Question about HP 1040 Plain Paper Inkjet Fax
Recording option I am a writer and I do telephone interviews on the phone. The HP1040 is not letting me do that. I also have an extension line. I used this little gadget that plugs into the tape recorder and into the fax machine, but I am unable to get it to work. It just won't record. I have try different combinations with the fax itself and the gadget but nothing doing. Can someone help? Thanks very much in advance.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
Here is the manual if you don't have it
http://www.retrevo.com/s/hp+1040++fax++manual
Posted on Jan 22, 2008
HP LaserJet 3055 .fax not working
Direct Line:
1.Check telephone line.2.Make sure telephone line is connected in line in port not in extension.3.connect extension telephone phone to the device & check for the dial tone.
Dial the number and observe weather extension phone is ringing?
A. *If extension phone is ringing check display is there any message like "ringing".. wait till fax tone comes,if not check "basic fax settings"... if setting are OK .. Replace formatter
B. *Extension phone is ringing no message displayed on device replace "LIU" card..
If extension telephone is not ringing check telephone line..
No out going faxess:
*Check line is connected though EPABX , if connected Check..prefix setting..
*Check out going..
Best of luck...
Sep 06, 2011 | HP LaserJet 3055 All-In-One Printer
Cable to record telephone interviews with Sony ICRecorder
Use an Olympus TP7 plug it into the mic jack and you should be good
Mar 26, 2010 | Sony ICD-B200 Digital Voice Recorder
I need to rerecord the greeting message for my phone system.
According to the instruction manual, which can be found at: http://telephones.att.com/docMgt/public/art/175/1872_manual.pdf,
TO RECORD AN ANNOUNCEMENT:
1. Press A.
2. Choose the announcement location by
pressing s until the appropriate
mailbox is displayed.
3. Press R. Begin speaking after the beep
4. When you are finished, press S.
You will hear your new announcement.
5. Repeat Steps 1-4 to record another
announcement
— OR —
Press S.
TO REVIEW YOUR ANNOUNCEMENT:
1. Press A.
2. Press s to choose the announcement
you want to review (A, B, C, AO,
MBOX 3, MBOX 4).
3. Press P to hear the selected
announcement.
Or, if you're away from the office,
CHANGING ANNOUNCEMENTS:
You can re-record any of the announcements
currently in use by any
line or mailbox.
1. Contact the answering system.
2. After two beeps press a number key
(1-4) to select a line or mailbox, then
press 4*. The system beeps and begins
recording.
3. Speak into the telephone in a normal tone
of voice.
4. Press # when you are finished. The
system beeps once and plays the new
announcement.
To review your announcement, press a
number key (1-4) to select a line or mailbox.
Press 41 after the two beeps to play
your announcement.
NOTE: If announcement is being used by
both lines, re-recording the announcement
will change the announcement heard on
both lines.
Hope this helps!
tkhusa420
Sep 25, 2009 | Lucent 1872 Corded Phone
Do not know which port to connect telephone line
there is only one line to connect to telephone. it same to the telephone connection line.
Nov 13, 2008 | Brother MFC 210C All-In-One InkJet Printer
Casio SI 460
You need to perform a system update on the new phone.
joequevedo@charter.net
Oct 30, 2008 | Casio SI-460 Corded Phone
Hi, I am setting up a canon mp730 for a friend. I have run into a problem with the fax phone line. I have connected the lines correctly to the copier and her answering machine but when I try to use the...
Remove the connection and once again try to re connect the lines between the copier and phone line . You might have some connection . Just give a try .
If this doesnot work . I will let you know how to proceed further .
Oct 12, 2008 | Canon Office Equipment & Supplies
Very bad recording
Be sure you are in the SP record mode and use the dictate conferance setting depending on your environment.
Oct 06, 2007 | Olympus DS-2300 Digital Voice Recorder
Can I use this fax on a telephone line together with a GE 2.4 GHz Cordless Telephone (Model 27992B)? Will it be possible to recive messages and faxes when no one is at home? Remark: The answering machine...
sure u can: Installation with an answering machine and/or extension telephone: 1. Remove the seal covering the TEL. SET jack on the rear of the fax. Connect an extension telephone or answering machine to the TEL. SET jack. 2. If desired, connect an extension phone to the answering machine. from the user Fax guide: If desired,you can also connect an answering machine or an extension telephone to your fax. ¨ Connecting an answering machine to the fax will allow you to receive both voice and fax messages on the same line while you are out. For details on using this feature, see Chapter 7. (Note: Do not connect an answering machine to your fax if you will be using the distinctive ring feature described in Chapter 2.) ¨ You can connect an extension phone to the fax to make and receive calls like any other extension phone on your line.
Oct 09, 2005 | Sharp UX 510 Plain Paper Thermal transfer...
HP 1040 Plain Paper Inkjet Fax Logo
48 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
