Rockola jukebox I have a Rockola CD 9000 Jukebox that will not play the song all the way through It will play about 3 to 5 seconds and stop, then go to the next song. Can you help? We have no service people nearby.
  • o_spoon Jan 20, 2009
    mine plays 3 seconds then stops , prob the pickup or {player]
  • Robert Turbeville
    Robert Turbeville Jul 07, 2017
    Need some help from someone that has a Rockola 9000. I have one but it didn't have the color tubes with it. I am trying to find out what colors the tubes are or if they have a color sheet inside the plastic color tube. Email me at rtville77520@yahoo.com. Thanks, Robert
  • 195 Answers
SOURCE: Song Programming
With regards to your problem with the Rowe Ami 100 cd jukebox.
Do you have a manual, if not I suggest you buy a printer manual or one on CD and refer to the Programming and Installation section.
In order for the jukebox to know about the cd's that are installed in the jukebox it has to initialize all or the changed cd's that have been replaced within the jukebox.
Put the jukebox into the Service Mode (the service mode should appear on the display)
Type 3 to select the Initialize sub menu
Type 0 and full initialize will appear on the display
Press Popular to start the initialization
Place the jukebox service switch into the normal mode
Initiazation will take around 30 minutes to complete.
Regards
Alan Hood
ami-man
Posted on Feb 27, 2009
  • 195 Answers
SOURCE: My cd rowe ami jukebox is stuck in scan/transfer mode
You say you do not have the digital display lite up, have you checked all of the breakers on the power supply?
If not do so. Rowe Ami jukeboxes are very prone to dry joints (cold joints in the USA) this is cracking around the soldered pin on the connections to the boards.
If you can solder correctly then check out the printed circuit board on the power supply. I would retest and see if the display now lights after correcting a fault on the power supply.
If that has not made any difference then proceed to the Mechanism Control Board and the Central Control Computer (CCC) and check again for dry joints.
If you can not solder with any confidence then send in your boards to a Rowe Ami specialist for testing/repair.
Regards
Alan Hood
ami-man
UK
Posted on Mar 11, 2009
MechMusicSF
  • 16 Answers
SOURCE: i have a rockola mystic jukebox & one side of the
Either a bad connection somewhere, or one channel in your amplifier is out.
Before you try anything else, switch the amp from 'stereo' to 'mono.' If the speakers come on, your amp is good and you simply have a bad connection somewhere between the amplifier and cartridge (thing that holds the stylus"needle"). Or, possible, but not probable, a bad cartridge.
For a quick fix, switch the amplifier to "mono" and then run all the speakers to the working channel.
In the meantime, if you're handy, try switching the speaker leads and such and see if you can isolate the problem.
Kyle~
Posted on Apr 18, 2009
  • 38 Answers
SOURCE: Rowe Jukebox CD-100E. When I turn it on the
AT THIS TIME YOU ARE NOT SURE IF THE PROBLEM IS IN THE LASER ASSEMBLY, OR THE AMPLIFIER?
BORROW OR RENT, AN AMPLIFIER HOOK IT UP TO THE OUT PUT ON THE LASER OUT PUT ON THE LASER CD OUT PUT. LOOK AT LASER UNIT IT HAS A MARKING ON IT THAT SAYS AUDIO OUT PUT. PUT CABLE TO A SECOND AMPLIFIER.
THAT WAY IF IT STILL FADES. THEN THE CD LASER IS THE PROBLEM . IF THE SOUND IS GOOD THEN THE AMPLIFIER IS AT FAULT
DOCTOR FIX IT
Posted on Nov 04, 2009
SOURCE: Trying to figure out my NSM Galaxy CD jukebox
when i put 50 cds into my nsm galaxy juke box thay get stuck in the rack and will not play .it will load about 39 and play any more and thay seem to stick
Posted on Feb 21, 2010
Need stylus type for 463 rockola jukebox.
hi Stephen.
if you go to this link you will see on the right hand side of the page where you might be able to get one from.or you could try ebay.
where to buy stylus for 463 rockola jukebox Google Search
Dec 01, 2017 | Audio Players & Recorders
Where can I hire a repairman to fix my Whirlitzer juke box?
go google and type in--- service agents for wurlitzer juke box ---
find and agent closest to you and call him on the phone
Dec 23, 2016 | Audio Players & Recorders
Jukebox manual
Many on eBay
http://www.ebay.com/itm/Original-Rockola-Jukebox-Model-488-Service-Manual-w-wiring-diagrams-/231244858100?pt=LH_DefaultDomain_0&hash=item35d74482f4 Original Rockola Jukebox Model 488 Service Manual wiring diagrams
Aug 05, 2014 | Collectibles Jukeboxes Book Rockola...
What causes a Rockola jukebox not to index?
I might be wrong about this but check inside for a switch marked Scan/off/play inside at the front of the mech. It should be in play position. Also check any circuit breakers and reset them on the upper back of the machine (inside). They look like the clicky end of a ball point pen.
After that I am stuck.
May 16, 2014 | Neonetics Rockola Jukebox Neon Clock
Rockola jukebox keypad doesnt work
If the whole panel is out it sounds like a missing or bad ribbon cable. start there and tell us what happens.
Nov 21, 2013 | Neonetics Rockola Jukebox Neon Clock
Been given a grade 5 Rockola 160 433, need a copy of the service manual
Contact the folks at www.victoryglass.com and tell them the make and model of your jukebox. They will have the manual set for around $50. Also, they bought out the entire Rockola factory parts inventory. So if by chance you needed Rockola parts, they would have it.
Aug 05, 2013 | Wurlitzer Rock-ola Jukebox
My Jukebox, when I place a cd in to play, it says CD read and does nothing else?
If the battery in the cpu is dead, it may cause this. First, check and replace the battery if necessary, then you will need to initialize or map all the cd's. It depends on what manufacturer of the jukebox is, (Rowe, Rockola, Wurlitzer) as to the procedure, but, a manual will be very helpful.
Mar 12, 2013 | Wurlitzer Jukebox CD Player
How do you set the Rockola 480 to free play?
For free play on Rock-Ola 480. Open your jukebox, on the right,you will see a large metal box marked Profit Setter. In this box are Sections A, B and D. In section D, you will see very small white buttons on a pink background. Push ALL of the buttons in section D to the left with a pen.It will play for free until changed. For money, put it back like it was. It will also play all songs automatically. If you wanna know that, e-mail to varnett1@woh.rr.com
Dec 16, 2009 | Vintage Jukebox External Speakers Shelf...
CAN I PROGAM MY JUKEBOX TO PLAY FOR 8HRS EVERY DAY ?
Yes. You need to set the time correctly then set the background music to play for 8 hours starting at a specific time. The background music only uses the top 20 CDs of the 120.
Dec 04, 2009 | Wurlitzer Jukebox Princess 120-Disc CD...
272 people viewed this question
 Grubhead
Grubhead
