Noisy unit,it makes pumping noise thru the whole house.
It's probably 10 years old,that Kenmore single package is very noisy,mostly compressor rumbling or pumping noise but it cools fairly.It takes about 30 minutes to bring down one degree in Florida summer time.Let me tell you the unit is attached to the concrete wall of the house.
  • HANK MCNEIL May 11, 2010
    what's the question?
  • 78 Answers
You have already used it for 10 years, now please buy the new one and give kenmore little rest!!! whatsay?
Posted on May 20, 2009
Noisy compressor on fridge freezer
does it always make that hum noise or just when adjusting temp
Aug 18, 2012 | Kenmore Refrigerators
Hey Guys, I have a 1.5 HP A.O Smith switchless motor for my inground pool. I believe it is about 8-10 years old.(I have only owned the house for 4 years) I close up the sytem properly each year,...
Thank you for posting your question here on Fixya.com.
Let's start with closing properly - taping things off with garbage bags can cause more harm than good. Trapping moisture under the bags will lead to condensation which is mildly acidic. The lack of any airflow leads to corrosion and accelerated wear. If you are going to cover anything you must make sure air can circulate thru freely or you will actually need new equipment sooner than if you had not covered it at all.
The noise can be from your impeller but only if it is cavitation...are you getting air in the pump basket or air bubbles from the returns in the pool? If not the noise is the bearings. If the seal has leaked at all it can be what caused the noise. If not it is the condensation mentioned above or age/contamination. Whatever the cause it is only relevant in keeping this from happening again sooner that it will naturally.
As long as the damage is limited to the bearings a new set of bearings and a pump seal would cost you $100-$125 in a repair shop...if you buy parts to do it yourself it should be under $30. A word of caution - if you have never repaired this type of equipment and are not familiar with bearing and seal changes the ~$80 labor charge is worth it.
If there is more damage than just those parts a new motor and seal should be under $200 total; again from a shop. A whole new pump would exceed $300 for most units, maybe more.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
May 03, 2011 | AO Smith Pool Pump Motor Hayward Swimming...
What is the clunking noise made after the refrigerator stops running? Its a Kenmore and is 10 yrs old. We have thoroughly cleaned behind and beneath the refrigerator and now the noise seems louder.
The clunking noise you hear , is probably when the compressor shuts off , due to temp reached or when it goes into defrost . An internal motor mount spring , inside the compressor , is broken ( rusted and broke ) . The refrig can go on working for years , without any problem , except noisey , when it cuts off . To stop the noise , replaceing the compressor is the only option . I have heard of placeing objects under 1 leg of the compressor , to " re-adjust " the ballance , but thru my experience , another spring broke , causing more knocking .
Mar 24, 2010 | Kenmore 64802 Top Freezer Refrigerator
Noisy outside from the Unit
Could be compressor noise Improper charge bad fan motor hard to say. What is the brand name of your unit. Russ
Jul 20, 2009 | Ruud Handle Air Conditioner
I JUST HAD A GUY COME OUT HERE AND SAID MY COMPRESSOR WAS BAD, HE SAID I MIGHT AS WELL REPLACE THE WHOLE UNIT CAUSE THERE WAS ONLY $400-600 DIFFERNCE IN REPLACING THE UNIT COMPARED TOT HE COMPRESSOR. THE...
better replace a whole unit,than you have guarantee on whole unit not just on compressor.
And your unit is old 8 years,replace it and you have a new.
It is also my suggestion.
Jul 04, 2009 | Weather King 10AJA4801AH Air Conditioner
A three loud consecutive popping sounds at various
You probably have a bad compressor. It's internal parts are held up with 4 springs and one of them has probably broken and causes the compressor piston to hit the side of the comp. housing. This will happen when the ref. shuts off. To be sure, if you turn the ref off at the controls then you should hear the noise in the back. If it is less than 5 years old you can get it replaced under warranty. if more than 5 years old it will just be noisy. it will most likely last several more years like it is. Let me know if I'm right.
Apr 01, 2009 | Frigidaire FRT21H8 Top Freezer...
Noisy wash cycle
if it's 10 year old it's not worth repairing if the transmission is bad.  However, if it's only the $20 coupler that connects the motor to the transmission.  Fix it.
Mar 29, 2009 | Kenmore 24032\24036 Top Load Washer
Amana refridgerator mdl abl2222fes knock noise
sounds like the compressor vibration dampers are wearing out. the dampers are the rubber washers that seperate the compressor from the chassis of the fridge. when they start to deteriorate, and the compressor kicks on, it will bounce against something in the chassis, causing a knocking noise.
Jan 22, 2009 | Amana ABL2222FES Stainless Steel Bottom...
Kenmore 4.6-cu/ft refrigerator makes unusual vibrational noise
probably is the compressor become noisy but it doesn't mean that it will fail
Oct 08, 2008 | Refrigerators
Kenmore refrigerator is noisy
my kenmore fridge is loud everytime the compressor comes and stays on. I have developed tinitis in the year because of this noise. Solution to this problem : I will never ever buy another Kenmore refrigerator.
Mar 05, 2008 | Refrigerators
Heating & Cooling Logo
165 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
