Question about Behringer EUROPOWER EP2500 Amplifier
Ep 2500 behringer not wlorking on briged node the red light on
Ep 2500 behringer not working on bridged node the red light ON on channel a every time i switch on bridged mode pls help to fix this stuf
robotek
  • 1512 Answers
SOURCE: Behringer ep 2500
sounds like you may have a phasing problem with the 4 speakers connected in series. This has the effect of cancelling the bass out. Check that you have them all wired as say "stripe" to negative terminal on the speaker. I use this as a rule of thumb to be sure there are never any phasing problems. they all(speaker boxes) need to be facing the same way for bass to propagate well. Check that you have bridging OFF and all settings to "stereo" SAny other settings you are not sure on, just ask me here :)
Posted on Jan 19, 2008
  • 3 Answers
if after the pop it smells like a firecracker just went of than you fried the circit for that speaker or if it has fuses on it or ferther down the wire check them but it could be just the radio and nothin to worry about:)  a friends car does it, and it is very anoying
Posted on Jun 02, 2009
  • 4234 Answers
SOURCE: power supply problem in a pmp 3000 behringer miker
I am not familiar with the particulars of your specific model, but with switch mode supplies in gereral, look for defective filter caps on the output side or a defective Zener Diode. If you can post a few photos of the power supply section, I may be able to guide you to the likely parts. Dan
Posted on Jun 08, 2009
VOTIT
  • 2071 Answers
SOURCE: power supply problem in Behringer pmp 3000 mixer
Just try to resolder all component parts in power supply section,maybe there is a loose connection or cold solder joints that causing of abnormal voltage or missing voltage.Also check the resistor for cange value causing the voltage trap.Check also all electrolytic capacitor for leak. Hope it may help you;;
  • 382 Answers
SOURCE: how to clean a behringer ep-2500
Absolutly, I serviced amps for years and prefer a vac and dry brush over compressed air that can blow dust into controls.
Cheers,
Kevin
Posted on Nov 18, 2011
Accidently had peaker connect to A side while in bridge mode wud mixer be damaged
Hi, When an two channel (stereo) amplifier is connected in bridge mode the polarity of one channel is reversed, for this example say channel B. An identical (mono) signal is applied to both channel inputs.
The output is now connected between the two channel +ve outputs. As channel A's output goes +ve , channel B's output goes -ve, thus doubling the output voltage.
On this Behringer powered mixer, the bridge switch simply connects the power amp section inputs, the required way.
The bridged output is wired to the B output between pins 1+ and 2+ of the 4 pole Speakon connector. (Because usually pins 1+ and 1- are used, stereo operation is unaffected.)
So.... If you connect a speaker from the A output alone then I would expect it to work, BUT if there is already a speaker connected from the bridge output, then what happens will depend on the amplifier design.
At best the A channel will see too smaller impedance, and hopefully shutdown.
This is a Behringer, it has digital (class D) power amps, and it does Not claim any amplifier protection !!!
If the powered mixer works in normal stereo, then it is probably OK.
If it then does Not work in bridge mode it is likely to be the connector wiring.
All the best.
Apr 07, 2014 | Behringer Pmp4000 Europower 1600-watt...
How to clean a behringer ep-2500
Cheers,
Kevin
Nov 18, 2011 | Behringer EUROPOWER EP2500 Amplifier
I have just bought an Behringer EP4000 amp. How do I connect 2 x B1520 and 1 x B1800X speakers to this amp? Thanks!
You don't (unless you want two B1520's on one channel and the sub on another). Reading the manuals would help.
The EP4000 amp drives only two channels. It CAN be bridged for one speaker but it won't support two channel and bridged mode simultaneously.
http://www.retrevo.com/support/Behringer-EP4000-Amps-manual/id/23591dj795/t/2/
The B1520 subwoofeer is PASSIVE so it will need a dedicated amplifier to power it and control its volume independently of other speaker channels.
http://www.behringer.com/EN/Products/B1800X.aspx
Aug 31, 2011 | Behringer Eurolive B212A Speaker
Diagrama completo del amplificador de audio behringer ep 2500
Un cordial saludo nesecito un plano del Behringer Ultrabass BXR1800H
super urgente
ATT/ CARLOS
hk3moa@yahoo.com
Apr 07, 2011 | Audio Players & Recorders
What is the rms power output of ep 2500?
This unit has the following output specs:
2 x 1200W into 2 Ohms (stereo)
2400W into 4 ohms bridge mode (mono)
Dan
Aug 17, 2010 | Behringer EUROPOWER EP2500 Amplifier
Drive V-600 Car Audio Amplifier: lost rt channel...
you have blown out the channel expesive to fix you will have to now brige the unit to run the extra speakers for bridging diagram email me
May 16, 2010 | Crunch Drive V-600 Car Audio Amplifier
My clip light stays on behringer ep 2500
DISCONNECT ALL INPUTS(MIC CD) AND CHECK.DISCONNECT ALL OUTPUTS AND CHECK(ALL SPEAKERS ONE BY ONE)IF THE PROBLEM CLEARED WHEN YOU DISCONNECT ANY INPUT OR OUTPUT FIX IT BY CHANGING START WITH CABLES FIRST.
Dec 20, 2009 | Behringer EUROPOWER EP2500 Amplifier
Behringer ep 2500
Jun 01, 2009 | Behringer EUROPOWER EP2500 Amplifier
How would i conect a ep2500 amp two 2 subs @ 4 ohms, or 8ohms
hey" i got 2 behringer 2500 amps and i have 2 peavey speaker that are 4 ohms 2000 watts eachand want to mono the amp separte,and i want to run 1 amp to each speaker so can you help me?
Nov 26, 2008 | Behringer EUROPOWER EP2500 Amplifier
Behringer ep 2500
Jan 15, 2008 | Behringer EUROPOWER EP2500 Amplifier
Behringer EUROPOWER EP2500 Amplifier Logo
188 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
