Question about Cycling
I need a manual for adventurer 12 speed folding bike
2 Suggested Answers
  • 1138 Answers
SOURCE: operator manual for huffy crosswind bike grip shift
Look for the manufacturers name and model number on the gripshift and check at www.parktool.com. Look under derailleurs for repair tips which will give you an idea how they work. A twelve speed has six gears on the rear sprocket and two on the crank giving you a combination of twelve speeds. sheldonbrown.com is another good site with good articles and pictures.
Posted on Jul 17, 2009
Can I get a new shifting lever for my Adventurer Folding Bike made in 2011
Yes, you should be able to get a new shift lever. The lever is not specific to your bicycle, just needs to be compatible with the derailleur(s). A bike shop can help you select the correct one.
Oct 22, 2017 | Cycling
How do the gears work
Have a read and watch some videos.
  • How do Bike Gears Work? ' Design Squad - YouTube www.youtube.com/watch?v=oauDyIu_swM
    • BY DESIGN SQUAD GLOBAL
    • 3 MIN
    • 107K VIEWS
    2012-10-12 · How do Bike Gears Work? ' Design Squad ... What Is Inside A Bike Freewheel/How Does It Work? - Duration: 3:56. RJ The Bike Guy ...
  • Bicycle Gears - How Bicycles Work ' HowStuffWorks adventure.howstuffworks.com/outdoor-activities/biking/bicycle3.htm Bicycle Gears - Bicycles aren't just for kids. ... How Bicycles Work. by Marshall Brain Adventure ' Biking. Bicycle Gears. Prev Next . You have ...
  • Bike Gears: How Do They Work - Sportive Cyclist sportivecyclist.com/bike-gears-how-do-they-work Now, if you'd like to learn more about bike gears, and chainsets in particular ... Bike Gears: How Do They Work (learn what terms like '53/19? mean) ...
  • Bicycle gearing - Wikipedia, the free encyclopedia https://en.wikipedia.org/wiki/Bicycle_gearing Bicycle gearing is the aspect of a bicycle drivetrain that determines the relation between the cadence, ... Hub gears work using internal planetary, ...
  • How to use Bicycle Gears ' Gears on a Bike bicycleuniverse.info/eqp/gears.html How to use Bicycle Gears. ... This works because the higher gears move you farther for each spin of the pedals, making you do more "work" ...
  • Hub gear - Wikipedia, the free encyclopedia https://en.wikipedia.org/wiki/Hub_gear A hub gear, internal-gear hub, or just gear hub is a ... 1959 Elizabethan Apr. 35/1 My lightweight bike with 4-speed hub gear ...
  • Technique: How to use your gears efficiently ' Total Women ... totalwomenscycling.com/...how-to-use-your-gears-efficiently-9497 Total Women's Cycling . ... Find out how to change gears on a bike and learn to use your gears efficiently, ... Liked this guide on how to use your gears efficiently?
  • How do bicycle gears work? - Ask.com www.ask.com > ... > Biking & Cycling > Bicycles Bicycle gears work by moving the bike's chain on varying chainring and cog combinations to match the desired drive wheel speed, cadence and pedaling speed of ...
  • Apr 21, 2016 | Cycling
    Adventurer folding tandem bicycle manual
    sorry but you need to contact the proper site to get that stuff we have no idea
    Jan 12, 2014 | Motorcycles
    How to make a 2005 ktm 50 mini adventure faster with out parts
    Thank you for contacting FixYa with your inquiry.
    If the bike is running correctly and RPM's through all the gearing range you are probably at the bikes optimum speed range with present set up as is.
    If it's down on power or faltering while running we probably need to do some tuning or replacement of power components (Piston & Rings, Gaskets etc....) Check the spark plug after running and make sure it's a cocoa brown color and the jetting should be correct. Check the manual for jetting instructions if the color is off.
    The simplest speed increase is gearing (requires some in-expensive parts). Easiest way is to go up one tooth on the primary sprocket and add a master or half link to the chain (if needed) to adjust the length. Would try only 1 tooth increase at a time to test.
    In Oregon we many times use the stock primary sprocket when running in the mountains, up one tooth for running in the desert, and up 2 teeth on the primary when running over 100mph down in Mexico. This mostly applies to the big bikes but it's the same for the mini's.
    Hope this helps and thanks again for contacting FixYa.
    TF
    Jul 04, 2011 | 2005 KTM 50 Mini Adventure
    I need an owners manual for a roadmaster mt storm by huffy
    The best I can do is to provide you with the manual that Huffy provides for multiple bikes. The manual below is for multi-speed and freewheel bikes.
    Huffy Multi-speed Manual
    Hope this helps. Thanks for using Fixya.
    Note: If the manual link above is not useful you may contact Huffy directly at:
    Huffy Bicycle Company
    6551 Centerville Business Pkwy
    Centerville, Ohio 45459
    (800) 872-2453 customer service
    Monday - Friday: 8:00AM - 12:00PM; 1:00PM - 4:30PM EST
    Jul 13, 2010 | Huffy Men Mountain Bike (26")
    Assembling a Dahon D7...
    The manual is available here:http://www.dahon.com/support/manuals.htm It looks like the seatpost and seat are meant to be left in the bike.
    Nov 23, 2009 | Dahon 7 Speed Folding Bike
    Dahon Vitesse: i have tried to tighten my folding mechanism in
    Here is one manual:http://files.dahon.com/support/manuals/2009/2009_16inch_20inch_fold_unfold_guide.pdf Here is a much more detailed manual:http://files.dahon.com/support/manuals/2009/2009_dahon_user_manual_en.pdf It looks to me as if the handle bar stem has to be up high enough so that the end of the stem will clear the fold when you fold it down. Otherwise the stem will be down inside the bike and it won't be able to fold. If that makes any sense.The better manual has good pictures and diagrams and explains the locking mechanisms a lot better. Please rate me if this helps.
    Nov 22, 2009 | Dahon 7 Speed Folding Bike
    I HAVE A 05 GS1150 AND WANT TO KNOW WHAT GRADE ENGINE OIL GOES INTO IT!!
    Find downloadble version of workshop manual here: http://www.ebooksquad.com/2007/12/02/bmw-r-1150-gs-evo-adventure-maintenance-schedule.html
    This has all the details you need.
    Jul 13, 2009 | 2005 BMW R 1150 GS Adventure
    Cycling Logo
    142 people viewed this question
    Top Cycling Experts
    Michial Gueffroy
    John Egan
    John Egan
    Are you a Cycling Expert? Answer questions, earn points and help others
