Question about Canon PIXMA iP90 Mobile Printer
Ip90 printer makes a vibrating buzzing noise upon start up
I turn it on. The print head moves left then right. Rollers turn. When print head starts to move left again, there is a buzzing noise, which I think seems to be the roller locking up? Don't know how to fix. When paper is in the printer, it will start to feed the paper then jam. I don't see any obstructions. When turned off, then back on again, the paper will all clear, until it gets to that point again as described above.
    Problem Solver:
  • 16 Answers
Something is obstructing the rollers.something such as an office pin or pen/cock or any other thing might have fallen inside.open the machine and clear the jam.
Posted on Jun 14, 2015
  • 12 Answers
SOURCE: Error E3 when no paper jam
MP160 PIXMA paper feed jam E3 error. I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180. With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper. The usual c-clunk sound that indicated the feed roller has been engaged was not there. The screen warning said to remove jammed paper and the printer showed an E3 error.
The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front). The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads. Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points. Its not a quick fix.
When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier. The lever is actuated by the ink cartridge carrier when it moves to the right. If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer. Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
Posted on Jun 13, 2009
  • 1335 Answers
SOURCE: Canon PIXMA MP530 Error Code 5100
OK. It sounds like there's something on the carriage bar restricting the movement of the ink carrier. Perhaps some ink got on the bar.
Try taking a clean lintfree rag dampened with rubbing alcohol and clean the bar. This may have to be repeated a number of times to get the foreign matter off the bar and the ink carriage.
Let me know if this helps. iF it does not we can try something else.
Thanks.
Posted on May 05, 2009
SOURCE: LCD Error: "Check Printer"
I FOUND A SOLUTION that worked for me for the CANON F50:
F30/F50 Printer
1. Enter Service Mode - by pressing "menu then copy then #"
2. Select TEST MODE
3. Select (8) PRINTER TEST in TEST MODE
4. Select 3 (EEPROM CLEAR)
5. Select 0 (INK COUNT)
6. Press Stop/Reset key
7. Press On/Off Key
Posted on Oct 16, 2008
  • 20 Answers
SOURCE: paper wont feed
I had the same problem and it turns out one of my kids put a coin into the top of it and it was far down inside where i could not see it.and it was stuck in the bend of the paper feed after tearing it almost all the way down i finally was able to see it removed the coin and it worked.
Posted on Nov 03, 2009
Joed911
  • 4338 Answers
SOURCE: Paper feed issues when there
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Posted on May 19, 2011
My Canon MG8120 all-in-one makes a loud noise when copying (not when printing). How do I fix it?
Dear
from the question I understand, the scanner move to right and during return it starts noise.
The problem with scanner assembly, It might be dust accumulated on gears, the scanner belt might have loose or the grips of the belt has worn out. Proper cleaning and lubricating the moving parts may overcome also if the belt worn out it has to be replaced.
In case of at home position it gives noise then the home position sensor may dirty/dusty, it has to be cleaned.
thanks.
Feb 15, 2015 | Canon Pixma MG8120 Wireless Photo...
Tip
Noise while printing - Diagnosis Pt 1
<p>Unexpected noise (such as clicking, thumping, or grinding) from an branded device are heard during printer operation.<br /> <br /> <span><b>NOTE: </b></span><br /> Noises can be caused by a number of things, some of which may not be addressed in this document. This document deals strictly with the isolation and potential resolution of known noises through troubleshooting.<br /> <p>The following table describes some of the noises to be expected in a printer functioning normally:<br /> <span>Noise occurs:</span> <br /> <span>Additional information:</span> <br /> During power-up<br /> When the printer periodically makes humming and buzzing sounds as the carriage assembly moves around on the right/left side of the printer, the printer is actually cleaning the ink cartridges. This is a normal operation for the printer. This sequence may happen in the following conditions:<br /><br /><br /> <ul> <li> <p>Before and/or after printing<br /> <li> <p>During power on <br /> <li> <p>After the printer has been on standby/idle for some time<br /> <li> <p>After replacing a cartridge<br /> <li> <p>In the middle of a long print job (such as printing many photos)<br /></li></ul> During printing*<br /> <ul> <li> <p>Paper pickup: There will be some noise during paper pickup due to the movement of rollers and gears.<br /> <li> <p>While printing: The unit has printed a few lines or the paper has been fed into the printing area. There will be some noise during printing due to the movement of rollers, gears, carriage and paper (paper feed and ejection).<br /></li></ul> During paper ejection*<br /> At the end of the print job, there is a louder clicking noise as the paper is being "pushed off" to the output tray.<br /> During copying/scanning<br /> The scanner may make pulsing and dragging noises as it scans portions of the document or it may make a long rolling sound if it is doing a continuous scan. After scanning, it will make a long dragging noise as the scanner is brought back to the home position (could be on the left or right side).<br /> Post-printing with no additional jobs in the queue<br /> Post-completion of a print job and without another job in queue: At the end of a print job, there will be a noise on the left/right side of the printer as the pens are being capped. The printer may try to do this a couple of times, which is normal.<br /> Between print jobs<br /> The printer may make humming and buzzing sounds as the carriage assembly moves around on the right/ left side of the printer during the cleaning of the ink cartridges.<br /> In the accessories<br /> There may be some noise associated with accessories (ADF, duplexer, etc.) during the initial positioning and during normal operation.<br />
on Mar 10, 2011 | Office Equipment & Supplies
Canon PIXMA MP240 scanner problems (physicl, not digital)
when i load paper it feed cockeyed,,,when rollers start it appears to only fee on one side and crinkles paper ..turns sideways and stops feeding....Help !
