Question about Acer Aspire T310 PC Desktop
Ram question will ddr400 ram fit in a ddr333 slot? if not what will?
  • 1 more comment
  • claytondean May 18, 2009
    awsome dude , quick answer, yeah it is a t310, was hoping 400 mhz whould work, u know anything bout setting up a media center?
    can you run 333 and 400 togeather?
    yeah i thought that might be the case, thanks for ya help, any info about the media center thing will be apriciated.
    cheers
  • Acer Master
  • 13,433 Answers
Yes ddr 266 - 333- 400 are the same shape just different speed.
if your computer is the aspire t310 it should work perfectly if you have anohter model please check with me first.
Posted on May 18, 2009
  • Ekse May 18, 2009
    according to acer it supports 400mhz and the maximum amount is 2GB or 2048MB. Post another question and lets see.
  • Ekse May 18, 2009
    I found your mediacenter question and I'll look into it, well if you have 333 and 400 together then the computer will run both or all with the lowest speed that is used on the machine.
    so if you have 333 all memory will run at 333 or if you have 266 as the slowest then all the memory will run at 266mhz.
I need to upgrade my pc ram, pulled the ram and infineon is the manufacturer, they no longer make ram so how do I know what other ram I can put in my motherboard, got number from stickers on the...
Look for labels on the RAM: PC100 or PC133 or DDR266 or DDR333 or DDR400 or PC2100 or PC2700 or PC3200.
Since you cited 'DDR400', you need to purchase 'DDR400' RAM.
Any sales-person in any computer-store can sell you 'DDR400' RAM.
Feb 03, 2011 | Abit NF7-S (V2.0) 400MHz FSB nVidia...
I am using Intel D865GBF board having Dual Channel DDR400/333/255 SDRAM memory support. It is of 3GHZ, 256 MB RAM. The other day I bought 1GB RAM of Transcend and tried fitting the same. But the PC never...
Yes it can support 1GB ram. Max capacity up to 4GB of ram, meaning 1GB each on each slot. Make sure that the memory that you will be installing are either DDR400, DDR333 or DDR266. It could be the RAM is faulty if the one you bought is the DDR's that I mentioned
Oct 11, 2010 | Intel D865GBF Motherboard
I PLUG IN 2 NEW 512 MEM PCBS & WLL NOT BOOT. 1 BEEP FOLLOWED BY 3 BEEPS FOLLOWED BY 3 BEEPS FOLLOWED BY 1 BEEP. THEN NOTHING.
Remove the "new" RAM.
Look at the labels for PC2100 or PC2700 or PC3200,
or for DDR266 or DDR333 or DDR400.
Compare with the label on one of the "old" sticks of RAM.
Be sure that the labels on the "new" RAM are "equal" or "higher" than the labels on the "old" RAM.
For example, if the "old" RAM are DDR333, then you can use DDR400, but your computer will not accept DDR266.
Reinsert one of the sticks of the "old" RAM.
Does it still beep multiple times?
If not, then the new RAM is *NOT* compatible with your computer.
Jun 15, 2010 | E-Machines T1742 PC Desktop
ASUS P4S533-MX MOTHERBOARD FAILED TO RECOGNIZE DDR400/DDR333 RAM
In you case compatibility is your problem or your memory needs a clean up. First clean up the memory's pins. Use a pencil eraser. Then try only one by one so that you will know if there is a problem in each memory. Insert one of the memory then turn on your PC. If it boot up or it is okay try the other one. Then if it is also okay, try both of it inserted and turn on your PC. If it not okay there is a compatibility problem. Make sure the brands are the same so the compatibility are never be a problem.
Mar 10, 2010 | ASUS P4S533-MX Motherboard
Using the A7V8X board, how can I achieve 3gig of ram? The chips I have found are double sided 1 gig chips, and your board only hold 4 sides (3 slots) Although the BIOS sees the 3072MB Ram, it cannot use...
When using DDR400 (PC3200) the system supports a maximum of 2 banks of memory, when using DDR333 (PC2700) the system supports a maximum of 4 banks of memory. A single DIMM will either have 1 or 2 banks of memory, so the best bet seems to be 3 x 1gb single sided ram strips.
Jan 26, 2010 | ASUS Computers & Internet
Where do i put he memory
From the manufacturer's web-site:
http://www.msi.com/index.php?func=proddesc&maincat_no=1&prod_no=557
look at the "green" slots in the picture of the motherboard.
That's where the RAM goes -- note that the RAM has a "notch" that is *NOT* in the "centre" of the stick; so, the RAM only fits *ONE* way into the slot.
On that web-page, it says:
• Supports six memory banks using three 184-pin DDR SDRAMs.
• Supports up to 3GB memory size.
• Supports DDR400/DDR333/DDR266/DDR200 SDRAM
Note: PC3200 (DDR400) maximum 4 banks only.
So, if you buy DDR400 RAM, the maximum is 2GB (2 sticks @ 1GB/stick); if you buy DDR33 RAM, the maximum is 3GB (3 sticks @ 1GB/stick).
Dec 01, 2009 | MSI Microstar KT6 Delta (MS-6590)...
Is their a special make of memory card, ie: ddr
According to: http://www.shopping.com/xPF-VIA-MB-FOXCONN-VIA-KM400A-400M01-G-6L-R
this motherboard has 2 slots for DDR (184pin) RAM,
and supports a maximum of 1GB of RAM per slot.
Note that DDR RAM comes in 3 speeds: DDR266 (slowest), DDR333, and DDR400 (fastest).
Buy the fastest RAM -- if the motherboard cannot run the RAM at "full" speed, the RAM will automatically slow itself down to a speed that the motherboard will support.
Sep 15, 2009 | Foxconn 400M01-G-6L Motherboard
Can I use DDR2 800 MHz RAM on GA-K8NS-Ultra-939-Socket-939 MBoard
I don't think that that motherboard will accomodate the DDR800 you probably need a DDR333 or DDR400.
Calling the manufacturer support will render better information because they made the board. The memory you refer to may not fit the slot for this particular motherboard.
Aug 13, 2009 | Computers & Internet
K7VT4A-Pro Mobo
Greetings,
The motherboard will read 1GB DDR400 memory per slot only.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 19, 2008 | Asrock K7VT4A-Pro Motherboard
Recommended memory for p4i45gv R5.0
IF UR RAM IS SDRAM THEN U CANT UPGRADE TO DDR BUT IF ITS ON DDR RAM THE U SHOULD B ABLE 2 UP GRADE 2 1GIG OV DDR RAM RUNING AT 400MHZ
Dec 25, 2007 | Asrock P4I45GV R5 Motherboard
Acer Aspire T310 PC Desktop Logo
97 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
