Question about Pioneer Vsx-1121-k 7.1 Home Theater Receiver, Glossy Black
HDMI out for pioneer vsx-1121-k not working
Cables / monitor confirmed to be fine. Receiver switches when hdmi input sources are powered on.
SOURCE: Receiver: Pioneer Elite 72TXV Verizon
Called Verizon automated help desk. They rebooted DVR remotely and solved the problem.
Posted on Mar 29, 2008
  • 4 Answers
SOURCE: HDMI Compatibility
It sounds to me like you have a HDMI Control issue. It sounds like the DVD player wants to control the receiver. Try turning off hdmi control on the TV, reciever, and the dvd player in their setup menus.
Let me know if this helped,
Joe
Posted on Jul 13, 2009
  • 6 Answers
SOURCE: I just bought a vsx-1019ah receiver. I connected
Check if your KuroLink is on or off. There are a lot of problems that users have been having with the KuroLink on. Since you have a Pioneer display, KuroLink might help in switching both the receiver and the display on and off together, but my advice to you would be play around with the settings (in your case, especially KuroLink). Also remember, the KuroLink is on by default i.e. if you've never changed this setting, it probably is on.
Hope this solution works, else check out the Official Thread on Pioneer VSX 1019 AH-K on avsforum. There are a lot of helpful people out there.
Posted on Dec 07, 2009
  • 6 Answers
SOURCE: I have a motorolla DSR505 sattelite receiver that
The DVI output usually transmits only video (I'm almost 90% sure about this). It would be better if you did not use the DVI to HDMI cable. Receivers and displays can be very picky when it comes to using HDMI. Your Motorola DSR505 has other output options on its rear. I would suggest using the Component out for video (the 3 outputs colored green, blue and red) and either an optical or coaxial for the audio. The Pioneer VSX 1019 AH-K has the required inputs. Of course, you would require new component and coaxial/optical cables to do the job.
Hope this helps. If you're still in a tangle, you can consult the Official Thread on the Pioneer VSX 1019 AH-K on avsforum. There are a lot of helpful people out there.
SOURCE: Pioneer VSX-72TXV used to work but trying HDMI just broke it...
I fixed it myself. Didn't realize that I loosened speaker cables on the wall panel when I moved the receiver and two were touching...
Posted on Dec 10, 2009
Pioneer VSX-1027-K receiver sound cuts out for a second or two a few times a minute. Just started happening with no new connections added to the receiver.
This is not a firmware problem. It is an HDMI cable problem. Disconnect everything and only connect one source at a time and see if that takes care of your problem. Try different combinations of inputs and cables with only one device. If you find that works then you have a bad jack or a bad cable. You wont always lose your signal totally with a bad cable.
May 16, 2016 | Pioneer Audio Players & Recorders
No sound out of the pioneer vsx-1121-k
Try removing all the speaker and the HDMI connections; then use a headphone to listen to music from the tuner or a CD in stereo mode. Better in direct mode. If you hear your music correctly the receiver could be working correctly. If no music is heard, you may need to have it repaired professionally.
If you can hear music, connect the main FL & FR speakers and verify you can hear music that way, without the headphone connected.
If you can hear music that way, connect the center and rears. Try a mode that uses all channels to verify all sound channels are working.
Then, and only then start adding your HDMI connections.
Good luck
Jan 19, 2015 | Pioneer Vsx-1121-k 7.1 Home Theater...
I have a pioneer VSX-822k receiver. My older Runco CL-710 projector with DVI will not display anything from the Pioneer's HDMI output. (using a monoprice HDMI to DVI cable designed for this) The sourc
it is not compatable with 1080p,it says so on pg 17 of the projector manual,This unit is compatible with the following computer resoultions: 1280x720, 1024x768, 800x600, 640x480,you cannot use it with the receiver unless you use rca cables http://www.projectorcentral.com/pdf/projector_manual_2126.pdf
VSX 822 5 1 Channel 3D Ready Receiver
Oct 18, 2014 | Audio Players & Recorders
Dec 10, 2009 | Pioneer VSX-72TXV Receiver
Recently purchased this reciever, and in reading the manual, I cannot tell if it will work if I hook my Comcast HDMI to one of the HDMI inputs (Input 2)? In general, i will be only hooking up the Cable box...