Nov 24, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Canon Pixma iP90 - Jagged text and lines
The printer has a plastic band that runs from one side to the other. The print head has a sensor that passes over it each time it moves. The band is a little transparent and appears to have vertical lines in it. That needs to be cleaned.
  1. Remove power from the printer,
  2. Wipe it clean,
  3. Move the head manually to other side to clean the other areas.
Hope this helps.
Jun 02, 2009 | Canon PIXMA iP90 Mobile Printer
Wont print
I had this problem recently with my IP90. Both the black and color heads were clogged. After running the "canned" routines several times to clean the heads and deep clean the heads...still didn't help...here's what I did:
1. open the top lid to have the cartridges that are inserted in the print head move to the middle of the printer.
2. remove both cartridges
3. What is left there is the print head holder. Slightly move it to the right and gently lift the print head lock.
4. Grasp the print head and lift it out of the tank.
5. Have several paper towels hand and know that you will have color and bw ink on your fingers
6. Put the print head on the paper towel
7. Pour rubbing alcohol on the blk and color heads and let them sit of about 10-15 minutes.
8. after that dry the heads and re-insert them in the printer
9. I put new cartridges in the printer and ran clean and deep clean a few times.
10. My color and black and white print came right back!
Hope this helps.
Mar 17, 2009 | Canon PIXMA iP90 Mobile Printer
IP90 WONT PRINT BLACK
Hope this helps.
Jan 30, 2009 | Canon PIXMA iP90 InkJet Printer
Error light on stylus c62- printer makes loud buzzing
It sounds like the print head is jamming on the parking mechanism (usually because the actuation lever is stuck in the up position). Turn the printer on, and as soon as the print head moves, pull the power cord out of the back. You should now be able to move the print head over to the left by hand out of the way. Now look in the "parking bay" at the right end where the print head parks itself and see if there is a plastic arm sticking up. If there is, gently pull it towards you and it should spring down. Now turn the printer back on and it should operate normally. If it happens again, repeat the process a few times to see if it clears the problem. Otherwise it means the parking mechanism is gummed up with dried ink and needs a good clean (see below).
If you see that the whole parking mechanism itself has moved up to block the way, this means a spring has come off. To get this back on again requires the printer to be dismantled - as does the cleaning job above!
Jan 27, 2009 | Epson Stylus C62 InkJet Printer
Figuring how to install new print head in my Canon iP90 printer
The important point is moving the head to the left, or sliding it left or right, so you can actually SEE the LEVER. It is hidden otherwise and what appears to be the obvious lever on the top is the wrong lever. If you have pressed the correct lever the unit removes very easily. If it is hard and you cannot make progress chances are you have not found the correct LEVER!
Sep 04, 2008 | Canon PIXMA iP90 Mobile Printer
Print Head
After opening the purple cover, the printer head will move to the center. There should be a gray tab on the left side of the forward facing opening (about the middle of lower cartridge). Gently push printer head to the right (1/4 to 1/2 inch) and a gray slanted tab will appear from behind housing. lift this tab and a metal lock will pop up. Tilt lock back and the printer head should be lying loose in its cradle.
Apr 11, 2008 | Canon PIXMA iP90 InkJet Printer
Paper will not feed into printer
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Oct 17, 2007 | Lexmark X83 All-In-One InkJet Printer
Canon PIXMA iP90 Mobile Printer Logo
446 people viewed this question
old marine
old marine
