Question about Epson STYLUS R230 InkJet Photo Printer
I have 2 Epson R230. One has a bad printhead, in that the test print is messy and the black print head is badly clogged. I want to swap the printheads, so that I will at least have one working printer. The one with the good printhead cannot recognise the cartridges - I've been unable to find any solution for this; so I'm going to remove this printhead and put it into the other R230. Finally, I'm going to toss the printer without the printhead through Epson's window!
  • 3 Answers
Befory you toss the printer, try this!
Take a syringe, 1" piece of rubber tubbing that will fit over the head input snugly, (auto parts house stocks some that works fine). Fill the syringe with a good head cleaner, slightly warm it in the microwave (try 5 seconds to start). Attach to nozzle, gently pull back just a bit, then apply a little pressure. If it accepts the fluid, STOP, You can clean the syringe, add the proper color ink, inject just a small amount. reinstall a known good cartridge, clean heads couple times checking results, if ANY streaks or color appears, clean again! Sometimes letting it sit overnight allows the head to fill with ink. I have had very good luck with this method, also some will not clean properly, just depends on how bad it is clogged.
Good luck..
Posted on Sep 21, 2009
R230 epson color
The cartridge head may have gotten clogged. Take the cartridge out and clean the head with a damp cloth and print a couple of pages to set this right.
Also, print a test page to make sure the ink hasn't dried up. If it has, you will have to get a new cartridge.
Aug 12, 2014 | Epson STYLUS R230 InkJet Photo Printer
Epson xp 305 help
It's quite likely that at some point in time you will have attempted to print in black only to receive an error message that you cannot print until a colour cartridge is replaced.
"If ink is not in the tubes from the head to the cartridge, air will be sucked in and therefore cause damage to the print head. This is because the nozzles are in the print head and not in the cartridge. "
What Epson are basically saying is... if this safeguard was not in place, and you sent a print request for black when a colour cartridge was empty, there is a risk of air being pulled into the printhead. This air will ruin the vacuum effect needed for the printhead to pull ink in, meaning your printhead would be at risk of never printing again.
Additionally, if any air is allowed go get into the aformentioned tubes from the head to the cartridge, any remaining ink will coagulate. Just in case you're not a scientist - coagulation in a tube/cartridge is bad, and will lead to you not being able to print again with that cartridge, or to a blocked nozzle/printhead which will require a significant amount of cleaning cycles to budge.
Aug 08, 2014 | Epson Expression XP-305 Inkjet...
Baddly blocked printheads on px700w
I have found some rubbing alcohol on a paper towel, set on top of the print heads will sometimes loosen the grunge. If I recall you can remove the print head assembly on an Epson, so you might try soaking it in a bowl of rubbing alcohol. Make sure you fully dry the print head before placing it back in use. Run your cleaning option a couple of times to recharge the head after cleaning.
Feb 23, 2012 | Epson Stylus Office Equipment & Supplies
I have an Epson Workforce 600 printer that won't print black ink. I have replace all the cartriges with new and still no black ink. I've done nozzle clean several times. Only a very faint line on test...
You may have to clean your HEADS. I found this on the Web. Hopefully this will help. Pls rate me.
Good Luck
Found this on the Web:
http://www.fixyourownprinter.com/forums/inkjet/14116
Epson Stylus Head Cleaning Solution Plus
Re: Epson printer problem
You will want to press the button that you use to change the ink cartridge (the 3rd button). Once the carriage is in the "cartridge change position" you can unplug the printer. Then you are ready to flush out the heads. Click here for cleaning instructions http://www.wesesweb.web1000.com/printhead.html
The instructions are fairly easy to follow. If you need the head cleaning solution click here .http://www.fixyourownprinter.com/kea0.html
Repairs: All Epson Stylus printers (except for the C64-C86, CX4600-CX6400 series) which don't print, or print choppy in black or color. For the other printers, as well as Canon BJCs, use the other repair kit.
Description:
  • This is the same chemical used by Epson in their service department
  • Easy to use, no disassembly required
  • Gently dissolves even the most stubborn clogs and restores output to dried out print nozzles and clogged printheads
  • In our testing on an Epson 600 that sat unused for several months, it 100% restored a head that had no output, with one application (Individual results may vary)
Note: This is not alcohol or Windex; it is an ink-specific solvent that has proven to be safe and effective for use on Epson printheads. Do not use alcohol or Windex, they will very likely ruin your printer.
Kit Includes:
  • 1 oz bottle Epson Stylus Head Cleaning Solution (enough to fix several printers)
  • 1 syringe applicator for dispensing solution
  • Simple directions for use
Price: $9.99 order form on link below
http://www.fixyourownprinter.com/kits/Epson/K89
Feb 25, 2010 | Epson WorkForce 600 All-In-One InkJet...
MY PROBLEM IS MY 230 PRINTER VERTICAL PRINT IS NOT
I have problem while printing colour photos and I would like to know how to print back to back i.e. even and odd pages
Jun 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
Printhead error
Print out empty? Normal run? replace print head? If no mistake installed print head, the problem at board, or may be just lost electricity.
Jun 07, 2009 | Epson STYLUS R230 InkJet Photo Printer
Blank paper print in R230
try checking the pump assembly of the unit. if it is clogged, the printhead wont clean and theres a possiblility that you will not get a printout. also check the head cable to see if there are no cut traces.
Feb 18, 2009 | Epson Stylus Photo R220 InkJet Printer
Problem on print out!!!!
How were you trying to clear the printhead? Depending on the printer, you may want to put a warm wet paper towel under the print nozzles and leave there for a while to loosen up any dried ink in the nozzzles.
Oct 29, 2008 | Epson Stylus Photo R220 InkJet Printer
The printer is not recognising cyan ink cartidge CLI-BC even though it is full
Try doing a nozzle check to see which colors are getting through the printhead. If you are missing lines in the pattern or there is no ink color showing, you will have to do a head cleaning. Was your printer out of ink for any length of time? If so, it is a clogged printhead. some printers are designed in a way that will not allow you to print at all, if you are out of a color. They do this for a specific reason- If you were allowed to print in black and you were out of yellow and you did this for a month and then replaced the yellow, you would have a clogged printhead. Why? Because there is a reservoir in the print head and if you do not replace the ink, after a while, the ink in the reservoir will dry out and you will have a clogged printhead. The only way to fix this is to do a head cleaning (2-3-4, depending on how bad the clog is) and that uses a lot of ink. So, Epson does not allow you to print if one color is out, to save you the time and expense of having to do a head cleaning.
Did you remember to take the tape off the top of the cartridge? If so, run a few cleanings and do a nozzle check. If there is still no cyan, your print heads may be clogged
Aug 05, 2008 | Canon Office Equipment & Supplies
Epson Stylus R230 Light Magenta Not working
Print first a nozzle check pattern, self test which they say. Check your manual for your printer, it should be accessible from that if you dont have any manual, go to the epson website and download a manual. Usually the self test would go like this.
While the printer is turned off, you press and hold down the paper feed button, continue holding it down while turning on the printer. It will print the nozzle check pattern standalone. If you see all the colors then the issue your having is a color management issue, if you do not see the cyan, magenta, yellow, black, light magenta and light cyan from that test; then you will need to do 3 consecutive times of Head Cleaning from the maintenance program in your computer. If you have a windows xp it goes like this.
Click on start go to control panel - printers and faxes -
you right click on your printer icon and select printing prefrences. From there, go to maintenance tab and click head cleaning, go through that cycle 3 consecutive times and see if it improved. Good luck....
Jun 12, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson STYLUS R230 InkJet Photo Printer Logo
1,045 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
