Question about Nokia C5 Cell Phone
357006040519239 please ok this phone
I forget my lg gd900 security code..help me please..
just flashed the phone and its perfectly alright :) here's the log
Connecting phone - connect USB cable to phone, phone must be OFF and without battery ...
Driver connected, connecting phone ... OK
Changing baudrate ... OK
Setting bus ... OK
Loading certificate ... OK
Reading phone info ... OK
Writing flash from file : GD900AT-00-V10c-EUR-XXX-JUN-24-2009_EN_IT_GER_FR_ES_GR_NL_PT_SW_DA_RO_TU_HU_SLO_C Z_CRO_BUL_PL_SK_FIN_NO_SERB_EE_KZ_LV_LT_RU_UKR.fls
Checking flash file ... OK
Extracting flash files ... OK
Found 10 files for writing
Writing flash : ../../../wou_build/CRYSTAL_EUROPE_OPEN_REL
EASE/MPEH_CRYSTAL_EUROPE_OPEN.dsp ... OK
Writing flash :
MPEH_CRYSTAL_EUROPE_OPEN.eep ... OK
Erasing dynamic eep area ... OK
Writing flash : MPEH_CRYSTAL_EUROPE_OPEN.fls ...
Writing part 1 ... OK
Writing part 2 ... OK
Writing flash :
CRYSTAL_EUROPE_OPEN-CUST.dfat ... OK
Writing flash :
CRYSTAL_EUROPE_OPEN-ROOT.dfat ... OK
Writing flash :
CRYSTAL_EUROPE_OPEN-USER.dfat ... OK
Writing flash :
psi_large_block_16_bit_paging_crystal.flb ... OK
Writing flash :
slb_large_block_16_bit_paging_crystal.flb ... OK
Writing flash :
ua_large_block_16_bit_paging_crystal.flb ... OK
Writing flash : a250_single_image.fls ... OK
======== Process completed ========
Operation time - 0:14:47
Oct 27, 2010 | LG Crystal GD900 Cell Phone
HOW CAN I USE A CODE SO NO BODY CAN SEE MY STUFF ON MY LGVX1000 VOYAGER
using phone lock is the simplest method which meet urrequirement
please follow the steps below
1.Open the flip and press the OK Key [M ENU] .
  • 2. Press the Navigation Key to
    scroll to the Settings & Tools
    menu and press the OK Key .
    3. Press Phone Settings.(6)
    4. Press Security.(6)
    5. Enter the four-digit lock code.
    6. Press Phone Lock.(3)
    7. Scroll to an option then press the
    OK Key .
Lock Phone Now
Using the Internal Keypad
1. Open the flip and press the OK
Key [MENU].
6. Press Lock Phone Now.(4)
May 19, 2010 | LG VOYAGER VX10000 Cellular Phone
"Memory Full but i have 4GB"why?!?need help...
Go to the "Settings and Tools" menu.
go down to "Memory" and press [ok]
Press [ok] on "Save Options"
Arrow down to "Sounds" and press [ok]
Your phone is set to "Phone Memory"
Select "Card Memory" [ok]
Now set the Pictures and Videos the same way!
Hope this helps!
Sep 19, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Restart problem
ok ur data base as been deleted i think u can get back it if u have the data cable of ur phone connect to the pc and then go to the nokia site and get the up dates for ur phone click on that update and download it and install the update manger and start updating ok bye rate me please if u cant do this contact me again i will send step by step ok bye in the meen while i will check the ur phone details and i will give the website of update ok it is not restarting because the data has corruped it can be do very easily ok bye and contact me at a_srinivas15@yahoo.com and give me ur imei no please
May 26, 2009 | Nokia 3110 Cellular Phone
Installing theme sin motorola zn200.
Please tell me how to install theames in my zn200, i have downloaded themes but not able to send it to my phone, connection is ok but where to send??? please describe step by step.
May 10, 2009 | Cell Phones
Phone # on outgoing faxes
"user tools"
"fax features" ok
"general settings" ok
"program fax info" ok
"own fax number" ok
enter number..press "ok"
Please rate solution. thanks :)
Apr 23, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Got a dialling tone but couldn't make a call
Cnavarro,
my existing phones work fine but the new phone is really weird. tested Ok at the supplier's store and perfect at my friends' houses. But once tested at any of the phone outlet in my house, after keying the first 3 numbers....PLEASE CHECK YOUR NUMBER AND DIAL AGAIN etc... the scenario telling me my phone service in my house is OK and the new phone tested OK at other locations.
See if you could give me some clues....thanks
Oct 07, 2008 | Innovage 69420210126 Phone
SECURITY RESETS ON MOBILES
the phone code is usually 0000
Sep 01, 2008 | Cell Phones
Verge cordless phone system v581tad
I believe you have the expansion capacity of the phone all used up. The phone cannot register any more handsets until you delete the handset registered that is not in use. First check the handsets and see what handset numbers they carry. It should be #1,#2,#3,and #4 if it does not then you will have to delete the one that is missing or if it is then delete handset #5.To do this you will have to use one of the handsets registered to the base. First Press the MENU/ OK button then scroll down to ADV,SETTING then Press MENU/OK then scroll down to DEREGISTER then Press MENU/OK. Then ENTER HANDSET PIN would show, if you have not changed the pin enter 0000 if you have enter your pin member. From the next options select HANDSET and press MENU/OK from the next set of options select the handset number you want to DEREGISTER and press MENU/OK from the next option select YES then MENU/OK. Then try to reregister the new handset To do this Press the MENU/OK button then go to ADVANCE SETTING press MENU.OK scroll to REGISTER then press MENU/OK Select the base number displayed then press MENU/OK. PLEASE WAIT will appear. Then from the base press and hold the PAGE button until the handset prompts you to ENTER PIN # .Enter 0000 OR your pin number then you will see PLEASE WAIT. A tone will confirm the handset registration.
Apr 03, 2007 | Uniden Cordless Phone
Nokia C5 Cell Phone Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
