Question about Pioneer Vsx-1121-k 7.1 Home Theater Receiver, Glossy Black
HDMI out for pioneer vsx-1121-k not working
Component out is working, HDMI inputs respond and switch to components when powered on. Confirmed cable / monitor working fine.
5 Suggested Answers
  • 14 Answers
SOURCE: Pioneer receiver VSX-D411
Yes techtod you are right you do have to tell the receiver what you want it to do usually on the front panel you can access set up menu and go into input set up This is an example Say you plugged the dvd into optical one or coax 1 you must go to the input that says dvd click down till you highlight dig input and then select optical 1 or coax 1 there can be as many as 8 digital inputs so just check wich one you plugged it into and then tell the amp then you should be back to watching your digital movies
Posted on Apr 02, 2008
robotek
  • 1512 Answers
SOURCE: pioneer a858 amp no sound
Hi Big John
This is a nice reference series amp with a decent phono preamp stage. It is unusual to see a phono stage get damaged in this way.... but Murphy's law tells us "If it can be blown up, then someone will do it". I recommend that you do fix it. First up, perhaps check the settings for the preamp on the rear of the amp(from recollection). Be sure that you have it in moving magnet (mm) mode if you are using a MM cartridge.
Although its been a few years, My recollection is that there is a separate power supply for the phono preamp, with maybe even power regulators on on the actual preamp board. First check would be here to see if both DC rails are present for the phono Preamp stages. Most common failure here is heat stressed cracked/dry solder joints.
You need a good HiFi/Audio tech to have a look at it for you if the problems run deeper than DC supply for the preamp. Good luck. A FixYa rating is a great reward for my time to address your problem. Cheers
regards
robotek
Posted on Nov 07, 2008
  • 4 Answers
SOURCE: HDMI Compatibility
It sounds to me like you have a HDMI Control issue. It sounds like the DVD player wants to control the receiver. Try turning off hdmi control on the TV, reciever, and the dvd player in their setup menus.
Let me know if this helped,
Joe
Posted on Jul 13, 2009
  • 15 Answers
SOURCE: Pioneer vsx-819H: MCACC setup won't display on tv
Its because the pioneer does not display menu options through hdmi. You have to hook up basic yellow composite to monitor out.
Posted on May 03, 2010
Cannot get a display to appear
I imagine you can't see the set up menu to assign the proper type of video input (analog , composite , HDMI ) . On the 818 and previous series the set up menu will only appear through a Component (RCA green , blue and red ) or Composite (RCA yellow) BUT NOT THROUGH HDMI CONNECTION! That's why it will be necessary to run on of those two cable , match the input on the TV , on the Pioneer remote press Receiver then setup and the Menu should appear.
Hope i could help.
Jan 19, 2014 | Pioneer VSX-818V-K Receiver
I have a pioneer vsx-30 with hdcp error on the face i see it when a scientific atlantic cable box is connected through a componet connection
Component cables don't have the ability to carry decrypted HD info.
HDCP is "High Definition Copy Protection"...In theory, it prevents you from running the HDMI cable out of your receiver, and into a recording device, thereby recording HD content without a license for it.
HDCP handshaking is done between devices that run HDMI, or DVI.
If you're running component from your Cable box, and then HDMI out to your TV, then the content you're carrying from the Cable box may not be getting decrypted properly when it gets upscaled onto the HDMI port from Component.
IT could also simply be that you're using an HDMI 1.1 or HDMI 1.2 cable, which may not be able to carry the high bandwidth stream of your Receiver and TV.
Please be sure that all HDMI devices can support the same HDMI version, and also be sure your HDMI cable is labled "HDMI 1.x compliant". . .e.g. if your TV and Amp support HDMI 1.2, make sure you're also using an HDMI 1.2 Cable.
Apr 21, 2011 | Pioneer VSX-305 Receiver
No picture through Pioneer VSX 818V. Hi I have connected a blueray th the hdmi input and the tv to the hdmi, I have sound but no picture or on screen display?
Your receiver has 2 HDMI in with one HDMI out, 3 Component in and one out, and two difital optical in. If the bluray player has HDMI out this woukd be your best bet because HDMI carries the audio and video. If it has Component out, you would have to provde sound through the digital optical. Not knowing what blueray player or kind of tv you have, it's hard to advise so I may be over explaining. Anyway, we've touched on the bluray player to receiver. Out of your three HDMI slots on your receiver only one is HDMI out so make sure you're in the right one. Idaelly you have a DVD/blueray in on your receiver so on your receiver you would select "DVD" when playing. If your hook up is correct you may have to try another HDMI cable to test.
Mar 27, 2011 | Pioneer VSX-818V-K Receiver
I am trying to hook up my Pioneer vsx-455 to a LG LED LCD TV. I am not sure on how to do this and I can not find a manual anywhere. Can you help me?
your reciever does not have hdmi, so the audio is not going to be true DD+ or DTS for broadcast tv.
if your dvd/blue ray player has digital optical spdif, this can be used to transfer the encoded DD+/DTS digital audio.
the besat way to run your tv audio through the reciever is to hook up the dvd/blue ray player up with (perferrably) digital optical spdif, composite spdif or (least favorably) through the stereo stereo analog inputs on the reciever for "dvd" audio in and hook the video from the dvd/blue ray up to the corresponding "dvd" video component input on the reciever.
this way is only going to get your dvd/blue ray sound, next you need to hook up your cable box to the reciever so that you can get broadcast tv sound. hook up the cable box audio to the "tv" stereo analog audio ins, and hook the video to the corresponding "tv" video component inputs.
the component video inputs have separate jacks for red, green and blue ( labeled "Y" "Pb" and "Pr") and are capable of carrying a 1080p full hd signal. use the component video outputs on the reciever to output the video signal to a component video input on the tv, using the receiver's input selector to change the video source.
