Question about Mastercool 67680 Evaporative Cooler Air Conditioner
Question regarding Mastercool Evaporative Cooler
I have a 5500 CFM Mastercool that I installed last year. This is mounted on the roof and ducted into our 1249 sq. ft. house. There is a difuser directing air into 5 seperate rooms and a extension duct feeding the dinningroom, spare bedroom and second bathroom.
For the first two months or so it worked fantastic. It kept our house really cool. After a time the water line broke feeding the float tray. I called the service company that installed the unit since it was under warrantee and they came and repaired the broken line. Since then it never worked as efficient as it did proior to the water line breaking.
I understand the consept of how they are supposed to work i.e. temperature and relative humidity. But it seems that the volumne or should I say CFM has deminsihed in relation to the first two month or so. I have checked everything I know to check and cannot locate the problem. I have installed up-ducts in order to create air exchange to cool down the attic and it helped a little.
I wonder if the service company could have changed the shives (pulleys) without me knowing about it since it has never worked as well as it did before they repaired the water line. I know this sounds far fetched but who knows? I have heard of shaddy repairs just so they can get another service call.
So since I don't have any litterature on what size shives this unit requires. I was wondering if anyone of you could help? Also I was wondering if there are any modifications I can do in order to increase the CFM without blowing the circuit breaker?
I have also heard of the double unit where the air is pre-cooled prior to the actual pad. can anyone enlighten me on this?
Thank You,
Best Regards,
J.D.C
P.S. As of right now we have to run two evaporative coolers in order to keep the house comfortable.
  •  xxxx
    xxxx May 11, 2010
    Start with making sure the unit is getting enough water after the "repair". The cooler pads must be fully wet to get a good result. When you report back, if possible report the temperaure coming out of the vents, the outdoor temperature and the humidity.
This is just a slight possibility. You may have inadequate exhaust. Open more windows or doors. For every 1,000 CFM of air delivery 2 sq. ft. of unrestricted air relief is required. Check the water distribution system for insufficient water to the pads. Check the pads to ensure they are not clogged and clean if needed.
Posted on Jun 25, 2009
  • Rosemary Brown
    Rosemary Brown Jun 25, 2009
    Sorry, somehow I missed where you did the up-duct install to cover for exhaust/air exchange.
We have an older swamp cooler and need to have some windows in our home open to get best cooling. Does a mastercool need to have some windows open in our home to give max cooling?
The solution is to install "up ducts" These devices are easy to install and are fairly cheap. With a swamp cooler the best way to use them is to allow them to draft outside with the "up duct" you get the drafting to the outside but also get to remove attic heat too.
Apr 24, 2011 | Mastercool 67680 Evaporative Cooler Air...
Have 2 evaps on roof shut main water feed valve off. There is some water in pan of one and dripping on my new roof. Wondering why there is water in pan? can you help
Yes, there should be a water/condensation pan under it with an overflow drain that takes the water down off the roof. Perhaps, whomever installed your new roof, removed the drain tubing and forgot to put it back.
Apr 13, 2011 | Mastercool 67680 Evaporative Cooler Air...
Do they make some kind of transition for the side discharge MasterCool MasterCool Evaporative Cooler, ASA71 So when I cut open the side of my house I have a way to vent it thur the wall. Is there a kit...
Best way is to get a sheetmetal shop inyour area to make one for you.. Give them the exact size of the opening and then tell them you want a 3/4" flange all the way around and make sure the duct connection is what you need.. Let us know if you need anything else.. please vote.
Sep 05, 2010 | Mastercool 67680 Evaporative Cooler Air...
Evaporative cooler, flap on roof will not open?
Most rooftop evaporative coolers use a gravity activated damper called a barometric damper. They do not use electricity and can often be found in the ductwork that bridges the cooler to the roof.
Look for a metal plate on the front of the ductwork held on by two screws. Remove that and you should be able to remove the damper to service it or replace it. You can find replacement evaporative cooler dampers online if need be.
Jan 08, 2010 | Mastercool 67471 Evaporative Cooler Air...
We have a Mastercool II & it was installed ~ 3
The pads you need are at least 8 inches thick. If you have the contractor model, then the pads will be 12 inches thick.
Find a distributor in your town that sells cooler parts, if they dont have them, some of the big home improvement stores carry the pads for your cooler.
Make sure you are using a bleedoff or a dump pump to eliminate the hard water out of the cooler. If you keep those pads clean, they wiil last for many years.
Jul 20, 2009 | Mastercool 67680 Evaporative Cooler Air...
My husband wants to install a mastercool evaporative cooler in a building that is completely open on one side. We live in AZ.
It will work fine as a spot cooler if he has direct airflow on him, otherwise it wont do much for cooling the building.
Jun 30, 2009 | Mastercool 67680 Evaporative Cooler Air...
Master cool blower motor?
If this is a regular roof mounted unit then I will suggest that the motors internal clutch could be failing. If your unit is ducted then it could be something in the duct like paper. Sometimes as the wind flows through flex ducting it can also make this sort of noise.
If this is a portable Evap cooler then there is a rod that extends from the main blower to the pump assembly. You can probably see it turning with a flash light. If it is wobbling then it could be the pump or gear. As usual make sure the unit is clean and all the water ways (including the hoses) are clear of obstructions.
Jun 25, 2008 | Mastercool 67471 Evaporative Cooler Air...
Mastercool 67680 Evaporative Cooler Air Conditioner Logo
932 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
acrman404a
Level 1 Expert
Steve F
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
