Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Motor comes on and water gos out but basket will not spin untill lid is opened then closed again . this is on all spin cycles .
  • 6,784 Answers
HI, you will need to replace the lid pressure switch. it is faulty or the wires may be worn or lose.in most cases, it will be a faulty lid switch.
Posted on May 18, 2009
Whirlpool model # LLR6144BQ1 water fills but will not go to wash cycle.
Hi and welcome to FixYa, I am Kelly.
This is usually caused by a failed lid switch that is item 9 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=256996
First off put the washer in the spin cycle. With the lid closed see if the washer will spin. No spin also = bad lid switch. If the washer spins but will not agitate then the problem is most likely the water level pressure switch or associated air tubing. (any air leaks and it will not stop filling)
Water level switch is item 12 here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=256996&diagram_id=28209075#d28209075
We test these with NO WATER in the machine and after connecting an external hose with the lid closed with power on by orally passing air into the small air hose we connected. It will click and the washer must agitate. If it clicks and does not agitate... again it points to the lid switch. Disconnecting this water level switch hose with ater in the maching and then re-connecting the hose WILL result in the machine overflowing. Tub MUST be empty.
You check the lid switch as you just open or close the lid. You should hear an audible CLICK as the lid is barely off of its closed position and again as the lid is almost closed. NO CLICK = bad door switch.
These are the 2 most common reasons that will correct the symptom your experiencing more than 90 percent of the time. There is a remote possibility that there is a problem with the motor / motor clutch. Motor clutch problems are noted by odd noises when motor is running and it will not spin or agitate. If the motor will spin the machine but will not agitate the machine it can be a motor winding.
Thanks for choosing FixYa,
Kelly
Mar 13, 2011 | Whirlpool Washing Machines
Sometime the wash cycle stops when the spin cycle should start.
From what you're describing it sounds like the lid switch is faulty. Open & close the lid slowly & listen carefully for the click of the lid switch. If you do not hear the lid switch, you will need to replace the lid switch. Other testing will require accessing the controls & using a meter to make some more checks with. If the motor is not running & the lid switch checks good I suspect the timer. If the motor is running in the spin cycle but the basket is not spinning I suspect the drive block, basket drive, transmission or clutch.
Mar 04, 2011 | Maytag MAV7200 Top Load Washer
Motor running, basket not spinning during rinse cycle
with this issue i would look the the notor coupler
its a small plastic clutch between the motor and transmiossion
Oct 09, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer mdl#110.23832100 spin cycle motor
Hello, looks like your lid switch is on it's way out, replace it...you will find it normally about half way down under the lid. If not there you will find it in the control panel on the right side next to the water level control. The reason it works some times and not others is because some times it fails to push the lid switch down far enough to engage. the lid switch is a safety divice inteneded to stop you opening the lid while in a high speed spin. If you have any other questions please feel free to comment again. Mike
Oct 01, 2009 | Washing Machines
I have The same problem OPEN Lid and works fine
When you lift the lid, did the motor stop? Do you know if it agitates? If the motor runs and there is no agitaion or spin, check the coupler connecting the motor and transmission. If it agitates and does not spin, it could be a basket drive assembly. The lid switch can also affext the spin cycle. Many reasons why it won't spin. These are just ideas to look into.
Vic
Jul 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water comes back in and stands after cycle is run
I'm not sure what washer you have but a lot of washers have an additional spin cycle. If you left the lid open, then it would only fill with water then sit until the lid is closed. Try making sure the lid is closed next time you empty it and see if the water is in there the next morning. I hope this helps. Good luck!
May 25, 2009 | Washing Machines
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Kenmore 70 Series Washer Spin Cycle Only issue.
It sounds like one of two things 1,A worn clutch .or 2.motor coupler is about gone,
May 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore model #110.22802100 drains but no spin
If it is draining, then the motor is ok.
If it is agitating properly, then the motor coupler is ok.
This leaves the gearcase, clutch, basketdrive(brake), basket drive block, or timer.
Raise the lid and hold the lid switch down. Start a rinse cycle and let it go through the cycle. It should drain the water, then stop the motor for a split second then kick the motor back in and start spinning. If it doesn't drop out that split second then the timer is holding it in neutral drain. You can recreate this by letting it start draining, then let off the lid switch, then depressing it again. The basket should start spinning. If not,
Raise the lid and hold the lid switch closed. Start it in spin and see if you can get it started spinning by hand. If so you probably have a slipping clutch.
Post back with any questions.
You can go to sears.com, click on parts, and enter your model number and see parts diagrams of the washer. This can be helpful.
Nov 25, 2007 | Zanussi F1045W Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
77 people viewed this question
Dan Webster
Dan Webster
Sal De
