Question about Acer Aspire 3610 15.4 Glossy WXGA LCD Display - 3613WLMi PC Notebook
Screen flickers, Ok when you "tap" side of unit. Something loose or bad connection.
How to access and replace inverter on Acer 3610?
  • smontalto May 18, 2009
    Thanks, my Acer has been good to me and I'd rather keep it than buy new.
  • Acer Master
  • 32,281 Answers
Most LCD inverters are located behind the screen bezel at the bottom of the screen near the hinges.
Posted on May 18, 2009
Flickering screen like bad flouresent bulb
you need to remove the back cover of the tv to gain access the internal part. and then you need to look if their is a loose contact or dry joint connector at the power inverter board for the screen back light. if the connection is good then their is a flickering the back light is need a replacement.
Nov 12, 2012 | Televison & Video
Acer aspire 3610 screen flickering
It sounds like your video cable or your Lcd Inverter cables might be loose. You will need to take the lcd apart to get to them. The video cable is on the back of the LCD screen at the top. Remove it, then push it back in and use a piece of tape over where it connects to hold it in place. Also remove the other end of the video cable from it's connection and plug it back in. The lcd inverter is at the bottom under the lcd screen. It has two cables going into it. Remove both cables and then plug them back in. Put everything back together and hopefully your problem of flickering will be solved.
Mar 30, 2012 | Acer Aspire 3610 Notebook
White screen of death
1.Your LCD screen inverter has blown and needs replacement.
this will need to be replaced by a qualified tech.
Apr 20, 2010 | Acer Aspire 3610 Notebook
Screen flickering
Not likely a bad monitor...
The monitor cable on the back of the computer is loose.
Could also be the screen setting that is difficult to achieve and maintain.
If the cable is already tight on both ends, you might try a lower resolution setting for the monitor.
1. Right-click anywhere on the desktop
2. Go to "Properties" on the drop-down menu
3. Select the "Settings" tab
4. Slide the Resolution knob to the left a little (1024x768 or 800x600) and press [OK]
Hope this helps
Sep 14, 2009 | HP Pavilion dv6000z Notebook
Screen flickering when turning on laptop and sometimes the laptop turns on after flickering and sometimes doesn't turn on at all after flickering. Just stays black.
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 01, 2009 | Acer Ferrari 5005WLMi (LXFR506119) PC...
After replacing my broken screen on a Acer Aspire 3610 15.4 I have no display ,only back light on the screen, It will come up on a cpu to the opening screen then blank . I have the origional cables to the...
If you get a normal ACER screen boot then it goes dim, then your inverter is probably bad.
Just swap the inverter and you should be back in business.
Mar 02, 2009 | Acer Aspire 3610 Notebook
Display flickers on acer travelmate 2410
so, did the new inverter fix the problem? and, when you were replacing the inverter, did you get to peek at the screen? ok ok, I'll make it easier than that. take your model number and search for "Acer 2410 LCD" on eBay, there are a lot of screens and none of them show a video cable that is glued or soldered to the screen. there are, in fact, a few video cables there as well, so my guess is that they are flat out lying to because 1) to get you to pay too much for repairs 2) because the person at tech support has no idea 3) they are sold together according to their parts list or 4) they really DO go together. My guess is that what they are talking about is a completely new LCD panel INSIDE a lid case with the hinges and bezel and all that. So SURE it's going to look like the cable is included, but if you just pop the back off the lid, it's probably about 10 minutes of work to replace the LCD without replacing the cable. I have to provide 2 caveats to this:
1) Acer is NOTORIOUS for glue. they love the stuff and may well have glued everything together inside the screen case.
2) I have no real experience with this specific model so I'm not sure.
It's just that every other screen ever is pretty much made of the same parts: an LCD screen with a backlight cable and a video input socket, an inverter if it's in the screen, mic, video camera, light, etc if they are in the screen, frame, back of case, and a video cable that goes from the video socket out to the mobo.
IS the display light flickering or the display image? that's important too. Good luck. it's my guess that it's either a bad connection a bad CCFL or was a bad inverter. the cables may have gotten pinched and that could be it too.
Feb 18, 2009 | Acer TravelMate 2300 Notebook
Acer Laptop Screen Flickering
The flickering screen indicates that it is a backlight problem with either a faulty inverter or inverter connection problem. The inverter is usually located at the bottom edge of the LCD screen, and may have one or two connectors (one for the video info. and one for the inverter power or a combined connector) attached to the motherboard under the case near the top edge of the keyboard near the hinges. Reseating these connectors may solve your problem.
Jan 29, 2009 | Computers & Internet
Acer 3610 LCD Screen
KiMar, The inverter board (changes DC to AC to keep the backlight on) in your Acer is going bad. It needs to be replaced.
Jan 18, 2008 | Acer Aspire 3610 Notebook
Acer Aspire 3610 15.4 Glossy WXGA LCD Display - 3613WLMi  PC Notebook Logo
98 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
