Question about Bosch SHU3036UC Dishwasher
How do I reset the aqua stop on the bosch shu3036uc dishwasher
  • 1003 Answers
SOURCE: ...dead
CHECK DOOR SAFTEY SWITCH OR TIMER MOST LIKE SWITCH ASSOCIATED WHEN DOOR IS CLOSED
Posted on Jan 18, 2008
Master_Tech
  • 770 Answers
SOURCE: How do you "undo" the aqua stop?
create an inverted trap in ther dishwasher drain line so the water cant back feed
Posted on Jul 09, 2008
  • 98 Answers
SOURCE: Very long cycle time for Bosch DW
There is a recall on the control board of many of these models, butyour problem is likely not related. I have written a guide to help. It is here. Thanks!
Posted on Jul 19, 2009
localwonder
  • 6784 Answers
SOURCE: I own a Bosch SHU3036UC not draining properly
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Posted on Aug 04, 2009
Richie_asg1
  • 1036 Answers
SOURCE: Bosch SHU3036UC/U11 dishwasher does not stop filling with water
It sounds as if the main program board has developed a fault - as it should come to a complete stop. The fact it kept the water valve open with the door open is a serious fault- so I would have it checked before using it again.
Most machines have a water-stop feature - so if it develops a leak - it will shut off the water. This clearly didn't happen.
Posted on Aug 05, 2009
How do I get to make it stop and work .Dishwasher is not shutting down it says E 15 Water tap flashing , and red Aqua stop light .
inlet valve is the aqua stop long hose to tap has a solenoid at tap end that is likely your fault
Sep 29, 2016 | Bosch Dishwashers
Can i remove the aqua solinoid cut off valve from bosch dishwasher
the valve and wiring can be replaced you cannot remove it altogether as it wont be able to fill up, bosch aqua stops are normally powered solenoids that also double as the water inlet valve unlike most other aqua stops
Sep 27, 2014 | Bosch Dishwashers
Pwering up after remodel
No reset anywhere on it. If it worked before then it most likely is the wiring to the machine
Jun 07, 2013 | Bosch SHU3036UC Dishwasher
I have a Bosch SHU3036UC dishwasher. While sitting idle - during the day or over night, it fills up with fresh water. I shut off the water supply last night and this morning it was dry. Any ideas?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 12, 2011 | Bosch SHU3036UC Dishwasher
Where is an Aqua-stop fitted in a dishwasher?
In the water inlet hose close to the valve on your supply end,its encased in a big ( 2") plastic housing with a brass fitting.
Hope this helps.
May 21, 2010 | Siemens 24 in. SE25A266 ExtraKlasse...
My bosch dishwasher takes 4-5 hours to finish the sycle, what is the problem
the last time i checked a bosch unit with that problem i replaced the module .it was bad. replace and that will solve the problem. let me know what happened.
Dec 22, 2009 | Bosch SHU3036UC Dishwasher
Aug 05, 2009 | Bosch SHU3036UC Dishwasher
Bosch SHU3036UC draining on wash cycle
it is probably going to be a grimy door thermostat between the inner and outer panel. its hooked into the back of the soap dispenser. someone would have to take the outer panel off then clean wipe away the caked grime from the thermostat and put it back in its place. if this doesnt fix it then it could be a heat assembly problem or timer problem. in that case you would need an appliance tech out
May 28, 2009 | Bosch SHU3036UC Dishwasher
Jan 05, 2009 | Bosch SHU3036UC Dishwasher
Jul 09, 2008 | Bosch 24 in. SGS43C02 Classixx Built-in...
Bosch SHU3036UC Dishwasher Logo
26 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
