Question about House Brand Heating&Air Conditioning Booster Fan
Zoning not programmed
Hi, I have a new Brivis ducted heater but the installer never programmed the zones. It is a me30i. Does anyone know the step by step instructions to add the zones as buttons 4 & 5 dont even show the two zones. many thanks, Paul
    Problem Solver:
  • 6 Answers
Hi ill be honest this is a little tricky
There are many variations depending on a few things.
Is it heating only or add on refrig as well?
Is there a common zone or an area constantly open?
How many networker controls 1 or 2
So any way this is the set up for heating only 2 zones and common zone.
Turn the networker wall control off
in the off screen press the clock key (the time will flash)
hold down the 2 & 4 keys for about 5 seconds
depending on the model and what other appliances are lincked to it it will display either
H01 ID01 1500 (NC3 2004 onward)
1500 01 H01 (NC1&2 pre 2004)
press the (M or mode) button till you get to the N1 parameters eg N1 ID01 01
press the number 1 key or on older models top key
should then display should read
N01 ID15 01(COMMON ZONE)
Then using the dial to change the setting to read the same as below once done press the number 1 key or top key to advance to the next setting
N01 ID16 01(NETWORKER NUMBER)
N01 ID17 01(ZONE A)
N01 ID18 01(RELAY NUMBER ZONE 1)
N01 ID19 01(NETWORKER NUMBER)
N01 ID20 02(RELAY NUMBER ZONE 2)
N01 ID21 01(NEWORKER NUMBER)
then press the number 1 key followed by the on off button then, provided its all been installed correctly zones should appear and operate :-) good luck and i hope this helps.
Posted on May 16, 2010
Brivis zone
$900 seems like a lot for a new HSI and flame sensors :( 54 seems to be with the supply air thermistor. does the unit still operate with the error?
May 09, 2014 | Heating & Cooling
Hi installed brivis hx30 no common area x3 zone motors trying to install on net worker can only get zone a up any ideas
you will have to program all of the zones into the wall controller. to access the service parameters turn the controller to the off position then press clock. hold buttons 2 and 4 down for 5 sec then press the mode button it should display
1 01
or something like that u can scroll threw the parameters with buttons 1 and 2 and u adjust the values with the dial. for u it will need to be set to
1 15
1 17
1 18
1 20
2 21
1 23
3 24
this will then make it have all 3 zones so it will display zone A, B, C this is only for heating tho for cooling u will also need to program it in they are different numbers.
Hope this helped
-Chris
May 07, 2014 | Cell Phones
Brivis ducted Heater won't get above 19 degrees ,
could be broken ducting letting hot air escape or on the intake side drawing too much outside air in. could be the fan unit not pushing enough air
Jul 26, 2013 | Cars & Trucks
Why FC show on ademco 6148 keypad,
FC is for faliure to communicate. Need to check systems connection to monitoring station. Did anyone work on your phone line(s) or did you change your phone company or service? GL.
Dec 07, 2010 | Ademco 10) Ademco 6148 Keypad Fixed...
Hi i have a brivis eh 30 unit that comes up with error 65 and 30 the display inside the unit says fan limp, if i reset it from the unit it works for about 1 hr then the same thing can anyone help please
Hi. Here are the error codes for your Brivis Heater. Error Codes 30 - relating to speed sensor, 40 - overheating, 65 - motor lock-out. Usually resetting the unit will resolved the issue. In your case, you already reset the unit and problem came back. This will require immediate attention by Brivis technician.
Jul 12, 2010 | Heating & Cooling
Error message 35 Hi brivis ducted heating
I had the exact same problem and called 1300brivis. They told me that the error means the thermister needs to be replaced. My unit is also out of warranty but they are still going to come out and fix it.
Apr 12, 2010 | Heating & Cooling
No display on Robertshaw 9600; unit seems dead/furnace works
Hello
you have to have a thermostat! The thermostat tell the unite what to do. Get a new one.
Jul 25, 2009 | Honeywell Programmable Thermostat Heater
Brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
May 12, 2009 | Heating & Cooling
Carrier furnace
I'm not a fan of zoning but it sounds like they don't have the ducting done correctly. There has to be bleeder trunks installed in the unit because your are taking a unit that is designed to cool or heat a particular square footage and make it cool or heat a smaller area. This makes the unit way too big for the job you are asking it to do. If the ducting is improper, you are going to have issues like this. A lot of contractors will not admit that the ducting isn't correct due to the cost to correct it. I personally think (my opinion) that 4 zones are a little excessive. Sounds like you really need 2 units. It's hard to tell from my point of view since I'm not there to actually see what is going on. I would have a couple of different contractors come out and give you an estimate to fix the issue and then tell the installer to come and fix what they say is wrong.
Feb 16, 2009 | Carrier 38BRC060 Air Conditioner
House Brand Heating&Air Conditioning Booster Fan Logo
1,986 people viewed this question
Top House Brand Dryers Experts
Are you a House Brand Dryer Expert? Answer questions, earn points and help others
