Question about HP Designjet 4500 Pass-Through Scanner
HP Designjet 4500 Scanner error 55-203,55-205. Appears at calibration at alignment of chambers
  • Leo martin Mar 21, 2013
    ** Thanks it worked ** I think you need to reinstall printer driver again, uninstall by REVO UNINSTALLER then reinstall the drivers again.http://printer-driver-download.us/tag/hp...
    Problem Solver:
  • 5 Answers
55-203
Problem:
No movement in camera position has been detected during vertical camera
alignment.
Possible Solutions:
Check all the cables connected to the Camera.
Run the scanner maintenance program.
Posted on Aug 18, 2009
  • david midence galo
    david midence galo Mar 06, 2014
    whats is the scanner maintenance program
How can I fix a paper jam?
Open the scanner and remove the jammed paper.
Oct 12, 2014 | HP Designjet 4500 Pass-Through Scanner
HP Designjet 500, I have replaced the black print head twice, the first new print head would align and then fail the color calibration, the second new head aligns and pass's color calibration, but when I...
it seems there r some air in ur ink tube *** inser the priming heads & done the priming & reinstall the print heads if problem not resolved replace the carridge assembly,,,,,,,,,
Jun 03, 2010 | HP DesignJet 500ps (42 in.) InkJet Printer
My 3330 says scanner bulb is warming up then it gives me a error 79 message no ,matter how many times i restart it
The error 79 on that machine means that the scanner assembly has failed to align/calibrate. Could be due to a bad calibration strip on the scanner glass, have you ever sprayed glass cleaner directly onto the scanner glass? If so this can stain the calibration strip and render the scanner useless. It is probably best to have the machine serviced by HP.
Feb 05, 2010 | HP LaserJet 3330 All-In-One Printer
I am getting a system error 0C003200000003 HP designjet 1050C
System Error: 0C0032 (Continuable)
Problem
Description:
Drop Detector not Calibrated for all Printheads.
Corrective Action: Try the following:
n Perform the Service Station Calibration þ
n Replace the Drop Detector Assembly þ
n If the Error Code continues, replace the Electronics Module þ
WARNING Only replace one component at a time and check if the error has
gone before replacing another component. Using this procedure
you will be able to determine exactly which component failed
this is a continuable error.
Sep 25, 2009 | HP DesignJet 1050c InkJet Printer
Wat is 93.11 error
93.11 is a air pressure failure in a ink cartridge, you need to replace it to fix it
Jun 20, 2009 | HP Designjet 4500 Pass-Through Scanner
Deleted files -how to recover?
www.recuva.com ... it's a freeware program but works well recovering deleted files.
Robert
Please take a moment to rate this solution thanks
Jan 30, 2009 | HP Designjet 4500 Pass-Through Scanner
01.0:10 error on HP DesingJet 4500ps.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | HP Designjet 4500 Pass-Through Scanner
Error code 93:11
System Error: 93:11
Description: Unable to pressurize the IDS.
Remove ALL the Ink Cartridges and reinstall them one by one in to the Printer.
Replace the Ink Cartridges.
Replace the APS Assembly.
If the System Error continues, replace the Ink Supply Tubes and Trailing Cable.
Dec 29, 2008 | HP Designjet 4500 Pass-Through Scanner
HP Designjet 4500 Pass-Through Scanner Logo
1,377 people viewed this question
Seeker5211
Seeker5211
