Question about Refrigerators
Caravan fridge tripping when connected to electricity
A Sprite caravan fridge - wiring seems to have been tampered with.
Could I have a proper diagram?
  • shaun greyvensteyn May 11, 2010
    it is hard to get a diagram but il try to explain but i want to know if it is a 12v or 220v side that are tampered with
  • 159 Answers
On what voltage doe it work then i can tell you exactly how to wire it
Posted on Jun 01, 2009
Need the wiring diagram for the aux circuit feeding caravan fridge power while the engine is running.
Understanding Caravan and Tow CarUnderstanding Caravan and Tow CarIn the beginning.... The first and oldest electrical system on caravans, that was installed way back when most caravan's were no more than small garden sheds on wheels were the rear lights that replicated the rear lights of the towing vehicle, usually no more than two side lights and two brake lights.
Illumination for inside the caravan was provided by gas lights fed from a small gas cylinder usually clamped to the "A" frame of the caravan. It wasn't long before the lighting system needed to be upgraded, as direction indicators became mandatory on cars, additional wiring was needed to replicate indicators on the rear of the caravan. Skip forward a few years and a rear fog light became mandatory, so a further upgrade was made to the lighting electrical system to allow the rear fog light to be installed. The wiring for these lights was connected through a 7 pin plug to the car that is commonly known as a "12N" connection.Sometime in between the indicators and rear fog light changes, people decided they wanted to replace the gas lights inside the caravan with 12 volt lights that could be run from the car battery. People often used old car spotlights or other 12 volt lights that were found in cars of the time as interior lights and these soon drained the car battery, so an "upgrade" was to install a second battery in the caravan that could be used to provide power for lighting. These were usually old car batteries. It would be another few years before the dedicated "leisure battery" came along. Originally, you would have to take this battery out of the caravan and charge it at home using a standard car battery charger. Again, in a continual developing process, someone came up with the idea of being able to charge the second battery in the caravan from the tow car while driving along the road, or when on site, being able to run the engine of the car and using a long lead be able to plug the caravan into the car to charge the battery for the next nights use of the lights, So a second "supplemental" electrical system was born and the "12S" (S for supplemental as to differentiate it from the 12N or Normal) connection came into being.he 12 Volt systems
The 12 volt systems are split into two. The first, and as we have seen, the oldest is the caravan road lights, that is to say the lights that are required by law to have on all trailers. These lights consist of "tail" or "rear" lights - rear side lights (red), brake lights (red), direction indicator lights (orange), reversing lights (white) and fog lights (red). Due to the size of a caravan front marker lights (white) are required and from 2013 side marker lights (orange) on longer caravans.
12N & 12S Vehicle Wiring
These lights are connected to the car via a 7 pin "12N" type plug or by a more modern "continental" style 13 pin plug. The road lights are usually a complete system with all the supply and earth connections being separate from any other electrical system on the caravan. One of the most common faults with road lights is problems associated with the earth lead, but more of that later.
The only road lights that are not connected via the 12N connection are the caravan's reversing lights. The original 7 pin socket when it was developed was thought to have enough connections for everything anyone could ever want. Unfortunately as the years progressed, the number of "spare" connection on this plug diminished, to the point where there was no spare connection for the reversing lights. However, with the advent of the 12S, this was taken care of.The second 12 volt system is the supplemental system. This is designed so that when towing, you can charge the caravan's leisure battery, power the fridge and in some cases power an electrical brake system. The design of the supplemental system has to take into account a number of things:-
• It must be able to charge the caravan's leisure battery only when the car battery is fully charged and the engine is running.
• It must be able to power the caravan's fridge - but not allow the fridge to flatten the car battery if the engine is not running.
• It must be able to power the internal 12 volt electrical system of the caravan, but turn everything off when the engine is running.
• It must not interfere with the correct operation of the road lights of the caravan or towing vehicle.
OK, so lets look at the first one -
"It must be able to charge the caravan's leisure battery only when the car battery is fully charged and the engine is running"roblems with this type of connection. If the car battery is flat and you try to start the car, a heavy current will be drawn from the caravan's leisure battery and would cause the caravan wiring to over heat and possibly cause a fire. It would also damage the plug and socket connecting the caravan's wiring to the car, as they are not designed to take the high currents involved in starting a car engine. So how can we do this safely?
Sep 29, 2016 | Cars & Trucks
Circuit breaker tripping
Sounds like the electric motor in the fridge may have shorted out some of the windings which is causing it to draw more current. You should get one of those clamp on amp meters to see how much current it is drawing when it first kicks on.
Jan 23, 2014 | Admiral 26 cu. ft. Side-By-Side...
My fridge tripe the earth leakage everytime I switch on the fridge.
call ana accredited electrician to check the insulation of the wires and for vermin infestation that is across electrical connections
it could be a faulty capacitor or failed motor as the earth leakage breaker is also a fuse for excessive current draw
Jun 08, 2017 | Whirlpool Refrigerators
Why does my caravan fridge trip out when connected to 240v
The heater element is almost certainly to earth. Work it on gas until you can fit a new heater.
Jul 01, 2012 | Refrigerators
E442 Fridge Was noisy, now trips mains power :(
Sounds like the compressor is grounded out causing the breaker to trip, but it could also be wiring, but if I recall most things in those type of machines reduce down to 12vdc and that wouldn't blow the breaker.
Jun 03, 2012 | Fisher and Paykel Refrigerators
Hi, my fridge freezer keeps making the electric trip out. help!!!
Try this:
Turn your thermostat as warm as it will go, you are trying to isolate the compressor and keep it from turning on. If your fridge has an "off" position, then turn it off. Reset breaker, plug refrigerator back into the outlet. If the fridge trips while "off", then you are likely looking at a damaged cord / wiring.
If the breaker doesn't trip, unplug the fridge, and move the thermostat to the warmest position possible. Plug fridge back in, If the breaker holds, then you are on right track. Slowly move the thermostat to a cooler setting. You want to just reach the point where the compressor tries to start. If breaker holds here, then you are in good shape so far. It indicates a problem with the defrost heater (if equipped), or the ice maker (if equipped). If the breaker trips as soon as the compressor tries to start, your compressor may be damaged (bad and expensive).
Aug 17, 2010 | Refrigerators
Ditto
check for tripped breaker and proper voltage, next check to see if turns on if your getting air to the outside vent if ok the you need to open the unit up (unplug it FIRST) your be looking for the thermal fuse and or the cutoffs these will be attached to the blower housing assy ohm them out and also if electrical one check the heating element as well most cases this will solve your problems
Aug 21, 2009 | Bosch Axxis WTL 5410 Electric Dryer
RM4236 tripping site electrics
Paul;
Are you tripping the shore power pedestal? If so did you unplug the fridge and try it. The park pedestal breaker should be at least 30 amp and I can not believe the fridge would trip the site breaker before it tripped the breaker in your caravan. Are you sure it is the fridge? Your fridge is an old eletrolux dometic and I can not find the manual in my files. You may call Dometic and get a manual but That will not help you much. I will be more than glad to resolve your problem but I need more info.
The Dometic# is 800 366 3842. Prompt to tech dept.
Repost to us
Thank You for using Fixya
Jerry
Mar 26, 2009 | Electrolux Refrigerators
Fridge tripping the electricity
Hi
this sounds like the defrost heater is faulty. because at a certin time the m/c brings on the heater one every 24 hours that is why it is only tripping out at that time.
regards
Mar 22, 2009 | Fisher Refrigerators
Refrigerators Logo
345 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
