Question about Zenith R49W36 49" Rear Projection HDTV
Zenith TV PV4667RK
Set works fine for about 35 to 45 minutes then screen goes black still have sound. turn set off for about 2 hrs picture will come back for about 35 to 45 minutes.
  • Anonymous Mar 25, 2014
    have a very loud vibrating sound
  • 36 Answers
This sounds like a thermal intermittent, either a component or a connector or most likely a solder joint.
when it heats up it expands losing its connection if its a solder joint. if its a component its a lot more complex.
i dont know your electronic/mechanical experience, a projection tv is very complex inside, several circuit boards, dozens of wiring connectors a whole lot of very high voltage, enough to be fatal and if not at least very painfull.
if you are experienced and able check all the solder connections on every circuit board under a magnifier, repair any bad ones.
after that the trouble shooting gets very complex as it must be done with the boards opened up and exposed while the set is running, you will require a set of schematics, component freeze spray, a spot heating gun, a high impedance meter, an oscilloscope, temperature controlled soldering equipment and possibly a signal injector of some sort.
if its worse than a bad solder joint it is probably best left to a service shop.
best of luck.
Posted on Oct 17, 2007
Polaroid tv screen goes black after 30 40 minutes, sound is good. No picture. Turn set off and wait a few minutes and the picture returns for a few minutes then goes black again.
Ur tv now power on only have picture few mins,than dead,have sound only?Yes,than the 1 or 2 the long board call the LCD inverter boards are dead.The LCD inverter long boards help the LCD screen to have a backlight to produced a picture.Tries websites like, to buy 1 or 2 long LCD inverter boards for the replacement.
Jul 05, 2010 | Polaroid FLM-3232 Television
Problem With KENMARK flat Screen TV - BLACKS OUT
you do not give the model number for a better diagnosis
the most common cause of this problem is the invertor or at worse the screen its self.
If it is a lvd 163 you can purchase a new invertor from sales@tvs-services or call 01245392539
Feb 14, 2010 | Zenith IQC50H95W 50" Rear Projection...
Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Apr 30, 2009 | Sharp Aquos LC-C3234U 32 in. LCD TV
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
P42W46X Zenith Plasma - No Picture - Mostly Yellow on screen
Mine looks like too, but the line running across isn't on my set, picture looks like this, and the sound works fine. I took the tuner board all the way out and turned the set on and it did the same thing, then I unplugged the top wire on the board next to the tuner board and the screen went black. plugged it back in and the screen came back with the scrambled picture. Anyone know why? Bad mainboard maybe? the left of the tuner board?
Nov 25, 2007 | Zenith P42W46X 42 in. Plasma EDTV
LG LCD Tv picture goes black but the sound still works
Next time it goes dark do a flash light test to see if your inverter board is fubar.
May 03, 2017 | LG M4200C 42 in. HDTV-Ready LCD Television
Zenith R49W36 49" Rear Projection HDTV Logo
80 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
