Question about NetGear Computers & Internet
Security Key for Netgear router B90 755044 15
Where can I find the security key
azz949
  • 55 Answers
SOURCE: NETGEAR WGR614v7 Network Security key
Hi, you need to connect to the routers admin pages to configure the wireless settings and security. Check out this page:-
http://kbserver.netgear.com/kb_web_files/n101676.asp
When you get to step 6, click the WPA-PSK security setting and it will give you a box to type in a password of your choice, make it memorable but difficult to guess, so a mixture of numbers and letters. I think its a min of 8 characters.
Hope this helps..
Posted on Jan 25, 2009
megax01
  • 50 Answers
SOURCE: i cant connect thru my netgear router model wgr614v7
If you hook your PC directly to the router using an Ethernet cable you don't need the key. You can log into the router and change the WEP Key to anything you want, but u have to be directly connected to the router not going through the wireless.
Posted on Jan 26, 2009
  • 345 Answers
SOURCE: trying to find my security key for netgear router
You can only find it by logging in to router local IP address. Some routers are 192.168.0.1 and some are 192.168.1.1. Open up your browser and type this in the address bar. Which ever one comes with user name and password is the one you use. if you don't remember you user name and password the only way to log in is to reset router to factory settings. To do this there is usually reset button on back of router. Use pen or something small and push in to the reset hole until u fill button being depressed but make sure u don't press to hard because it can puncture. Hold it in for minimum 20 seconds and release. All of the information that was put in will be erased and then you can start from beginning. Default settings are without security key. For user name and password you can try Administrator and leave empty password field or try password. Once in router settings go to your wireless set up and create new WEP security key and write it down together with user name and password. Good luck.
Posted on Dec 30, 2009
  • 10 Answers
SOURCE: I need the security key to my existing wireless netgear router.
The Security Key is normally used for Wireless routers to protect your connection from any unauthorized use. As you have said that you do not have the Security key for your router with you, the best way to connect your ACER laptop to the Netgear router is by asking your Wireless service provider to reset the security key & freshly reentering the same on both of your HP & ACER laptops.
Posted on Feb 06, 2010
Need netgear security key
Connect the computer to the router.
Check the IP address of the router.
Open the setup page and you will find the network key.
See how to find network key
Mar 31, 2012 | NetGear RangeMax NEXT WNR834B Wireless...
Need a network security key how do i find this out
to find out your network security key, you first need to make sure that you are securely connected to your netgear router. after doing that, open a browser and type in 192.168.1.1 or www.routerlogin.net on the address bar. the username is " admin " password is " password " if it ask you for it. then it would take you now to the netgear page. on the left side of the screen. click " wireless settings " and scroll down to security options. the passphrase is your network security key
Feb 20, 2011 | NetGear WGR614 Wireless Router
How do i get my security code for my netgear WGR614v9
The default security key will be printed at the base of the router. If you have not changed the default security keys then you can use it. If you have changed it then you will have to log in to router interface and retrive your security keys.
Hope this helped.
Feb 07, 2011 | NetGear WGR614 Wireless Router
What is the security key of netgear wireless connection?
Security key in side the router. To get the key you need to access the routers web interface. Please follow the steps below on a wired pc. A pc which is directly connected with the netgear router using an Ethernet cable.
1. Open internet explorer and in the address box type http://192.168.0.1 and press enter. It should ask you a user name and password. User name is admin and password is the word password. click on login or ok.
If you don’t get user name and password window with http://192.168.0.1 and try http://192.168.1.1 or http://routerlogin.net
2. Click on wireless settings on the left hand side.
3. Under the security section if the security is wep then note down the key one and this is the security key you need.
If the security is something else then you wont be able to see the security key it will ******. In this i'll suggest you to change the security key to wep, encryption should be 64 bit and authentication type should be open. In the security key one box you need to type in the security key, The lenght of the key should be 10, you can only use a-f and 0-9. For example 123abc567f. and save the settings.
Try connecting on the wireless pc.
Note: if you change the security key then you need to connect all the wireless devices with the new key.
Hope this helps you!
Rashish.
Aug 16, 2010 | NetGear WGR614 Wireless Router
I have wireless network Netgear / lost security key
Log into your router ( default log in details can be found by googling your make) if you have changed the log in details, you may need to reset the router to factory default ( again, google this for a how to)
Go to wireless settings and then security ( or the other way around depending on your model) and your key will be there
Jul 31, 2010 | NetGear WNR1000 Router
Cant connect netgear router wants security key i
Sometimes the security key is on a sticker underneath unit, if not reset router to factory defaults by holding in the reset button at rear with a pencil or something similar.
Mar 17, 2010 | NetGear WGR614 Wireless Router
Feb 06, 2010 | NetGear RP614 Router
DONT KNOW WHAT MY SECURITY KEY IS CAN I RESET? IT
Do you mean the encryption key?
If so you can reset the Netgear back to the default settings and setup a new encryption key.
To RESET the router, press the pinhole RESET button at the back of the router for approx. 10 secs until the LEDs flash.
For instrustions on how to secure and configure the Netgear wireless router and the wireless card in the computer/laptop please click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
The Netgear configuration URL http://192.168.0.1
Default login = admin
Default PW = password
Should you need further help, please leave me a comment.
Dec 25, 2009 | NetGear WGR614 Wireless Router
Hope this helps..
Jan 25, 2009 | NetGear WGR614 Wireless Router
I cant connect thru my netgear router model wgr614v7
Computers & Internet Logo
32 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
