Question about HP Pavilion zd7020US Notebook
ZD7020US Display Display is in 4 segments.About 2 inches of the top of the screen disappeared and reemerged at the bottom.About 4 inches of the screen shifted right and reappeared on the left side of the screen.You can actually have the cursor go out the right side of the screen and come back in on the left or go out the top and come back in at the bottom.I hooked a monitor to the laptop and it works great on the external monitor.Any ideas what causes this problem?
  • 4 more comments
  • truckerdon Oct 17, 2007
    No. 1 solution not a fix.reinstalled system and all drivers but did not fix. As stated if you hook another monitor to laptop it works fine. ???
  • truckerdon Nov 04, 2007
    I left out one important possible clue. I drive a truck and was at a stop and viewing a gps program when i restarted the engine of my truck when this problem arose. I figure it was possibly caused by a voltage surge for I was using a inverter to get my 120 from a 14 volt source. After I started my engine my computer shut down and when I restarted my computer I had this problem.
    ANY IDEAS ???
  • mizz196 Dec 02, 2008
    Yes, I have the same problem! The screen is segmented, shifted up 2 inches and right 4 inches. Only the left inch of viewable area (where the start button is) is not viewable.
    I did hook it to an old external monitor and it viewed fine for about 60 seconds until that monitor decided to quit entirely (had been in the attic for 2 years).
    I have successfully hooked up to another external monitor. Can use the computer fine from it. Any ideas on fixing the laptop screen?
  • Anonymous Mar 25, 2014
    Occasionally vertical stripes will appear within 1/2 inch of the right hand side of the screen, from top to bottom.
  • truckerdon Jul 31, 2014
    Fixed the problem. There is an inverter board that runs between the display and the computer itself. This is mounted on the back of the display screen. No problems since replacement of inverter.
Thanks Bluegreenash, but the download driver didn't solve solve my problem either. Thanks
Posted on Nov 14, 2007
    Problem Solver:
  • 5 Answers
The answer may lie in getting your video card fixed
or resoldering the display screen wires.
Posted on Oct 17, 2007
  • 661 Answers
Sounds like you have the wrong monitor drivers installed,  download updated monitor drivers from the manufacturer's website,
also check your display settings,  as something is really wrong there.
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
My proview 558 monitor has a 1/2 inch black line at the bottom
ms_biguns, You need to test one or the other, The tower should output and drive a substitute known good monitor, or a known good pc should be able to display the WIN-desktop screen on your Proview 558. Could it also be that the software in pc not set up for driving a Proview558? 12fixlouie
Feb 28, 2010 | Proview Computers & Internet
Toshiba Laptop screen has 2 inch black line down the middle?
seems to me like your screen has developed some bad segments and will need to be replaced, you will need to take apart the laptop to remove the screen/display and purchase a new one and replace it,
Feb 20, 2010 | Computers & Internet
Hi, I have a 6 month old laptop Acer emachines E625 and turned it on this morning to find 3 thin black horizontal lines have appeared (with about 2 or 3 smaller lines above each of the 3 lines) at the...
Attach an external monitor to your PC. If the problem continues there, it's your graphics card.
If the problem disappears, you have stuck/dead pixels.
You could try a very gentle rubbing of the pixel(s).
Feb 03, 2010 | Computers & Internet
Black vertical bar about 4 and a half inches wide down center of screen
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
Jun 01, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Darker fatter letters every 2 inches apart from top to bottom
it is called phase you can attempt to let the lcd monitor auto set or you can disconnect the power over night then plug in and then do not auto set this default usually seems best some times
Nov 29, 2008 | Proview PL926WBi 19" LCD Monitor
Screen border
You are probably in the "3:2" ratio print setting. This is accessed through the "F" button, under image quality. The 3:2 is a ratio of height to width which corresponds to a 4x6 inch print. The other settings are approx. 4x5.33 inches in h to w ratio. Just change the quality setting to the larger megapixel settings and the bars will disappear.
Sep 21, 2008 | Fuji FinePix S700 Digital Camera
RCA 52" projection Model no. D52W19 produced 9/04
make sure you do not have the automatic screen mode set to wide screen on tv menu .Also if you have cable box set to wide mode only then the tv will only display wide mode.
Dec 05, 2007 | RCA P52937 52" Rear Projection Television
HP Pavilion zd7020US Notebook Logo
123 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
