Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Possible lid switch stopping basket from spinning
How does faulty lid switch stop basket from spinning
  • 1 more comment
  • korgone May 21, 2009
    my problem was that when spin time comes , I can hear and feel
    the motor running and hear the water running out ,but when I open
    the lid , I find that the tub has not turned , and i hear the motor
    slowing to a stop . when I close the lid , I hear the motor running
    again and I feel the tub turning . this is what I do each spin cycle .
    I open the lid then close it again and all is well .
    thanks a lot for your help . I'm a little disabled but as soon as I
    get a little help I will work on your advice .
  • korgone Jun 03, 2009
    thank you for giving me advice about my machine , but the 5 second
    thing does not seem to be happening . when we (me or my wife) hear
    the motor running at spin time , more than five seconds go by before we get to the machine ,and if left alone ,it will only go into the next mode , starting with a very wet pile of clothes . i wish it was the switch , its the easy fix .
  • korgone Jun 12, 2009
    thanks again for your advice , but I have not
    gotten anyone to help me move my machine . while
    waiting I thought about the five second timing .
    I was thinking that when the motor turned to
    spin the pump , it would also turn the tub .
    now I need to find a way to tell if the switch
    is faulty , or if the timer is faulty , but
    whenever I can I will try what you say .
    Scholar:
  • 85 Answers
Lid switch is safety mechanism that cuts off power to motor when lid is open. If it is broken or faulty you will not get power to motor during spin. Hope this helps!
Posted on May 18, 2009
  • 1 more comment
  • shinn8
    shinn8 May 21, 2009
    If it does start spinning after you lift lid and put it back down it is a problem in your timer. When it goes into spin cycle it pumps water out then the timer is supposed to pause the motor for 3-5 seconds to allow the transmission to shift into spin. If that is the case you will need a new timer.
  • shinn8
    shinn8 Jun 03, 2009
    Thats gonna be the timer
  • shinn8
    shinn8 Jun 12, 2009
    If when you lift the lid then put it back down it starts spinning then it is your timer for sure.
Sometime the wash cycle stops when the spin cycle should start.
From what you're describing it sounds like the lid switch is faulty. Open & close the lid slowly & listen carefully for the click of the lid switch. If you do not hear the lid switch, you will need to replace the lid switch. Other testing will require accessing the controls & using a meter to make some more checks with. If the motor is not running & the lid switch checks good I suspect the timer. If the motor is running in the spin cycle but the basket is not spinning I suspect the drive block, basket drive, transmission or clutch.
Mar 04, 2011 | Maytag MAV7200 Top Load Washer
Maytag top load washing machine 2 years old
This could be partly the clutch/break assy. You need to be able to run this with the lid open in the spin position. Activte the lid switch with a pencil or something. Reach in and hold the spin basket and then turn the washer on in spin. Hold this basket for 1-2 minutes then release it and let it reach full speed then stop the washer by turning the timer off or releasing the lid switch. See if the hard breaking/noise is better. Keep doing this untill it comes to a smooth stop and the noise is gone at the stop. Not sure this will cure the noise in the spin starting up problem or not, but start here. the clutch gets rust on the pads and this burnishes the break pads, removing this rust that makes it grab.
Goodluck..
Apr 05, 2008 | Washing Machines
Error on control panel "oL"
Hi
Error OL means that the washer has sensed an overload (OL) condition. It can also be a false error code appearing due to faulty lid switch. Sometimes this error code appears when lid is not closed/opened properly. You can check the lid switch for any disconnections, if the connection to lid switch is fine then use a multimeter to check the continuity of the lid switch. If the lid switch is fine then there is a piece of clothing stuck between inner basket and the outer tub. Disconnect the washer from the power outlet and then try moving the drum with your hand and check if it turns freely or is offering any resistance. If it is not moving freely then it is due to rusted drive shaft or motor. Hope this helps... Please post back if you need more assistance.
Daniel
Dec 15, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore model 80 washer will agitate but drum will not spin
Your basket drive/ clutch or the drive block may be bad . Can you hear the motor running during spin? Can you turn the drum by hand when it is stopped? I would also look for something stuck between the basket and the outer tub a sock or???? Stick a screwdriver in the lid switch slot so you can see what is going on with the lid open and see if basket will spin with a little help. Does it make any unusual noises?
Mar 19, 2010 | Kenmore Washing Machines
Washer wont spin
WASHER DON'T SPIN
normally if is filled with water an does not spin, check ur door switch may be bad or broken also check the lid make sure the smaill white tab is there too, the switch normally break when someone stands or slamms the lid hard or puts heavy baskets over the lid ,the switch mounting screws base is made out of plastic so is easy for it to split
the lid switch is a safety device that stops the machine while on spin cycle, in case you forgot your wallet u go back to get it stick ur hand in it, and is on spin cycle, as soon as u open the door, the door will deactivate the power tho the washer, and the basket will stop, when not going into spin mode is one of the main reasons
good luck leave some feedback!
Feb 01, 2010 | Washing Machines
Whirpool model GSQ9669LW1 basket does not spin after replacing the broken coupler between motor and transmission. Motor showed good continuity using volt-owm meter on ohms setting on low, medium, and high...
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Reviews@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 06, 2017 | Whirlpool Washing Machines
Motor comes on and water gos out but basket will not spin untill lid is opened then closed again . this is on all spin cycles .
HI, you will need to replace the lid pressure switch. it is faulty or the wires may be worn or lose.in most cases, it will be a faulty lid switch.
May 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Mar 10, 2009 | Kenmore Washing Machines
Roper washer frozen drive?
I would first check the lid switch and the plunger that pushes the lid switch. If both are good I would make sure the machine is washing properly. If the machine will not wash or spin you have a bad coupling. If the washer will wash then stop at the spin it is usually a bad lid switch, or transmission. The transmission will have a 5 year warranty. It is also possible that you have an object stuck under the main wash tub. You can remove the cabinet and look for objects or you can remove the wash basket itself. Good luck with your repair.
Mike
Sep 22, 2008 | Roper RAX7244KQ Top Load Washer
Washing machine stopped
try lifting the main top up and down and listen crefully do you hear any clicking just before the lid closes??? im assuming not, the lid switch sounds bad. wont drain or spin with a faulty lid switch
Mar 15, 2008 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
238 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
