Question about Rosendahl Arne Jacobsen Bankers Alarm Clock AMC-RD-43675
When the rear case is placed back in position the light keeps flashing. Why is it happing?
My silver elite keeps reconnecting even when I have it in the off position
I was having the same issue. When it switches to off by turning the earpiece it will flash a blue light 3 times. carefully place it in the case but do not press down. use the lid of the case to close it all the way. Mine at least seems to stay off. before I was pushing it into the case and it would come back on even in the closed position. hope that helps you.
Jul 22, 2016 | Motorola Mobility ELITE SLIVER Bluetooth...
4wd indicator flashing
There is a fault in the system l;ike the motor is burned out or the contacts are burnt in the position sensor of the transmifer case.
Apr 02, 2014 | 2007 GMC Canyon Crew
4wd/4low lights flash
Hi there:
That flashing is a signal from the GEM computer that indicates a failure in the Control-Trac system. Typically it is one of the Hall-effect axle speed sensors (located in the t-case) that has failed. In the auto position on your model the system monitors relative front and rear axle speeds, increasing the period of engagement of the clutch pack in the transfer case to eliminate the rear moving faster than the front. If it gets to full-lock, for example, and the rear still seems to be turning faster then it reverts the system to 4WD (locks the transfer case in 4wd as it does in 4wd-lo) and flashes the lights to tell you of the problem (in 97 and later models it reverts to 2WD in the default, auto position). Some have reported cleaning the contacts on the speed sensors has helped, but you may want to get to a dealer if the problem persists. Watch that they dont automatically try to replace the computer or the transfer case. Usually it is just a sensor problem, which is relatively easy and inexpensive to replace. There is a shift motor on the t-case on these models, but it is only used to select 4wd-lo and yours seems to do that OK.
Other details HERE.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 23, 2012 | 1997 Ford Explorer AWD
4wd 4wdlow light flashing
Hi there:
Feb 23, 2012 | Ford Explorer Cars & Trucks
How do i turn engine managment light off plz on a volvo c70
  • 1
    Place the key in the ignition and move the key to Position I.
  • 2
    While keeping the key at Position 1, press and hold the reset button for the trip odometer. You will find that button located where the speedometer is.
  • 3
    While still holding the button for the trip odometer, move the key to Position II.
  • 4
    At this point, wait until the service light is flashing, it should take about 5 seconds for this to occur. When it hits its 3rd or 4th flash, move the key back to Position I.
  • 5
    Release the button for the trip odometer. Next, start the car and you will notice the service light should be reset. If not, try it again. It may take more than one time to get this light reset. Good Luck!
  • Mar 12, 2011 | Volvo C70 Cars & Trucks
    PSC 1315 All-In-One InkJet Printer: The orange light keeps flashing. This has been hap...
    Please perform the steps given below and check.
    1. Press the Power button to turn off the product.
    2. Wait 15 seconds.
    3. Press the Power button to turn the product on again.
    NOTE: The product might go through a warm-up period of up to two minutes. The product lights might flash and the carriage might move. Wait until the warm-up period is complete before proceeding.
    4. Try to print a self-test report. Refer to the steps on how to print a self-test report at the top of this document.
    If the issue still persists perform the steps from the HP Web link and check.
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01578337&cc=us&lc=en&dlc=en&product=374568
    May 18, 2010 | HP PSC 1315 All-In-One InkJet Printer
    When the power button the red button flashes but nothing else hap
    the red light flashing means the set is in auto shut down, could be a power supply problem or a convergence IC problem. tech should first check all diodes and caps in power supply then replace convergence IC's
    Jan 11, 2009 | Panasonic PT-53WX42 53" Rear Projection...
    COPIER PROBLEMS
    Start by powering off the device and unplugging if from the wall. Let it set about 1 min and power back on. If the jam light is still on go to the directed area and make sure that an actuator, switch or sensor is not pulled out of position or covered with paper dust or a tiny piece of paper. If all is clear and nothing out of place you could have a bad senor, switch or actuator. The worst case would be a bad board.
    Dec 27, 2008 | Canon PC-940 Black and White Copier
    Hey i need help
    youre losing your signal and it sends the tv into stanby mode and cauuuses the power supply to shut down
    Apr 29, 2008 | Sony KP-51WS500 51" Rear Projection...
    Rosendahl Arne Jacobsen Bankers Alarm Clock AMC-RD-43675 Logo
    Top Rosendahl Home Experts
    john h
    Tom Chichester
    Are you a Rosendahl Home Expert? Answer questions, earn points and help others
