Question about Kenmore 44042 Front Load Washer
Kenmore 44042 - No spin cycle
Our Kenmore 44042 Front loader has just stopped spinning.
My wife had an unbalanced load a couple of days ago and now it has stopped the Final Spin cycle.
Tried it on Fast and Normal settings and the same thing happens..
It drains the water out just fine, does the back and forth low speed tumbling but then when it is supposed to rev up, you can hear it whine a little and it starts turning but then slows down and does the back and forth tumbling again. I am halfway handy with a wrench/screwdriver and am happy to get it apart if anyone has a clue.
Thank you
Phil
  • 100 Answers
The front load washers are supported by springs on the top and shocks on the bottom.  More than likely you broke a spring on the top or cracked one of the shock mounts which causes and unbalanced load all the time.  Will it go through a spin cycle with no clothes is it?
Posted on Oct 30, 2007
Why does it always become unbalanced in spin cycle?
how confident are you to get inside it? Check the balance springs and shock absorbers.
Normally it is two simple things.
First the machine must be level front to back and left to right. Also all 4 feet must be in equal contact with the floor.
Make sure you load the washer evenly with clothes. Mix large and small items so when the spin starts the clothes even out. Never wash just one large item that is very absorbent, like one bathrobe or one blanket..
Dec 26, 2015 | Washing Machines
My Kenmore he front load washer stopped at the rinse and spin cycle. I don't know the model but it only a few years old. It made a load noise before stopping. I attempted to get it going again wit
Kenmore front loader. stopped at rinse. First ck to see if you washer works at different settings if so its very possible its your timmer or what called the wig wag or solonoid this switches the machine to spin & rinse. A basic service call should resolve your problem.
Jan 30, 2012 | Washing Machines
I have a Kenmore front load washer that will not spin all the water out of the clothes. After it finishes I have to run it through a rinse spin cycle and it does fine. The machine is only 14 months old
The first thing to check is probably the filter at the bottom of the machine. I'm not sure about this particular model, but the usual thing to do is to remove the machine's front lower panel - i.e. the panel at the front of the machine, closest to the floor.
You will probably find a little drawer or door, just a couple on inches in size. If you open it, you may find some lint, a couple of elastic bands, and enough coins to buy a beer. If so, it's the coins that are causing the problem! Take out all the stuff, close the little door, put the panel back on, and everything should run fine.
I hope that helps. Good luck!
Oct 09, 2010 | Kenmore 44042 Front Load Washer
Cylce stops after 1st drain before spin out
I have kenmore washer front load H2 after 1st circle of wash it stop and start beeping with code F11. My email address is anarfi1212@ live.com
Jan 21, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore 417 FLW stuck in final spin cycle
It appears as though this is a known problem with the spin control board component, so ordering a new board should solve the problem.
Oct 17, 2009 | Kenmore 44042 Front Load Washer
Shaking
Most common cause for the machine to shake during the spin cycle is due to a unbalanced load. A load of a couple of small bulky items or a small load in general may not be able to distribute the weight properly causing the machine to be unbalanced. It is best to wash full loads whenever possible. We have a brand new front loader as well, our first load about took the walls down...We just tossed a couple things in to see how it worked....thats how I learned to wash full loads. Now with the knowledge of why it shook so bad, we have had no more problems. Hope this helps
Please take the time to give this solution a fix ya rating
clarkco
Feb 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Kenmore 80 series washer stopped during unbalanced spin cycle
lid switch is broke lever probley broke off or screw holes broke out due to off balance load forcing tub over against switch lever
Apr 29, 2008 | Kenmore 20172 Top Load Washer
Danby washing machine noisy only during spin cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jan 13, 2008 | Danby DWM99W Top Load Washer
My old Hoover top loader Washer is noisy & doesn't spin out properly - how can I fix it?
Sounds like the switch which cuts the machine off when the load is unbalanced. My guess is that: This switch is being triggered too easily The springs holding the bowl up are either stretched or one is broken; The machine may not be level.
Mar 30, 2007 | Hoover HTC243 Top Load Washer
Kenmore 44042 Front Load Washer Logo
255 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
