Question about Acer PH110 Multimedia Projector
Projector won't turn on
Hi my Acer PH1100 has not been used and kept in a secure place for a couple of years, now when you turn it on the blue light flashes and it sounds like it's about to warm up but then it powers off and the blue light keeps flashing??? help please
2 Suggested Answers
  • 23 Answers
SOURCE: When I tried to switch
Ordinarily my first thought would be that the lamp is needing replacement. But if it's brand new, the lamp should be OK. Can you open the lamp compartment to see if it was broken during transit, or perhaps it's not fully seated properly. If it's a broken lamp, then I would contact the dealer you purchased it from, or contact the manufacturer directly to have it replaced. Also, is the noise loud and unusual, or just the normal sound of a projector coming on? If it's very loud, it could be the fan motor. Check that the fan is blowing. If the fan is the problem, the projector will shut down to protect itself from overheating. That, too, should be covered under the waranty.
Posted on Jan 13, 2011
Testimonial: "Thx for help"
Acer projector blue light blinks and fan blows and no picture
As far as I can tell this looks like a lamp problem. Unless some of the fans are not able to cycle up tehn it would shut down before it overheats
Feb 14, 2014 | Acer H5360 3D Video Projector 3D
Acer 1161P LED light flashes red and blue at the same time and the lamp is off
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Oct 14, 2013 | Acer Projectors
Blue power light frozen, projector won't turn on
Page 47 has nothing to do with this problem! Thanks for wasting minutes of my life
Nov 28, 2012 | ViewSonic PJD6211 Projector
Acer P1265 projector asking for password
Security
This projector provides a useful security function for the
administrator to manage usage of the projector .
Press to change the "Security" setting. If the security function
is enabled, your must enter the "Administrator Password" first
before changing the security settings.
• Select "On" to enable the security function. The user has to
enter a password to operate the projector. Please refer to the
"User Password" section for details.
• If "Off" is selected, then the user can turn on the projector
without password.
Feb 06, 2012 | Acer P1265 DLP Projector
Recently, out of the blue, my HC1600 projector has been failing to project any image. It makes a clicking noise...then stops...makes another clicking noise and proceeds to flash a green and (stationary)...
Probably a power supply problem. Most likely, there is a power transistor or relay that is not properly powering the light or other equipment. Check the warranty on the device, get a new one if you can. It won't be easy to fix.
May 03, 2011 | Mitsubishi HC1600 Projector
Acer P3250 will not acccept password...
I found a solution that worked for me:
1. Turn on the projector
2. Press "Power > Left > Left > MENU" (Opens the system menu)
3. Choose "RD Menu"
4. Choose " EEPROM Restore" (the projector turn off and the power lamp blink red for about 1 minut. Then it stops)
5. Turn on the projector again and it should work again
Sep 15, 2009 | Acer Office Equipment & Supplies
My Acer Aspire 5920 won t turn on The battery light blinks but it is plugged up
try pressing on fn+f5 or fn+f6 a couple of times each. Maybe the screen got switched to projector status by mistake.
Jan 07, 2009 | Acer Aspire 5920-6727 Notebook
Color alignment is off
i also have the exact same problem. i picked up 3 of these used for my work and kept one at home. I knew one had issues and another had a burned out bulb and so on. I had a repair place to combine the two to make one good one. The repair man said that they had a real hard time keeping the color locked in alignment. It's not a physical alignment, its controlled by the board output and somehow the board can be adjusted. It was vague to me. After about a good couple of years of hard use the one at home is now doing the same. On one hand I want to fix it but I dont even have a plasma so I may go and spend $800-$1000 on a hi def DLP. At that price it won't be the best but it will rock this projector. that would be my advice rather than putting more money into this old model.
Aug 06, 2007 | Philips ProScreen 4600 Impact Multimedia...
Acer PH110 Multimedia Projector Logo
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
