Question about Dryers
Kenmore 87574120 dryer
Missing door switch
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: how to change the dryer door switch
To remove the panel you need to undo two screws.
How to take apart the dryer:
Older (29 inch) Whirlpool/Kenmore models.
Newer (27 inch) Whirlpool/Kenmore models.
How to replace door switch:
Free Dryer Repair Guide - Replace your dryer door switch
Door switch replacement help for a common door switch
Posted on Feb 24, 2009
  • 111 Answers
SOURCE: I need to replace a door switch on a Kenmore Dryer
I'm not too familiar with the model but you either have screws that are just above the door (open the door first) or two metal tabs in the front that hold the top on the dryer. The two metal tabs can be seen if you take a flashlight and look where the top meets the front about 8" from each side roughly. A flatblade screwdriver inserted at the top of these fasteners will release them from the top. Next have a 5/16 nut driver to remove the two screws on each side holding the front onto the sides. There may be screws at the bottom as well. You may not have to remove the front at all. Also HAVE THE POWER DISCONNECTED! Don't want ya to get fried. Remove the leads from the door switch on the right and remove.
Posted on Oct 30, 2009
How to check the door switch on my kenmore dryer 11074832400
access switch and tape the leads together,,, if dryer works bad switch. if not something else is problem,,( of course unplug dryer before unplugging switch)
Aug 28, 2014 | Kenmore Dryers
Where can i find the door switch on the kenmore 70 series dryer
the door switch is located inside the door on top left or top right of the dryer, if it is one of the newer 70 series dryer it will be on the inside bottom towards the middle
Apr 13, 2014 | Kenmore 63942 Dryer
I have a kenmore steam dryer electric model 8044 and the light in the drum doesn't come on when door open?
It sounds like you have a faulty door switch. Switches are typically inexpensive. You can find Kenmore dryer switches at PartSelect.com (you just have to know what you're looking for):
http://www.partselect.com/PartSearchWizard.aspx?Appliance=Dryer&Brand=Kenmore&PartType=Switch
Dec 28, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
How to replace door switch on old kenmore stac.dryer 110.88752792
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.Check online for the part repairclinic.com has it for $14.00 not bad
Nov 17, 2009 | Kenmore 63942 Dryer
Kenmore dryer will not start. is it the door
since to push button is a contct relay,
i would suspect, the door switch first
Oct 13, 2009 | Kenmore 62602 Electric Dryer
Dryer just stopped
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
I would also, check the Thermal Fuse as well.
Jun 25, 2009 | Kenmore 62602 Electric Dryer
Kenmore electronic sensor gas dryer thinks door is open
Hello linda, it sounds like the door switch is not working in the closed position, when you close the dryer door the door switch shut's the light off, it also allow's the dryer to run when the door is closed, if it's defective the dryer will not run, check the connections at the door switch, if the connecetor and wire's look ok your door switch will have to be replaced. Hope this help's.
Apr 02, 2009 | Kenmore Dryers
Washer door
The washer door is not switchable, but you will need a kit to switch the dryer door. talk to your sears rep for the kit number
Feb 02, 2009 | Kenmore Elite HE4 Electric Dryer
Need help with OLD dryer
IF YOU MEAN THAT THE DRYER STARTS BACK UP WHEN YOU CLOSE THE DOOR, THE PUSH TO START SWITCH IS SHORTED. CHECK TO SEE IF THE PUSH TO START BUTTON IS STUCK PRESSED IN AND NOT SPRINGING BACK OUT.
IF IT IS STUCK, TRY WD-40 TO LOOSTEN IT. OTHERWISE, REPLACE THE SWITCH.
IF THE DRYER KEEPS RUNNING WHEN YOU "OPEN" THE DOOR, THE DOOR SWITCH IS SHORTED. REPLACE THE DOOR SWITCH.
Mar 31, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
19 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
