Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Volume problems Hitachi 50" LCD rear projection tv. After setting the volume to any number to listen, suddenly drops down to zero. I then have to turn the volume back up. Happens constantly.
  • johnnydr May 18, 2009
    Problem with the volume happens with either factory remote, or the direct-tv remote.
    Sergeant:
    Champion:
  • 255 Answers
Are you using a remote?
Posted on May 18, 2009
I set the volume to 40. After a little while the volume starts dropping down. If you do not turn the volume back up the volume will eventually go to zero all by it self and turn off the system.
HDMI Audio drop out? - ecoustics.com
www.ecoustics.com > Forum > Home Video Forum > HDTV Forum
Sep 21, 2005 - My Panasonic TH-37PX50U plasma has an audio drop out problemwhen .... The drop out occurs on both TV sound and receiver sound. ... very littlebass effects when playing DVD's through the HDMI cable when I compare it to ....Most noticeable when I turn down the volume control on the set top box (and ...
Dynamic volume problem : Ask Audyssey
https://audyssey.zendesk.com/.../20013893-Dynamic-volume-problem
Apr 8, 2011 - it appens only when dynamic volume is ON (day, evening or midnight) . the audio signal of the TV is on a optical Toslink cable and it ... and so it drops thevolume to make sure the sound will not be too loud. ... April 11, 2011, 12:40 AM .... Setthe audio setting on the receiver to Stereo vice Surround Sound.
How do I stop my surround sound system cutting out? - TV DVD HDMI ...
ask.metafilter.com/.../How-do-I-stop-my-surround-sound-system-cutting...
Jan 21, 2009 - When the volume is at higher levels, all but the center speaker cuts out..... That is why I just turn down the TV's speakers to 0 and listen to things from thereceiver. ... notice that the sound is coming 40ms later or earlier than the video). ...system), and adjust the A-V delay on the receiver until the audio lag is ...
Jan 06, 2016 | Audio Players & Recorders
Very low volume on phillips big screen tv
From the model number it is a older set (model listed here).
Simple things: if using a cable or sat box to it via rear jacks etc volume may be turned down on the box!
A few sets in menu have volume limiter--in main menu audio section
Also and last check to see if with a DVD etc hooked to one of the rear sets of jacks if same problem....rules the set in or out for this problem.
If none of this helps--audio circuit problem and shop repair.
Apr 17, 2012 | Philips Magnavox 9P6034C 60" Rear...
Panasonic tv turns volume down by its self
there might be something wrong with the tv remote. turn the tv on then make it on a high volume then put the remote in a different room and see if the volume turns down if it doesn't then you have some thing wrong with the remote not the tv.
Jan 15, 2011 | Panasonic PT-50LC14 50" Rear Projection...
My tv has no volume,i checked every cable connection and it all fine.I know my speakers are fine in the tv everything was fine until a button was pressed on one of the remotes the tv or the direct tv...
Remove all batteries from your remotes. Unplug the unit for several minutes. Plug unit in and use the controls on the set to turn it on and adjust the volume. This will eliminate the remotes. They could have a button stuck. If this does not work you may have a legitimate problem and need a tech.
hardrocko
Feb 01, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Hum in sound volume
It could be a few things. The first thing you want to look at is make sure that the microphone is muted in the mixer controls of your audio cards. These settings are located in the control panel. If you need the mic, look under the advanced settings under it and disable the 20 db option for it.
If that doesn't work I have a few other ideas.
Mar 17, 2009 | Proscan 32LB30QD 32 in. LCD TV
Cannot raise or lower the volume
resorted contacts on bottom of control board.
Feb 16, 2009 | Hitachi 50UX57B 50" Rear Projection...
No Volume from the set
you will need to go under the settings for your tv and find the volume control and reset it to internal dpeakers and take it off of external.
Feb 07, 2009 | Hitachi 50CX29B 50" Rear Projection...
Hitachi L26H01U headphone socket doesnt work
User problem!! The main TV volume and the headphone volume work independently so you can have the TV volume set at zero and use the headphone volume. However I suggest getting a pair of headphones with it's own volume control.
Dec 26, 2008 | Hitachi 26HDL52 26 in. LCD Television
Projection 52" lcd
so use the warranty as is less than a yr old let them fix it....
Aug 09, 2007 | Hitachi 60V500 60" Rear Projection...
Hitaci volume problem, pls help !!
My problem is solved. There is a separate volume control on my HD cable box that had been turned down. By turning it back up the issue was corrected.
Jun 18, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
162 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
