Question about Janam XG105 Barcode Scanner
Scanner stopped working - Janam XG105 Barcode Scanner
If the cartridges are missing will that stop the scanner from lighting up
You didn't give a brand or model of your all-in-one, but I'm going to assume it's one of the common brands. They're all pretty much the same. If the printer doesn't work, the scanner can't be used. So if the printer has no cartridges, it very likely will stop the scanner too. There's no way to use the all-in-one just as a scanner when the printer doesn't work.
Jan 23, 2011 | Computers & Internet
Scanner stopped working. Only one light is on on
you will probably have to get another scanner or have the lights replaced
Apr 08, 2010 | Metrologic Instruments 9520 Voyager
My HP scanner stopped working. THe light appears
Not worth fixing. The bulb is wearing out and you can't buy them.
Dec 20, 2009 | HP Scanjet 4570cxi Flatbed Scanner
I have two uniden scanners (BCT 8) and both have stopped working. On checking we know all scanners in the Reno NV area have stopped working on the trunking system EDCAS - any suggestions as to what it may...
Your EDACS system may have switched on the ProVoice security system. If so, NO scanner will pick up their trunked transmissions. For more information/research on the EDACS system in your area, I suggest you visit www.RadioReference.com
Dec 06, 2009 | Uniden Radio Communications
Scanner won't scan red ribbon
metrologic ms3780 scanner only scans a few times then stops..when you remove it from the base and reinstall it it works afew times then stops again?
Jan 02, 2009 | Eclipse Metrologic MS5145 Barcode Scanner
Making strange noises and stopped working
It sounds like a broken mechanic part problem. You need to bring it to an authorized repair shop.
Nov 26, 2008 | Canon CanoScan 9950F Flatbed Scanner
Scanner has stopped working
When I had the cable that came with the printer connected to the scanner, and the cable that came with the scanner connected to the printer, the scanner didn't work.
Changing the cables changed everything.
Oct 15, 2007 | Canon CanoScan LiDE 70 Flatbed Scanner
Janam XG105 Barcode Scanner Logo
37 people viewed this question
Top Janam Computers & Internet Experts
David Payne
David Payne
Are you a Janam Computer and Internet Expert? Answer questions, earn points and help others
