HI, the F-2 is signaling a higher than normal oven temperature. Follow these steps bellow.
1. Look for welded
relay contacts on bake or broil relays. If this happens, replace oven
control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation. If the door lock device is not working properly, replace.
3. Look for a high
resistance connection or any other cause of high resistance in the oven
temperature sensor circuit. Check sensor, sensor harness and sensor
harness connection at sensor and oven control. Replace sensor if found
defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
Was this helpful?
Yes
No
Popular Solutions for Whirlpool RBS305PDS Electric
I hate my accubake oven. It has never held a oven temp for more then five minutes. Tech has been out...
(More)
I hate my accubake oven. It has never held a oven temp for more then five minutes. Tech has been out here once, calibrated thermostat 10 degrees, yet it took 1 hour to broil pork chops since temp was 200 degrees. I bake twice a week and have never had a item come out not burnt on the outside and dough in the middle. Do Not Buy this Stove, dealer is not receptive at all, poor service, I want a new stove now....this one was purchased Dec 2008!
start button on whirlpool electr built in oven won't work. Just beeps but does not turn oven on....
(More)
start button on whirlpool electr built in oven won't work. Just beeps but does not turn oven on. Model # RBS27PDB4 Cass
My whirlpool accubake built in oven RBS275PBD84 won't start. If you press start it beeps a few times...
(More)
My whirlpool accubake built in oven RBS275PBD84 won't start. If you press start it beeps a few times but nothing! One other button (minutes up) to set timer does not work. Any ideas?
My oven light doesnt turn off and when I try to turn to bake or clean it says door in red as though...
(More)
My oven light doesnt turn off and when I try to turn to bake or clean it says door in red as though it is not closed however it is closed and wont turn on.
The inner glass of my Whirlpool oven ( model RBS305PDS16) broke. I purchased the glass and removed...
(More)
The inner glass of my Whirlpool oven ( model RBS305PDS16) broke. I purchased the glass and removed the door. I have taken the door a part and would like instructions on the proper way to reinstall the glass. Can you help, please....
