Question about Dryers
Our dryer whirlpool awz8480 is heating for 8seconds. The heating elements and sensors are ok. Can anyone tell me what to do? Thank you very much. Leo
kachbibi1
  • 979 Answers
SOURCE: my dryer, whirlpool #wed5840swo stopped heating.
Does the drum turn? I know you have checked the breaker which can trip sometimes. There may be a small disc about the size of 7-8 stacked nickels that is actually a reset that is planted along in one of the lines. You can bypass it to see if it is the problem. If it is, then you can get a replacement at an appliance store. Make sure all your wiring is correct because you could be spending a lot of money for nothing. Was your old element actually bad(burned in 2)? This main thing I would want to know is if the drum turns or not. The other, probably not, problem could be in the control panel. If you are handy with an ohm meter, you can see if those parts are indeed O.K. You can call em at 803 463 5567 for clarification.
Posted on Jan 14, 2009
  • 659 Answers
SOURCE: whirlpool dryer not blowing hot air
The element is at the bottom of the unit. Usually they are located on the right bottom but when you take the housing off, you will be able to see it.
Posted on Apr 11, 2009
  • 38 Answers
SOURCE: I have no heat in my dryer. How can I tell if it
check for continuity on the heating elements leads.
Posted on Apr 16, 2010
  • 4 Answers
SOURCE: Whirlpool Cabrio - How do I tell if my heating
If you are comfortable useing a volt meter and a ohm meter I can walk you throught the steps otherwise you need to call a repairman, If you are not getting any heat and the tumbler is turning it is possible the element is bad again only a test meter can tell for sure or you can take the dryer apart and look at the element to see if it is broken make sure the power is turned off at the breaker first also unplug the dryer.
Posted on Apr 17, 2010
  • 24 Answers
SOURCE: replace heating element for Duet Dryer GEW9200LW1
First disconnect the power to the dryer by unplugging it from the wall. Then remove the 3 screws on the lower panel of the dryer. This should expose the heating element in a metal housing on the right side of the dryer. Disconnect the 2 wires going to the heating element and slide it out of the housing. The heating element part number is 3387747.
Posted on May 25, 2010
Whirlpool AWZ 7686 Tumble Dryer heater works for only 10seconds
Might want to check for an obstruction in the outlet of the exhaust
Well if you had mention that in the first place I wouldn't be asking you. No wonder your trying to fix the problem by yourself because with that attitude you can't get a technician to come out for service.
Sep 12, 2015 | Whirlpool Dryers
We have a dryer that works but does not heat
No heat indicates a burned out heating element.Easily replaced.Cant answer on timer.
Apr 08, 2012 | Whirlpool Dryers
My dryer element comes on when dryer is started. But it soon goes off and the dryer is still turning. The clothes do not get dry. What can it be?
HI,
Check vent hose for full volume outside.Restricted air will cause heat build up which cuts off the
element
Check Thermal fuse located on element case
Its probably one of these
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 23, 2011 | Whirlpool LER4634J Electric Dryer
The dryer works but there is no hot air. How can I tell if it is the heating unit or the heating sensor that is bad? Amana NDE7800AY
Ohm the heating element for continuity
There is a thermal cutoff at the top of the element case with 2 wires
Hook these two wires together for a check or ohm it for continuity. . The dryer should run. unless it is a more tech problem.Also check for 230 volt at the wall and at the service cord at the dryer. A dryer will run on 115 but it will not heat.
for more questions.
Leo Ponder
imufo2@sbcglobal.net
Jul 31, 2010 | Amana NDE7800AY Electric Dryer
NO HEAT
Hello there;
Normaly this problem is due to a heating element that has failed and needs to be replaced or there is a sensor for the heating element that can go bad too but not as likley as the element.
So i would recommed if you feel that you can do the repair your self
contact you local appliance dealer and tell them you need a heating element for you machine and they will be able to get you the right one.
You will save a lot of money by installing it your self if you have a repairman do this it will cost you around 100 dollars just for the service call and that is not including the 60 dollar part ok?
I hope that this has been very helpful for you
Best regards Michael
Nov 16, 2009 | Whirlpool GEW9250 Electric Dryer
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
NEW Electric Whirlpool Cabrio Steam Dryer; NO HEAT
Check temperature sensor.  Check to see if heating element is OK.
May 29, 2009 | Whirlpool GEW9250 Electric Dryer
How do you test dryer heating element on GEQ9800LW0
Ok maybe the heating element got old and brittle over time and finally gave up the ghost. But it may not be the element. It could be one of the safety Hi-limits have blown.READ MORE...
Apr 10, 2009 | Whirlpool GEQ9800L Electric Dryer
Whirlpool Duet Dryer is scorching clothes
there is a sensor in the exhaust line in the dryer, near the motor. this tells the heating element to shut off when it gets to a certain temp, either during reg cycle or if the exhaust gets clogged, it is meant as a safety measure, but it sounds like yours is bad so the heating element never shuts off. it is not an expensive part and easy to replace
Oct 27, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool Model LE7010XSNO. No Heat After Lint Cleaned Out
Those are likely possibilities. Also check the wiring for disconnected or burned terminals especially in areas that get hot. The element comes out easily to visually check it for breaks. If that's OK I'd look at the safety thermostat.
Jan 06, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
21 people viewed this question
Top Dryers Experts
