Question about Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top Load Washer
Samsung WA422PRHDWR/AA not draining
Waste water tube - ok drain - ok pump - ? when waste water tube is removed the water flows out freely. Likewise when water is sent trough the waste water tube. It just does not drain on its own. No Leaks. Spin refuses to activate (maybe because it senses the water is not draining.) bad pump? sensors?
  • 3 Answers
In my case, one of my stainless collar stays had ended up in the laundry and was stopping the pumps impeller from spinning. After spending an hour taking apart the washer and fishing around in the pump, I got the stay out and the washer drains fine now.
Posted on Aug 24, 2015
    New Friend:
  • 5 Answers
I had a the same issue and my fix ended up being the leveling sensor. repair man said if you tilt your washer to far in any direction it throws it off...hmmm
Posted on Dec 27, 2013
  • 127 Answers
SOURCE: Washing machine will not drain all the water. If
there is always a little water left in the drum assembly when done pumping. however it is usually well below the level of the clothes basket/drum so that there is none contacting the clothes when at rest.
if you can actually visibly see water within the clothes basket/drum when the cycle is complete, then check below.
have you lengthened the drain hose beyond the standard length to reach to your taller than normal sewer/drain inlet??? if so then you're getting more water returning to the unit when the pump shuts off and if the extra hose is long enough then theres enough water returning to your tub so that the basket sits in water at rest..
if so you'll need to install a check valve to keep the additional water from going backwards into your unit. some of these units have one built into the drain hose where it connects to the pump.. i tried looking yours up via the model # listed on the 1st page but got nowhere with that number.
you could also have a restriction in your pump or drain assembly that may be slowing things down some.. can't be of more help without proper model # though..
hope this helps,
best of luck,
ttfn
Posted on Oct 25, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Samsung WF317 Front Load Washer code nd
Check the drain pump itself. But at the same time if your clothes are still sudsy it sounds like it is not going through all the cycles. Almost like it is skipping a cycle
Posted on Feb 12, 2009
SOURCE: I have a samsung wf203anw
Posting a problem with your POS Samsung washer here is a waste of time! UII currently have the same problem a lot are having with this not draining nd code and I AM NOT going to pay for a tech to tell me that I have to have a guy come in to take my washer apart. I will do it myself!
Posted on Feb 28, 2011
SOURCE: NEW SAMSUNG WASHER WONT DRAIN.
Try clean debris filter locate in front of the machine.
Posted on Jun 23, 2008
SOURCE: Error message 1E is displayed at start up samsung model SW75C3S
1E error mean there is malfuntion on your sensor pressure. Maybe because the sensor is damage or rusted. You must replaced, it's cost me about $15
Posted on Jun 10, 2009
My 17kg whirlpool x-pert is not spin drying
Is it emptying the water quickly enough? A blockage, or partial blockage on drain will prevent the spin starting quickly, and you only have a limited time on spin before the program stops.
Carefully remove and clean any filters if fitted on the drain - you must do this and don't assume they are clear. If ok, check the connections at the waste hose on the sink or plumbing, and in the waste hosepipe. Can you hear the drain pump running on the drain only cycle? a glug glug glug noise.... if you cant hear the pump it may be seized or jammed with a coin or button or pin or bra wire or zip etc etc.
If no waste water is flowing, try lowering the waste pipe on to the floor completely flat - water should flow out under gravity. If it doesn't, there may be a blockage in the machine sump hose - a sock or pants, etc.
Check all the basics first - water fill, water drain, filter clear, drain water flowing etc.... if all ok, may be motor or control card.
Dec 28, 2017 | Whirlpool Washing Machines
Overflowing from drain hose which is attached to white chamber Whirlpool wwdc7210/1
The washing machinedrain hoseis where the water flows through to get the water out.If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it
Jan 27, 2016 | Whirlpool Dryers
My washing machine will not drain off water in spin cycle
Washer will not drain:
Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement.
Read more:http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ
Thewater pump belt(to drain out the water) may have broke or become frayed or loose.If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing theNO DRAINissue and remove and replace if needed.
If thelid switchis not working as required it will cause your washer to not drain (and many other problems).This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuityMy advice is free cuz God is good!
Sep 21, 2014 | Samsung WA422PRHDWR
Error code of NF (no fill) on samsung top load washer (WA422PRHDWR/AA) even after checking lines for restrictions and ensuring clean line filters (red and blue). Now, when it does work, it will only do a...
Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, start machine. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, start machine. Now there should be twice the flow of water than there was with HOT and COLD temps. I suspect it is the HOT side of inlet water valve that has failed because machines usually rinse with COLD water.
Jan 20, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
Water won't drain from bottom of dishwasher. I pulled the dishwasher out, blew through the drain tube, disconnected the drain tube and felt around inside. Ok there. The dishwasher has not been in use for 4...
Sorry to hear that you are having problems with your DW.
Actually, yes. Not using a dishwasher for a while can damage some parts. Sediment from water damages the water valve. Food residues clogs the drain and drain pump. More likely the drain pump needs to be replaced.
Per your notes, looks like you are a handy main, so you may want to remove the pump to determine if it is clogged. (Quite dirty job). The drain pump is easy to locate, just follow the drain hose.
Also, check the connection with the food disposer under the sink.
Nov 15, 2009 | Dishwashers
Maytag washing machine won't drain or agitate
Check the drain line for kinks or obstructions. Check the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Make sure nothing is clogging the pump (like a stray piece of clothing) and check the pump impeller. Make sure there are no blades missing/broken and that the impeller spins freely. If there are any broken/missing blades or if you can't get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged drain line, pump, or jammed impeller. Remember to disconnect the machine from electrical source before attempting any repair. Sorry for your trouble and I hope this helped. Best wishes.
Sep 23, 2009 | Washing Machines
F18 Error
the error is caused by a blockage in the pump you need to drain the washer using the black tube near the pump drain or by unscrewing the pump cover next to it on excel 8kg washer these are at bottom right of machine. when all water out remove pump cover that you loosened to get water out then check for blockages inside. the pump has a device inside that should move round freely remove all debris replace and try to drain using drain cycle this will finish and hey presto back to normal!!
Oct 05, 2008 | Siemens Washing Machines
Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top Load Washer Logo
723 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
