Question about Refrigerators
Whirlpool ed25pe need outside dimensions of ed25pe
Dimensions for whirlpool GU1200XTLS2
DOOR AND PANEL PARTS Diagram & Parts List for Model ...
www.searspartsdirect.com/model-part/gu1200xtls2/1198/.../00001.html
DOOR AND PANEL PARTS diagram for model # GU1200XTLS2 Whirlpool-Parts Dishwasher-Parts (24). Full Size. Print ... Owners manual Part #: 8283509.
Whirlpool Dishwasher Model GU1200XTLS2 Parts from ..
Jan 03, 2016 | Whirlpool Dishwashers
What are the dimensions of Whirlpool Fridge Model ET18GKXGW01?
You would be safe if you used the current dimensions for todays
18cf Top freezer ref. 28" w x 67.5" h x 31" d
You are right no published spec's left too old I guess?
May I suggest measuring the space allowed for the fridge?
Jul 27, 2014 | Refrigerators
What are the dimensions for a Whirlpool Refrigerator ED22DQ?
A complete model number is needed, here is a list of manuals from Whirlpool.
Manuals and Literature
Apr 11, 2014 | Whirlpool Refrigerators
Dimensions
Wouldn't it be easier to simply measure the one you have - or measure the available counter top space you have for a replacement?
Whirlpool Customer Service can be reached at:
1-866-698-2538 U.S.
1-800-807-6777 Canada
553 Benson Rd
Benton Harbor MI 49022
Jul 10, 2013 | Whirlpool MT9160XE Microwave Oven
What are the dimensions of the Whirlpool microwave GH4155XPB?
Dimensions/Weight Exterior Dimensions (WxHxD): 29 15/16" x 16 1/4" x 15 7/16" Cavity Dimensions (WxHxD): 22 3/8" x 8 3/16" x 13 13/16" Approximate Shipping Weight (lbs.): 86 Microwave Capacity (cu. ft.): 1.5 Cooking Power (watts): 1000
Jun 06, 2011 | Whirlpool GH4155XP Microwave Oven
What are the dimensions for a Whirlpool Microwave MH7100XYB? Whirlpool doesn't have the dimensions on their site and I'm trying to replace it.
30" wide x 16" tall x 14" deep. Tried to find a replacement for mine of that size with no luck. Turned out a $30 capacitor needed replacing ($90) service charge.
Sep 21, 2010 | Microwave Ovens
I need the dimensions of the Whirlpool MH6130XE microwave to insure the opening is sufficient.
You can download the owner's manual and installation instructions here.
They'll give the dimensions.
Jul 23, 2009 | Whirlpool MH6130XEB/Q Microwave Oven
Whirlpool ED22COXHW02 side ny side not freezing or cooling
From your description it sounds like your compressor has gone bad. Check the condenser and see if it is plugged with dust. Clean it and let the unit cool off for about an hour or so. A plugged condenser can cause the compressor to overheat which can cause the thermal overload to click cutting the power to the compressor. After the compressor has been aloud to cool off restart the system and see if the compressor will operate. If you had to remove a panel in the back to access the condenser make sure you replace it for proper air circulation.
May 31, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