It should work fine. The Pioneer VSX 1019 AH-K has been made so that it can accept 4 HDMI inputs (of which 3 are assignable, and 1 is for the BD player)
If you still have a problem, you can resort to the Official Thread on the Pioneer VSX 1019 AH-K on avsforum. A lot of helpful guys out there, and a very active thread.
Oct 27, 2009 | Pioneer VSX-1019AHK A/V receiver
Pioneer vsx-819H: MCACC setup won't display on tv
I would say check the cable version not everyone knows this but there are different version HDMI cables such as 1.0,1.1,1.2 and the newest 1.3 cable these are band-with depended cables and if you use a lower version this should work if not you might have a issue with video.
Other then that you might have a issue with the unit if all other signals are working on the monitor.. Ruling out this will be hard if you do not have another monitor to test it on. I would be conducting a test on other output monitors and see if you get any results.
please press the accept button as I worked hard to answer you question.
Oct 24, 2009 | Pioneer VSX-819H-K A/V Receiver
I have a motorolla DSR505 sattelite receiver that I want to connect to my Pioneer VSX-1019AH-K audio/video receiver. The sattelite receiver has a DVI output jack so I have a DVI to HDMI cable to connect it...
Sep 18, 2009 | Pioneer VSX-1019AHK A/V receiver
Get ''not supported ''message on vx-1018-ah
Verify this is a Pioneer VSX-1018AH.
The manual explains it all... The problem is probably an incompatible setting on your source.
Search for "not support" in the manual...
http://www.pioneerelectronics.com/PUSA/Unassigned+Content/VSX-1018AH-K+OPERATING+INSTRUCTIONS
I think this may do it... From Page 86...
No picture or sound. • This receiver is HDCP-compatible. Check that the components you are connecting are also HDCPcompatible.
If they are not, please connect them using the component or composite video jacks.
• Depending on the connected source component, it’s possible that it will not work with this receiver
(even if it is HDCP-compatible). In this case, connect using the component or composite video jacks
between source and receiver.
• If the problem still persists when connecting your HDMI component directly to your monitor,
please consult the component or monitor manual or contact the manufacturer for support.
• If video images do not appear on your TV or flat panel TV, try adjusting the resolution, DeepColor
or other setting for your component.
If ‘NOT SUPPORT’ appears in the receiver’s display, try adjusting the resolution, DeepColor or
• While analog video signals are being output over HDMI, use a separate connection for audio
output.
• When this receiver reproduces MULTI CH IN audio sources with the HDMI setting set to
THROUGH, you cannot hear audio output from all channels. In this case, make a digital or analog
audio connection.
• To output signals in DeepColor, use an HDMI cable (high speed HDMI cable) to connect this
receiver to a component or TV with the DeepColor feature.
Check the HDMI Control (Page 65-66 of the manual). It only works with Pioneer Flat Panel TV's. Also check Page 83 for "No image is output..."
No image is output when an
input is selected.
• Check the video connections of the source component (see page 18).
For high-definition video (using component video connections), or when digital video conversion
is switched off (in Setting the Video options on page 72), you must connect your TV to this receiver
using the same type of video cable as you used to connect your video component.
• Make sure the input assignment is correct for components connected using component or HDMI
cables (see The Input Setup menu on page 67).
• Check the video output settings of the source component.
• Check that the video input you selected on your TV is correct.
Some components (such as video game units) have resolutions that may not be converted. If
adjusting this receiver’s Resolution setting (in Setting the Video options on page 72) and/or the
resolution settings on your component or display doesn’t work, try switching Digital Video
Conversion (in Setting the Video options on page 72) OFF
Apr 05, 2009 | Pioneer Audio Players & Recorders
HDMI Compatibility
Joe
Oct 03, 2007 | Pioneer VSX-81TXV Receiver
Pioneer Vsx-1121-k 7.1 Home Theater Receiver, Glossy Black Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
