopping after several sputters, or a weak idle. You may also see oily or smoky exhaust.
6 If your mower is a "four stroke" model, change the oil at least once a year. When it is tipped over with the spark plug in the air, is a good time to remove the "oil fill" plug and drain oil into an old ice-cream container for recycling.
I hope this will help to solve the problem.....
May 31, 2011 | Craftsman Garden
How do i replace blade on mountfield princess lawn mower. is it a left or righhand thread
It should be a standard thread. You may need to put a shop rag into the spark plug hole to make sure the engine does not turn while you are trying to remove the blade.
Mar 28, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
How to change a spark plug on a club cadett model # 959435
Hello. Changing the spark plug requires a couple of tools, all available at any auto parts store, and the right replacement plug. Regarding the plug, look in the manual or take the old plug to the auto parts store and have the clerk cross reference for you to be sure you get the same one or a comparable. Look at the links below to learn more about changing spark plugs in lawn mowers than most people know. Have fun with it.
Here is the link to a video to show you the steps. http://www.ehow.com/video_4426873_changing-spark-plugs-lawn-mower.html
http://www.oneprojectcloser.com/how-to-change-spark-plug-in-a-lawnmower-example-briggs-stratton-engines-in-craftsman-and-murray-mowers/
Apr 16, 2010 | Poulan "" Push Mower
I have a lawnmower with a BSA 3.5 engine that I cannot start, the problem seems to be no spark at the spark plug. As I have never worked on a lawnmower I have no idea what generates the spark on...
Test for spark by placing a screwdriver into the spark plug wire and holding it close to a bolt on the engine. should see a spark (blue). If not, problem is likely the armature (coil). The coil is located under the engine shroud and held in place by two bolts. If you replace this part, (normally $30 to $40) you must ensure a proper air gap. Auto parts stores have inexpensive repair manuals to help.
Lee
Cherokee Small Engines
Apr 21, 2009 | Garden
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
