Question about ASUS Computers & Internet
Asus gx74sx overheats when charging battery
Runs fine without battery on ac, or with battery but no ac plugged in.
SOURCE: Dead laptop
where is reset button
Posted on Jan 18, 2008
Pyrhyc
  • 2028 Answers
SOURCE: dell d620 will not go into charge mode
This is usually caused by a bad battery. Sounds like both batteries are not working properly. They may still hold some charge, but they are wearing out. After all, they are batteries, and bateries wear out. Keep in mind that some batteries are better than others, even though they may be the same brand, some will hold a charge longer, and some wear out faster. I'm on my second new battery in a year and a half on my Dell, the first held a great charge but wore out after approx 8 months, the one I'm using now still charges fine but only last about an hour and 15 mins.
Posted on Jun 21, 2008
ramon49
  • 111 Answers
SOURCE: My internal battery will not charge
90% of the time the battery is bad. No quick fix, other than test the battery or replace.
please rate
Posted on Mar 26, 2009
  • 8 Answers
SOURCE: hp compaq nx9110 runs only on battery when it is plugged to AC
It sounds like you have a faulty power jack, and possibly a dead battery as well. You should take it to a person you may know that can order and solder a new one in or take it to your local electronics repair shop. I do repairs like this on a daily basis for my computer business.
Posted on Apr 28, 2009
SOURCE: Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Posted on Jan 09, 2010
Asus a3a laptop
Probably the AC Adapter is no good....Go to e-bay and purchase a new AC Adapter for that model # notebook. But if it shows charging then try first by taking out the battery and see if the AC adapter will run the computer without the battery in it (if so, then the adapter is good, the battery is actually bad, so replace the battery instead).
Good Luck.
Nov 29, 2013 | ASUS A3Ac Notebook
Asus ASUS A53U-ES21 wont power on
In order for the AC adapter to work the battery must be in good condition, why? Because the system runs of battery the AC adapter just keeps the battery charged up while in use, if the battery is open or defective the computer will not run on just the AC adapter.
Jul 12, 2012 | ASUS Computers & Internet
Asus1000ha flashes between AC Mode and Battery Mode
Based on your explanation I will try to answer your problem.
It seems you have a problem with charger regulator. When you plug your charger into AC outlet then this regulator will detect the current that flows through voltage sensor then the Vreg pole will command the regulator to open charging circuit.
In plain English: Your computer has a problem with power regulator IC which located near the battery poles.
Aug 11, 2017 | ASUS Eee 1000HA PC Notebook
NEW Battery not properly charging
Batteries have electronics data that software has to get to properly charge it. Newer lithium batteries maybe different. But apparently, you have a work around for a lengthy use of the new battery.
Feb 16, 2012 | Gateway MD7818u Notebook
Computer is not charging the battery.
Your DC connector is probably loose from the system board:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Jan 05, 2011 | ASUS F8Sn-C1 PC Notebook
I bought a asus refurbished laptop, what should I do about charging a battery,charge it for eight hours without turning on the laptop??
A battery will charge as you use it . Go aheead and plug it in go about your laptop use as normal it does not need be off to charge the laptop any faster
Its using AC power to run and will still charge the battery
IF it does nto charge in a few hours it could be a weak battery
Try this first beofe you bring it to a service shop EBAY sells every type of battery ever made & Cheap too ! but check for warranty in EBAY bought battery look for return 100 percent guarantee on battery sales
Jun 15, 2010 | ASUS Computers & Internet
My eee pc wont recognize that it is plugged in.
Usualy this is a battery fault.
If the laptop remains on ac mode without battery try to replace the battery.
Mar 09, 2010 | ASUS Eee PC 1000H Netbook
Thbattery does not charge.I have installed a new
you can try 2 things
1st option
If you get this message that "Plugging, Not charging", don't worry. it may be cause inconvenient removing your battery, well:
1- remove your battery
2- directly connect AC adapter
3- restart or on your laptop
4- after loading windows, put the battery
enjoy...
if it not work, you must flash your BIOS or upgrade to new version can find from your manufacturer company website.
2nd option
Take battery out and use pencil erases to gently clean the contacts. Also clean contacts on laptop battery box.
Sometimes the contacts oxidize.
Then put back in and see if it charges.
Jan 13, 2010 | ASUS Computers & Internet
Laptop battery not charging wanna know how to run without battery
The problem you described here shows that, the case is not likely to be a battery problem, but the laptop AC-Adapter (Charger) problem, because, the red light you are seeing shows that your battery has rundown, and even when you plug-in the adapter to AC, it still blinks red, showing that the AC-Power is not charging it. I would suggest that you get another Laptop AC-Adapter (The Charger), or try it with a friend's own first, then you'll see that the problem might not be with your battery but your AC-Adapter
Jul 09, 2009 | ASUS Computers & Internet
Can i run the laptop without a battery in it.plugged in with ac adaptor only
Yes, you can.
Laptops can run without battery with the AC, and it's fine, does not harm.
But however, I do not recommend you removing the battery and using the notebook with AC adapter only. The notebook is designed to be portable and with battery plugged in. In addition, using AC adapter only may cause the system to overheat since it is getting and using direct power from the power outlet.
Sometimes when you take out the battery your laptop doesn't work.
But that issue usually is related with some problem with the connectors of your motherboard.
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Oct 17, 2008 | Dell Inspiron 2200 Notebook
Computers & Internet Logo
15 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
