Question about Brookstone Stunt Copter RC Helicopter
Stunt copter won't sync - Brookstone Stunt Copter RC Helicopter
My remote control isn't syncing with the copter
Go to twit.tv
look for Select :All Shows:
Click on the show called "Know How....
They have many free courses in "Remote Copters"
May 03, 2015 | Brookstone U-Control Combat Copter with...
Manta 4 channel rc quad-copter will not calibrate properly
Sounds like the axle is slightly bent and warped from the initial crash. Try replacing the axle and this should solve your problem.
Apr 19, 2014 | Protocol Manta 4-Channel Radio-Controlled...
Wireing guide for a brookstone stunt copter
If under Warranty (Brookstone or Extended) have them replace it. If not, suggest a Hobby Shop that specializes in R/C Helis
Apr 17, 2013 | Brookstone Stunt Copter RC Helicopter
I want a manual for my stunt copter for the 4ch/2.4G
Just added it to this site. Should be up in 24 hours or so. Otherwise, go here: http://www.brookstone.com/webassets/pdf/796083p_manual.pdf
Dec 30, 2012 | Brookstone Stunt Copter RC Helicopter
I presume you have lights & sound on the controller when you turn it on - fourteen quick beeps and then a different toned fifteenth beep. The screen lights (blue). Insert the battery (lettering facing up toward the helo fuselage unitl it's seated all the way - an LED inside the fuselage, visible from behind, quick flashes and then begins a slower blinking.
Once the helo battery is inserted, turn on the controller, which starts the aforementioned beeping. On the last controller beep the helo's LED will stay lighted, indicating the helo & controller are synched.
I had a problem making sure the battery was inserted all the way into the helicopter. You'll know it's inserted properly when the LED inside the helo flashes.
Dec 26, 2012 | Brookstone Stunt Copter RC Helicopter
The brookstone stunt copter and remote donot sync
It would not sync. solution was to assume poor technical writing. step zero. turn the controller off. step one. plug in the battery to the copter. step two. QUICKLY turn the controller on. if you miss this small window of time, it is going to fail. The copter light blinks fast during this period, and if it slows the blink rate, then you have waited too long.
Dec 13, 2012 | Shuttle 9094 Emax Remote Control...
Brookstone Stunt Copter RC Helicopter Logo
32 people viewed this question
Top Brookstone Electronics - Others Experts
Are you a Brookstone Electronics - Other Expert? Answer questions, earn points and help others
