Question about Frigidaire PLHS237ZD Stainless Steel Side by Side Refrigerator
Frigidaire PLHS267ZDB2--Not cold enough
Hi my 3yo fridge is not freezing the meat anymore and the fridge side is a little warm.I set the controls to colder side and could hear the motor or something in the back start and let run overnight but it just doesnt get cold enough to freeze the meat.I opened the back and cleaned/vacuumed the dirt from the coils but same thing.I also opened the inside of the fridge and noticed some ice or frost built up on the evaporator coils but not sure if its normal.Any otherpart I should check??Your suggestions would be much appreciated.Thanks.
  • Allan Gomez Oct 19, 2007
    I had a look at it again last night ,with the evap coils visible plugged it in and noticed that the evap coils went cold rightaway and frost started to build up  on it.I also noticed that the fan didnt move at all (not sure if normal).I took a voltmeter but measured 120v on the fan motor terminals.I will replace the motor and will post the result.Thanks..
  • Anonymous Mar 19, 2014
    I have a kelvinator cyclic 330 that doesnt get cold enough anymore. Can see ice forming on the back plate but the fridge as a whole not cold enough. Any ideas? Thermostat maybe?
Replaced the fan and the damn thing works like a charm....Thanks alot for all your suggestions.This is a cool site and you guys are doing a great great job! Keep up the good work!
Posted on Oct 22, 2007
  • 473 Answers
It has a defrost problem which will not let it cool properly.  On a frigidaire you can open the refrigerator side door and hit the light switch 4-5 times and that will put it into defrost.  Take the panel off on the bottom back inside the freezer to expose the evaporator.  Once you have put it into defrost see if the heater comes on.  If it does then you have a bad defrost timer.  If it doesn't start to defrost then the defrost thermostat is most likely the problem.  It just clips onto the evaporator.  May have to splice a new one in.  It's possible the defrost heater itself is bad but not as common.  Test it with and ohm meter for resistance.  Any resistance means it's ok.  If the heater is bad I would replace the defrost thermostat also.  Would appreciate a solved rating for expert advice unless you have more questions.  A step by step check out may require a live chat.
Posted on Oct 18, 2007
Fridge not freezing meats
I was writing a big note here before then hit the wrong button, it was just a bunch of jargon anyway. Yes it is the condenser fan motor causing your problems. Doesn't cool the refrigerant properly than nothing works. I would change the fan before it causes any damage to the compressor.
Sep 04, 2012 | Whirlpool Refrigerators
Hi, my Hotpoint ff200e fridge freezer is cooling but not freezing, compressor wires are warm and compressor itself is quite warm, top fridge is not cooling enough, then the lights on control panel start...
Hi.. feel the dividing rdge between fridge and freezer.. is it warm?.. chances are that the little fan at the back of the fridge freezer that helps cool the compressor, has snagged own it's own wire... it's a weak fan, like you get in a computer, but it does a lot of work.. without it, the coolent does not do it's job, which results in your device not cooling things properly
Apr 24, 2017 | Hotpoint HTM17BBSSA Top Freezer...
My Frigidaire refrigerator side by side is freezing drinks.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 22, 2009 | Frigidaire FRS26H5AS Side by Side...
GE Side by Side freezer cold but not freezing, fridge is warm
you might have a defrost problem, timer,heater or bimetal when the coils freez up they dont cool enough .
Jul 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
Apr 04, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Freezer cold refrig warm
4 yr old sears side by side...not cold in freeze or frig side
May 21, 2008 | Frigidaire FRS26ZSG
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire PLHS237ZD Stainless Steel Side by Side Refrigerator Logo
484 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
