Question about Miele 24 in. G692SC Plus SS Free-standing Dishwasher
Water fills washer, program stops, inlet/drain flashes. checked all filters and pumps for blockages. none found. try again and washer empties water, then fills up again, program stops, inlet/drain flashes again. could it be a fuse???
  • sbst May 21, 2009
    washer drains away to begin cycle and then as water begins ton flow in the inlet/outlet light begins to flash and the cycle stops.
  • 68 Answers
Could it be.Try to open and look the fuse inside.Opps try to see the warranty of applian.
Posted on May 18, 2009
The washer stops at 39 minutes on a regular wash cycle and the code OE is displayed
This fault code can mean that the pump is faulty as well as blocked, first of all check for a blockage and, if none is found then the likelihood is that the drain pump is faulty. Should you need it, the most common drain pump used on LG washers and washer dryers is this one.
On non-display panel models this fault code is denoted by the lights for 800, 500 and No Spin being lit or flashing.
  • Check pump filter is clear and there are no obstructions
  • Check the drain hose for obstruction
  • Check the drain hose is not kinked
  • Check the drain pump filter and clean if required
  • Check the air chamber and pressure sensor hose
  • Check drain pump, normal resistance is 152-175?
  • Check drain pump rotor
  • Check connections to water drain pump
Oct 09, 2015 | LG WM2701HV Washer
Tip
Asko W6021 would not fill with water
Our W6021 front has had a couple of instances where it would not start the fill cycle as usual. Normally it would be switched on,the relay would operate and the water would begin to enter the bowl. We tried a number of things including checking the hose and inlet filter for blockage. We then checked the outlet drain pump trap and found a coin and a drill bit lodged in the entry hole to the trap. Once the foreign objects were removed ,the machine operated as normal once again. I will be very careful in future to empty my pockets of metal things.
on Jun 15, 2007 | Asko W6021 Front Load Washer
Duets washer won't drain
Probably a blocked filter, outlet pipe or pump.
Take the drain hose and lay it flat and lower then the level of the drum and this will drain the machine providing the blockage is not solid. When machine is empty check filter , pipes and pump and remove any blockage found.
Replace drain hose and you should then be able to carry on with your wash or spin the clothes.
Dec 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Machine had been giving E20 error code - filter cleared and it re-started ok. When wash was in progress - jammed at rinse stage and all lights came on (except spin speeds) and humming noise and nothing...
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa
Oct 11, 2011 | Zanussi ZWD1470W Front Load Washer / Dryer
FH IS FLASHING ON THE WASHER AND IT HAD STOPPED WORKING ONLY 5 MNUTES INTO ITS CYCLE
The FH error code means the computer on the control board didnt detect any water entering the washer..sometimes it doesnt detect the water entering because the filter screens on the water inlet valve are clogged with sediment and water is having a hard time entering the washer.
The filter screens can be checked by turning off water at the faucets and disconnecting the fill hoses from the back of the machine and pop the scrrens out of where the hoses connect at the washer and check for blockage in them. If they are found to be clean check the water coming out of the hoses before connecting them back to the washer...if the screens are clean and water pressure is good out of the hoses the part of the washer called the FLOW METER would need to be replaced
GENE
Sep 11, 2011 | Maytag EPIC MFW9700S Front Load Washer
What is e20 mean
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 26, 2010 | Frigidaire GLTF2940ES Front Load Washer
I am getting a Code E20 on Zanussi Washer Dryer ZWD 1271W
Jun 17, 2009 | Washing Machines
E20 error on Kenmore front loader. The water is
Jun 07, 2009 | Kenmore 44072 Front Load Washer
Draining problem
u take your front panel off at the bottom then u should see the drain pump and drain filter remove the filter check for blockage if none pump will need replaced odds are u have your filter clogged with some change or sock
May 19, 2009 | Maytag EPIC MFW9700S Front Load Washer
Kenmore 3.5 Quiet Tumble
Nov 03, 2008 | Kenmore 43142 Front Load Washer
Miele 24 in. G692SC Plus SS Free-standing Dishwasher Logo
648 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
