Question about Amana NDE2330AY Electric Dryer
My dryer will work fine for a while, then it stops working; after a while it cools-off and then it works again. any body knows why is this is happening? Brand : Amana Model: le8217w2
  • glca May 18, 2009
    Its the motor overload protector........don't know if the motor is starting to fail?
    Scholar:
  • 85 Answers
Sounds like motor is overheating. You can try cleaning and lubricating the motor but it is likely worn out. Hope this helps!
Posted on May 18, 2009
What causes my dryer to stop after 20 minutes?
Sounds like a possible motor over heating. The main motor has a heat safety built in that shuts it off if it gets too hot. It will restart once it cools off some. Over heating could be from excessive lint around the motor or even from a blocked vent pipe. All you can do is clean it well and check again. If it still shuts off the motor will need replaced.
Jun 03, 2015 | Dryers
Refrigerator stopped working - working on repair #4
I hope all that was covered under warranty, otherwise they are playing you and your wallet for fools. Sure sounds like a refrigerant leak to me.
Oct 14, 2014 | Refrigerators
Dryer trips every time turn on but when turn on "air only" work fine.
I would stop using the dryer immediately and get the problem look at: this indicates that a 'live' wire is making contact with your earth connection (which include the whole dryer metallic body) and causing your electrical breaker to trip.
In your case, the heating element might be faulty (possibly the insulation) and causing this 'short-circuit': very dangerous situation! Leaking water in the dryer can also cause this situation ... again a dangerous situation!
Sep 22, 2011 | Dryers
I have a Maytag Neptune model number MDG9700A gas dryer...When I first turn the dryer on the dryer will get hot for about minute then the gas turns off and will not heat up again...It glows fine after...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 01, 2011 | Maytag Neptune MDG9700A Gas Dryer
The dryer was working fine and then made a noise and stopped. It will no longer run when you hit start. The lights work so there is no power problem. There is no motor noise. Are there any other possible...
My dryer stops itself when it gets a bit hot in the motor after it has been going for a long time...then after it has cooled down it starts up again...there could be a build up of fluff around the motor?
Aug 19, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer was not heating up yesterday ...but working this morning ???? second time this has happened ....
you have bad gas coils.when the coils are starting to fail they work until they heat up and then stop working until they cool down and then they will work again,the dryer will work correctly for the first 15 to 30 minutes,then the coils will heat up and stop working not allowing the gas to come in, the gas coils are on top of the gas valve,remove the two phillips screws,remove the cover and change out the coils,easy repair.let me know how you make out.also next time you need help send the model number so whoever is helping you they can look up your machine.
Jul 02, 2010 | Kenmore 73952 Gas Dryer
Hi i have a whirpool gas dryer that all works fine but after about five minutes the heat will stop and it will just blow cool air. I can stop it and restart and everything starts and works fine and after...
The gas valve coils are closing the valve or the flame sensor is defective. The coils are the most common problem.
There are 2 on top of the gas valve. Turn off the gas and power. Remove the front panel by opening the top lid and then remove the screws from inside the front panel in the top right and left corners.
Nov 09, 2009 | Whirlpool Dryers
Dryers stopped working during cycle
My dryer stopped working during a cycle last night and won't start again. The light is no longer coming on either. The first thing I checked was the circuit breaker which was fine. Can anyone tell me other possibilities? What is the anser
Jul 17, 2009 | Magic Chef CYE4000AWW Electric Dryer
GE- GTS22WC refrigerator. Both the refrigerator and the freezer stopped cooling, We put it in the basement thinking it was no good, and after a few months we plugged it back in and it worked ok for about...
The auto defrost heat element is not working. When the ice buildup clogs the airflow the unit stops cooling. Once you unplug it and give it a chance to melt it works again. You need to have the defrost unit replaced.
Jun 27, 2009 | GE GTS22KBP Top Freezer Refrigerator
Amana NDE2330AY Electric Dryer Logo
243 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
