Hp t60m283 00
Laptop wont turn on with the battery and the charger plugged in
mewms_14904
  • 1027 Answers
SOURCE: wont turn on
Maybe that is why Dell makes an external battery charger.
It may be the ac power adapter (BRICK) is not putting out the required voltage/amps.
Posted on Apr 05, 2008
pontelemon
  • 531 Answers
SOURCE: laptop wont boot and the battery and power lights flash
"......no beeps and it is a 3rd party charger for this model of laptop."
That 3rd party adapter could be the problem. Also, try to take out the battery and power it up from AC adapter only.
Ideally, try to find original AC adapter just for testing.
Posted on Apr 16, 2009
  • 36 Answers
SOURCE: Laptop battery wont charge?
It could be the battery needs replacing ... it shows that the battery is charging but it doesn't keep the charge .....
Posted on May 23, 2009
SOURCE: My acer d250 laptop wont turn on unless it is plugged in
Clean the baterry connector port with an alcohol solution or Spirit solution.and try.
If you can get hand to another battery,check out if everything is fine.Otherwise replace the battery.
Check if you have warranty of the battery.
Posted on Dec 27, 2009
  • 4 Answers
SOURCE: FUJITSU SIEMENS S6010 WONT TURN ON, HELP!!!!
Hi, I have alot of Motherboards for that Laptop. Maybe a New Motherboard Needed. CPU May have Burned out?
Email: microxtremecomputers@live.co.uk
Posted on Feb 07, 2010
What does it mean when my hp desktop wont stay powered on unless my charger is plugged in
Desktop computers require power so you need to keep it plugged in. Laptops have batteries (making them portable) - if yours is a laptop and you have theses problems then either your battery is dead or you have a bad charger.
Sep 24, 2014 | HP Computers & Internet
Orange light trying charge
I would try this:
take the battery out
unplug the charger
turn upside down
hold power button down for 1 min
keep holding power button down as you turn over the laptop
while still holding power button down plug in charger and try to power on
Jan 26, 2014 | HP Computers & Internet
Its plug in but battery wont charge
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Nov 28, 2012 | HP Compaq nc2400 Notebook
HP Pavilion battery wont charge when charger first plugged in.
1. AFTER WINDOWS LOADED THE PUT YOUR CHARGER TO LAPTOP
OR
2. CHECK YOUR BIOS TO ALLOW NON-OEM BATTERY
OR
3. USE STAND ALONE CHARGER
Sep 21, 2012 | HP Pavilion dv6t Notebook
My hp 213 wont power on. what is the problem? could you please assist me
try to do this:
- remove the battery and charger (everything
connected to the pc) then press the power button
for 1 minute.. - plug back in the charger - after few secs try to turn it on
hope this helps :D
Mar 23, 2011 | HP 2133 Notebook PC
My laptop HP PRESARIO V1000 won't start without charger plug in. When push on, the charge led blinking for eight times then nothing happen. it start normally when I turn on with charger plug in, after...
It sounds like the Battery is Dead or not charging. You might try a local pc shop and see if they have any laptop batteries for you laptop. Or have them test to see if the battery is charging.
Dec 11, 2010 | Compaq Presario M2000 V1000 V2000 V3000...
Hi i have some problem to my laptop battery it wont charging, but laptop charger is working fine, my laptop brand is compaq presario C700. i tried to charge my laptop in 2 hours after that i tried to turn...
Did ur laptop works or turn on when u plug the adaptor charger?
If ur laptop turns on when the charger is pluged in, u got problem with ur DYiNG BATTERY!
Better buy a brand new battery!
Nov 08, 2010 | Compaq Presario 700 470024-192 Notebook
Philips X50 charging problems
1st remove Battery after few min insert battery and connect charger Then power on laptop.If not on check Power Mosfet or Power ic.
Jun 27, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Pavillion wont work with battery
First, I recommend you to try removing and reinserting the Battery when the Notebook is turned on and powered with the Power Adapter.
I recomend you to first clean the Battery Connectors by removing the Battery and use a Earbud to clean the Metal Connectors which connect to the Battery to remove any dust which is peventing from the Battery to supply the required power to the Notebook.
You can find some related topics related to troubleshooting issues related to Batteries in HP Notebooks from the links below :
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&docname=c00485351&dlc=en&lc=en&jumpid=reg_R1002_USEN
Additionally, you can download and install HP Battery Health Check SP3229.exe and check the status of the Battery by following the instructions.
Hope this helps...
Aug 27, 2008 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
