Question about GPX Karaoke Party Machine CD+G Portable Karaoke System - Blue
GPX Karaoke System JD402B does not turn on - GPX Karaoke Party Machine CD+G Portable Karaoke System - Blue
Can seem to view the lyrics on screen of my new gpx karaoke party machine, can you help me?
You MUST use SPECIAL Karaoke disks that have the lyrics... Is that what you are using?
Jun 26, 2011 | GPX Digital Products International Karaoke...
I just received a GPX JM250S Karaoke Party Machine. I have not tried a actual Karaoke CD yet. I plugged ipod in. Problem is- music is playing, then when I speak into mic music stops playing. There is no...
The music to sing along with apparently MUST come from a disk played on the unit. It appears that the external audio jacks are just to use the unit as either a boombox or to drive a larger sound system. You will have to convert your IPOD music into a Karaoke compatible CD to be able to sing along with it... They probably detect MIC input and mute any incoming signals from the RCA jack inputs,
Dec 26, 2010 | GPX Karaoke Party Machine
Need emerson karaoke HD 515 manual
retrevo.com or walmart (where they still sell it).
Mar 02, 2010 | GPX Karaoke Party Machine CD+G Portable...
My gpx karoke machine will not play at all power is on, shows cd number but no sound at all
Here are some things to try:
  1. Take the cd out, turn off the power, unplug the machine, plug it back in, turn on the power, put cd back in and try again.
  2. Check whether other cds play in it or if is it just this disc. Perhaps the disc is not compatible with the player. Might wanna check on that.
  3. Is the volume knob turned up?
  4. Does the mic work or is it just the cd? This will tell you if it is the disc or the machine that is not functioning properly.
  5. If no compatible disc works and the mic doesn't work and the volume is turned up, it "sounds" like the machine is defective.
Hope this helps. I'm a singer, so I wanna get you singing! Good luck.
Nov 04, 2009 | GPX Karaoke Party Machine CD+G Portable...
Open Questions:
GPX Karaoke Party Machine CD+G Portable Karaoke System - Blue Logo
35 people viewed this question
Top GPX Audio Players & Recorders Experts
Sandy Moore
Sandy Moore
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
