Question about Western Digital Scorpio WD1200BEVS 120 GB SATA Hard Drive
Wd3200bevt 320gb firmware - Western Digital Scorpio WD1200BEVS 120 GB SATA Hard Drive
  • Eric Andersen Feb 12, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
I have a lenovo lap top i turned on my laptop it it has a blue box that says harddisk security SATA PORT 0 WDC WD3200BEVT-24A23LOCK
that may be a virus/.
shut the computer off cold with power button, wait 20 seconds and restart it.
something has locked the hardrive
Aug 02, 2017 | Lenovo Computers & Internet
Driver
On connecting your disk, your computer should automatically search the internet for the correct driver if it is not present on your computer already. (for this to happen you need to be connected to the internet already and to have a system up and running). WD products use the Microsoft drivers. Please describe the configuration of your system in more detail.
12.April.2014
Nov 29, 2013 | Western Digital WD3200BEVT-00A0RT0 - 320GB...
Hard drive failure
It's just a Western Digital 320GB SATA harddrive,
http://www.ebay.com/itm/WESTERN-DIGITAL-320GB-WD3200BPVT-22ZEST0-HHBVJHNB-SATA-/170612627298
$229??????
I almost fell out of my chair! lol!
A 320GB SATA harddrive that is 2.5 inches across in width, (Regular laptop size) is W-A-Y cheaper than THAT!
http://www.ebay.com/itm/WESTERN-DIGITAL-WD3200BEVT-22ZCT0-See-list-for-DCMs-320gb-2-5-Sata-HDD-/200882121314?pt=US_Internal_Hard_Disk_Drives&hash=item2ec581ea62
Regards,
joecoolvette
Jan 23, 2013 | Packard Bell Computers & Internet
Unprotect a external drive wdc wd3200bevt-22zct0
You have to be the computers administrator to change any values on any hard drive on your computer click start control panel user accounts on the users tab click the name of the computer administrator you must have full control click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
Hope this helps.
Dec 21, 2012 | Western Digital WD3200BEVT-22ZCT0 Scorpio...
SMART Failure Predicted on Hard Disk 0: WDC WD3200BEVT-75ZCT2-(S1) WARNING: Immediately back-up your data and replace your hard disk drive. A failure may be imminent. Press F1 to Continue
just means its time to backup all your information, as if the hard drive does fail theres a good chance you may lose some or all of your information.
hard drives aint that expensive around 30 pounds +
and you can replace it with any sata hard drive.
Jun 17, 2012 | Western Digital Computers & Internet
Hi there , i have an acer travelmate 6592 laptop , the original 80 gig hard drive crashed , and i dont have the recovery disc , the hidden partition wont re install either , i have bought a new 320 gig...
You cannot get the full 320Gb capacity because the BIOS can only support a maximum of 127Gb.
You only hope is a BIOS firmware upgrade that can support 320Gb. Check out the Acer WEB site to see if a BIOS upgrade will solve your problem.
OTHERWISE
Install a 127Gb hard drive in your Acer and put the 320Gb hard drive in an USB hard drive adapter case and use it as an external USB hard drive because it is not affected by the BIOS limitation.
Jun 13, 2011 | Computers & Internet
How to remove write protection my transcend storejet 320gb. Now I'm just using 32Gb of space and that's it, I can't copy anything. But property shows me 278Gb of free space. HDD- WD3200BEVT-00A1TT0...
try right clicking and going to the properties and and reset the permissions of the drive. some times the user account will be write protected and the default hidden admin account will have full access.
Feb 28, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
I need driver software for my external hard drive. I have the 320GB Simple tech.
drivers should be on the drive! on desktop- click on my computer, click on drive letter (right click)- click on properties- or click on 'open' - if it shows driver files, double click and install drivers, or you may need to format it!
good luck!
Oct 11, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Open Questions:
Western Digital Scorpio  WD1200BEVS 120 GB SATA Hard Drive Logo
93 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
