Question about Dryers
Maytag intellidry dryer
Flame come on and then shuts of within 10 seconds will not come back on for about 3 minutes help
  • Dryers Master
  • 8,220 Answers
IF that is a model with spark sensor I would try cleaning the igniter with sand paper. Some gas appliances use a spark/sensor. It lights the fire then senses the flame and sends back confirmation to the brain. Hard to say without model number. Just guessing by you symptoms given. LOL
Posted on Dec 27, 2013
  • 97 Answers
SOURCE: Maytag Neptune Dryer taking hours to dry a load
Hello Friend, Your solution is simple. It sounds like your dryer is working properly, and your actual problem is a blockage somewhere in your 4 inch exhaust tubing. Check it and make sure it is not clogged up with excessive lint. Also if your tubing is clear you need to check your connection where it travels thru the wall etc. It would be a good idea to find the actual location where it exits to the ouside and check for good airflow. Your dryer is equiped with a safety thermistat and if you are not getting the proper exhaust flow the burner will cut off and restart in the manner that your's is doing. I Hope I have helped you, Tim. And please don't forget to give me your rating for my help.
Posted on Jul 11, 2009
  • 126 Answers
SOURCE: flame shuts down after 5-8 minutes
AFTER THE BURNER SHUTS DOWN THE 1ST TIME IT SHOULD COME BACK ON WITHIN 1 TO 3 MINUTES. WHEN THE BURNER TRIES TO COME BACK ON YOU'LL HEAR A CLICK AND THE GLOW OF THE IGNITOR SHOULD BE VISIBLE. AFTER 30 TO 60 SECONDS IGNITOR SHOULD FADE AND THE BURNER SHOULD FIRE. IF IGNITOR FADES AND BURNER DOES NOT FIRE YOU WILL NEED TO REPLACE BURNER COILS #279834. IF IGNITOR DOES NOT COME ON YOU WILL HAVE A T STAT OR SENSOR ISSUE. SOUNDS LIKE COILS TO ME. HOPE THIS HELPS PLEASE FEEL FREE TO CONTAT ME HUBAPPLIANCE@COMCAST.NET. PLEASE RATE MY RESPONSE.
Posted on Jun 24, 2009
MNfisherman
  • 11896 Answers
SOURCE: my kenmore gas dryer ignites and the flame shuts off after 10 sec
The valve on the pilot may need to be replaced. The springs get worn and wont stay up. Otherwise you could replace the entire pilot unit with a kit.
Posted on Jul 20, 2009
protek480
  • 1723 Answers
SOURCE: Maytag Neptune MDG5500AWW gas dryer ignites, then flame goes out
The 'radiant sensor/ needs to be replaced. This sensor tells the system that the flame is lit and everything is good. Go to repairclinic.com
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500aww-%3d%3di2681&PartID=2681
Posted on Oct 02, 2009
  • 34 Answers
SOURCE: My maytag atlantis dryer isn't heating
The chamber is most likely over heating and tripping off the gas valve which is doing what it's suppose to. If the exhaust duct or vent damper outside is plugged up with lint it will cause this problem. Try disassembling the complete exhaust vent & vacuum it out.
Posted on Oct 06, 2009
Why does my maytag dryer medc200xw turn off in 10 minutes and has no heat
Could be overheating. It just may need a good cleaning. and make sure the dryer vent is clear with no obstructions. You may need to take some panels off. Also may be the gas valve solenoid.
Jul 21, 2014 | Maytag MEDC300XW - 29", 7.0 Cu Ft, He...
Dryer shuts off within a few seconds and smell burning
That's a sign your motor is bad. Soon it won't start at all.
Mar 13, 2014 | Maytag MEDC300XW - 29", 7.0 Cu Ft, He...
Igniter starts to glow for 3-5 sec while making noise every minute or so
Check the thermocouple it is going bad or already has and that is why the gas valve is not staying open.
Jul 08, 2017 | Whirlpool GGW9200L Gas Dryer
Intermittant Heat on Gas Dryer
Check the venting tube. It maybe clogged full of lint somewhere inside of it. If so the moister contro sensor will shut off the burner within due time such as yours
May 01, 2010 | Maytag SDG4606A Gas Dryer
My maytag atlantis dryer isn't heating. It will flame then go out in about 10-15 seconds. 3-4 minutes later it will flame and then go out again in about 10-15 seconds
Oct 05, 2009 | Dryers
Maytag DG 412 won't stay lit
If the dryer can be restarted within 1 minute and it starts again it's not likely the coils. It may be poor air flow causing the safety thermostat on the flame tunnel going off as a warning. If it takes several minutes off to make it start again, it's likely the coils. When they cool down the broken coil contracts and the broken ends come back together (you can't see this). The coil kit number is 12001348 for the DG412.
Be careful not to break the ignitor when you service these...it is VERY prone to breakage. Turn off gas and electricity before servicing.
Aug 23, 2009 | Dryers
Flame shuts down after 5-8 minutes
Jun 23, 2009 | Dryers
Dryer does not dry clothes. Flame does not stay on
run dryer for 10 minutes then remove vent hose see if start working mean flame on for while, if it is then you need to clean your vent system.
May 01, 2017 | Maytag Atlantis MDG7400AW Gas Dryer
Dryers Logo
44 people viewed this question
Top Dryers Experts
