Question about Channellock Channel Lock 4v Dual Driver
Manual download drill
Cannot change bits
  • 3 Answers
"Manual download drill" - Please rephrase /clarify
"Cannot change bits" - More information needed.
Posted on Nov 28, 2014
Drill bit(masonry) wobble when test it.but it locks but just loose side ways.tnx
Try download once more. If there is any bit loss happened during download; this kind of error display might happen.
Jul 05, 2015 | Drills
Dewalt instruction manual
The black thing at the end is the "keyless chuck". Grasp it just behind the silvery tip of the chuck with one hand, and grasp the knurled ring just behind THAT area with the other hand. Twist the "front" hand counterclockwise while you twise the "rear" hand clockwise. That will loosen the chuck so you can change bits.
Aug 06, 2014 | Dewalt Dc987k2 Xrp 18volt 12 Drilldriver...
I dont know how to change the drillbit in my dw257 corded drill
Do you mean the Dewalt DW257 drywall screwdriver? For that model, you need to pull the adjustment collar forward. (This part fits over the drill bit to the clutch housing.) Remove the collar completely. Then using pliers, if needed, pull the drill bit tip out of the holder. Then put a new tip into the holder. Then snap the adjustment collar back over the retaining ring. See Figure 3 on page 2 of the manual (see below for a link) to see what the adjustment collar looks like.
If you want to replace the bit holder and the drill bit tip, pull the holder straight out from the drill. (Again use pliers if it is tight.) Then push a new bit holder into the spindle until the ball lock snaps into the groove of the bit holder shank. Put in the bit tip. Then put the adjustment collar on and make sure it snaps into the retaining ring.
These are the directions for the Type 3 DW257. The manual is available here: http://servicenet.dewalt.com/Products/Detail?isId=true&productNumber=DW257&selectedType=6793# . From the Product Information tab, select your model type and the instruction manual will be shown in the right hand column, if it is available. The manual is available as a PDF; you will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Oct 04, 2013 | Compaq Presario SR1030NX (DW256A#ABA) PC...
Changing Bit
where the bit goes into the drill there is a metal ring. Pull the metal ring away from the drill with one hand and pull the bit out. this model you may have to pull the meteal ring twards the body of the drill.
Feb 26, 2010 | Makita 9.6v Cordless Impact Driver 6903VD
Changing drill bits
If its a three jaw chuck l must either have knurled diameter across two parts just behind where the bit fits if so then twist the two parts in opposite directions.
Otherwise if there is a small hole near a circular rack then you will need the appropriate sized chuck key which will do the same job.
Hope this helps.
Oct 05, 2009 | Drills
I have a Bosch PSR12 12V Cordless drill, but no instructions.
This drill has a keyless chuck. Put your bit in the chuck and hold the collar of the chuck while pressing the trigger in the forward position. To undo the chuck do this in reverse. You can also hand tighten the keyless chuck if you prefer. I have a 1/4' adapter that I keep in my drill so I can change bits quickly.
Sep 09, 2009 | Bosch Drills
Keyless Chuck how do you change the bit? Model
hold outside collar on chuck firmly with your hand and reverse drill
Jul 10, 2009 | Black & Decker 3/8" Variable Speed...
Black & Decker model 4300 manual
Here's a link to a downloadable .pdf manual for your sharpener that will give you pages and pages of instructions to make those dull bits history.
Enjoy!
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 14, 2009 | Drills
How to Remove Bit from Dewalt Quick Connect Adapter DW0521
Hold the chuck by its sleeve, put the drill in reverse (make sure it's set at high torque if you used it in a drill/driver) and go full speed. That should release the bit.
Jan 04, 2009 | Dewalt DW0521 Quick Connect Impact Driver...
Channellock Channel Lock 4v Dual Driver Logo
810 people viewed this question
Top Channellock Drills Experts
Are you a Channellock Drill Expert? Answer questions, earn points and help others
