Question about Watches
Dce 1828 FH battery replacement - Watches
Finding and replacing the battery on my Zodiac sea dragon Z02270
  • Remove back
  • Locate battery. Note mounting arrangement for later battery replacement
  • Obtain replacement battery
  • Install battery
  • Check operation
  • Install back
  • Set time, etc.
Oct 19, 2016 | Zodiac Watches
I can't find a replacement battery, I have 2 3
Go to "http://relicbrand.com/pdf/Service_Form.pdf" and you will find an order form with prices for repairs and battery replacement.
It may seem expensive for a replacement battery but if you see the number of people who can't get their watches to go after battery replacement, you wouldn't hesitate to send them off.
Mar 17, 2010 | Relic 0504648FA
When day changes on my luminox 1828, it changes to "DIE" instead of Sunday. Why?
I think your watch is set to German(?) not English.
Do you get "Sam" instead of "Sat" (Samstag is German for Saturday)
If you do not have instructions, go to the Luminox web site and contact them for help.
Mar 16, 2010 | Watches
I need the instructions for a Zeon Tech DCE 1878 FE Radio Controlled Clock
how do i keek the digital display on my zeon tech nil4770 fc
Nov 26, 2009 | Bulova Watch
How to replace battery in polar f4 watch
HOW TO REPLACE BATTERY IN MY POLAR TARGET WITH A TS1 TRANSMITTER
Nov 25, 2009 | Polar F4 Heart Rate Monitor Watch
The crown on my Luminox 8362 doesn't push and pull to set the watch? HELP!!! THANKS!!!
If it's like my Luminox 1828, the crown has to be unscrewed before it can be pulled out and worked like a regular crown. Just don't forget to screw it back down afterwards.
Oct 18, 2009 | Luminox Watches
How to replace battery for Timex expedition
Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
May 12, 2009 | Timex Expedition 84601 Wristwatch
Watch going in reverse
There is no difference in watch batteries as they are produced by the certain standards. That means you have replaced the right battery.
The simplest solution would be re-replacing the battery. Just take the battery out and leave the watch without battery for 5 minutes, then put the battery back. Make sure the battery is fitted the right way (the + side usually facing up).
If this doesn;t help - let me know.
Rate, please.
Mar 23, 2009 | Watches
Sekonda 3850 battery replacement
Hi, its Richard, after battery replacement before replacing watch back, there is a small hole in the movement near the edge if you look down it there is a metal plate at the bottom gently press this with a fine screwdriver, the display will then come on, it is a reset switch, regards Richard.
Aug 20, 2008 | Watches
Battery Replacement
I thought you are supposed to touch the neg side of the battery
Jun 01, 2008 | Casio DBC1501 Wrist Watch
Watches Logo
21 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