Nov 25, 2010 | Pioneer VSX-455 Receiver
I cannot get the Input 3 HDMI port to work. The Input 3 Componet videoworks, but when I unplug the componet video and put in HDMI port nothing works. I do have something else in the HDMI Input 1 port...
Hi.
To start ensure that each time you connect or disconnect the HDMI ports both TV and connected device are off.
Also ensure that HDMI input is active, as detailed here.
HDMI connectors carry voltage, and connecting the HDMI cable while TV or device is on may easily damage the HDMI port, making it unusable.
The HDMI 3 and Component 3 are separate input. The component input may work, and HDMI port may still be defective.
To test the port do the following:
Disconnect TV power cord, and connected device (eg. Receiver, DVD etc.).
Leave units disconnected for five minutes.
While power is disconnected, test connecting on port three a device that was previously working on HDMI 1. Also use a cable that you know is working.
Connect back power with HDMI cable already connected. If HDMI 3 is still not detected, then the port is defective.
In that case ring Pioneer at the number listed on the owners manual.This model is often advertised as only two HDMI inputs. Call Pioneer to ensure the third port can be enabled.
Dec 26, 2009 | Pioneer PDP-4350HD 43 in. Plasma...
I have a motorolla DSR505 sattelite receiver that I want to connect to my Pioneer VSX-1019AH-K audio/video receiver. The sattelite receiver has a DVI output jack so I have a DVI to HDMI cable to connect it...
The DVI output usually transmits only video (I'm almost 90% sure about this). It would be better if you did not use the DVI to HDMI cable. Receivers and displays can be very picky when it comes to using HDMI. Your Motorola DSR505 has other output options on its rear. I would suggest using the Component out for video (the 3 outputs colored green, blue and red) and either an optical or coaxial for the audio. The Pioneer VSX 1019 AH-K has the required inputs. Of course, you would require new component and coaxial/optical cables to do the job.
Hope this helps. If you're still in a tangle, you can consult the Official Thread on the Pioneer VSX 1019 AH-K on avsforum. There are a lot of helpful people out there.
Sep 18, 2009 | Pioneer VSX-1019AHK A/V receiver
Get ''not supported ''message on vx-1018-ah
Verify this is a Pioneer VSX-1018AH.
The manual explains it all... The problem is probably an incompatible setting on your source.
Search for "not support" in the manual...
http://www.pioneerelectronics.com/PUSA/Unassigned+Content/VSX-1018AH-K+OPERATING+INSTRUCTIONS
I think this may do it... From Page 86...
No picture or sound. • This receiver is HDCP-compatible. Check that the components you are connecting are also HDCPcompatible.
If they are not, please connect them using the component or composite video jacks.
• Depending on the connected source component, it’s possible that it will not work with this receiver
(even if it is HDCP-compatible). In this case, connect using the component or composite video jacks
between source and receiver.
• If the problem still persists when connecting your HDMI component directly to your monitor,
please consult the component or monitor manual or contact the manufacturer for support.
• If video images do not appear on your TV or flat panel TV, try adjusting the resolution, DeepColor
or other setting for your component.
If ‘NOT SUPPORT’ appears in the receiver’s display, try adjusting the resolution, DeepColor or
• While analog video signals are being output over HDMI, use a separate connection for audio
output.
• When this receiver reproduces MULTI CH IN audio sources with the HDMI setting set to
THROUGH, you cannot hear audio output from all channels. In this case, make a digital or analog
audio connection.
• To output signals in DeepColor, use an HDMI cable (high speed HDMI cable) to connect this
receiver to a component or TV with the DeepColor feature.
Check the HDMI Control (Page 65-66 of the manual). It only works with Pioneer Flat Panel TV's. Also check Page 83 for "No image is output..."
No image is output when an
input is selected.
• Check the video connections of the source component (see page 18).
For high-definition video (using component video connections), or when digital video conversion
is switched off (in Setting the Video options on page 72), you must connect your TV to this receiver
using the same type of video cable as you used to connect your video component.
• Make sure the input assignment is correct for components connected using component or HDMI
cables (see The Input Setup menu on page 67).
• Check the video output settings of the source component.
• Check that the video input you selected on your TV is correct.
Some components (such as video game units) have resolutions that may not be converted. If
adjusting this receiver’s Resolution setting (in Setting the Video options on page 72) and/or the
resolution settings on your component or display doesn’t work, try switching Digital Video
Conversion (in Setting the Video options on page 72) OFF
Apr 05, 2009 | Pioneer Audio Players & Recorders
Component to HDMI
why dont u connect the xbox directly to the tv via HDMI cable? the output will be fantastic.The component cables just cannot give a better resolution than HDMI.
As for connections,i am not in favour of component and HDMI together.
May 18, 2008 | Pioneer VSX-92TXH Receiver
Pioneer 92txh component to hdmi passthrough
check for input...? if so then connect to it and bring it to the mode...!!!
Feb 15, 2008 | Pioneer VSX-92TXH Receiver
Pioneer Vsx-1121-k 7.1 Home Theater Receiver, Glossy Black Logo
47 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
