Question about LG (CRD-8400CB) CD-ROM Drive
Philips cdr 760 cd recorder: OPC FAILED
Every cd I put in now seems to be no good or unrecordable. I get the message : OPC FAILED. I tried numerous brands and for a while the TDK brand was working, but that too has now been rejected. Does the machine need to be fixed, or is there a particular cd that I must buy now to record?
thanks
Eugene when i try to burn a blank cd-r it says OPC failed.what can I do?
3 Suggested Answers
  • 66 Answers
SOURCE: My cd-rom will play cds,
LG CRN 8245B can only read cds , it can not burn blank cd-rw discs. you need a cdrw to burn cds
Posted on Feb 23, 2011
bronk50
  • 27725 Answers
SOURCE: My LG DVD writer is
make sure that the cd rom is getting enough power test all leads that are attached to the cd drive including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if your computer came with a motherboard disc the sound drivers could be on it
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Apr 11, 2011
Why do I get OPC error when trying to record on aCDRW ON a philips cdr 785
Common issue. The lasers/transports in these are terribly unreliable.
More of these hit repair stores and skips than pints of beer down a football thugs throat.
cut your time and loses and invest in one from any brand other than Philips. pioneer and Yamaha make exceedingly good CD-R recorders for the home user. Hhb, marantz, fostex for the pro market
Feb 16, 2016 | Philips CDR785 3-Disc CD Recorder
I have a CDR 765 Philips recorder. It doesn't work on recording. The error message is "NO OPC". Thank you
hola
la cdr765 de philips es una grabadora de pc 3610 de philips o hp7200, el opc error es la lente esta mal, compra ina grabadora y cambia los 2 circuitos de la mecanica original de la cdr765 y desmonta la 3640/7200 y ponle los circuitos montas y a disfrutar.
Feb 27, 2011 | Philips CDR765 2-Disc CD Recorder
I have a philips audio recorder cdr 760 When i try to record cd rw a blank audio tdk cd the machine said OPC FAIL What I have to do to record the cd rw on my Philips cdr 760 Thanks for your...
There are a lot of forums which discuss OPC failure and it strikes every hardware maker and brand of media.
The bottom line is that certain media and certain writers just don't get along.
The manual:
http://www.p4c.philips.com/files/c/cdr760_17/cdr760_17_dfu_aen.pdf
Discussion online:
http://homerecording.com/bbs/general-discussions/recording-techniques/phillips-cdr870-187247/
http://answers.google.com/answers/threadview/id/318687.html
"I don't buy expensive blanks. I buy modest quality blanks and watch
for sales so that I can them for about a dime a piece after the rebate
check comes in. If I have an OPC Fail message, I try another blank. If
I find that they consistently fail (about half a buck wasted) I move
the stack over to the computer (which seems to work fine with these)
and buy another stack of blanks of a different brand next time I see a
good price..."
an interesting workaround:
http://www.sweetwater.com/forums/showthread.php?10128-Tascam-CD-RW5000
"CDRW 5000 work around for OPC FAIL
Here's a work around for OPC FAIL on cdrw 5000 -
method 1: turn unit on at least 30 minutes or more before use (this seems to work best for me)
method 2: run OPC on an old cd that always works - after OPC passes, remove old cd and insert new CD (you only get 99 OPC runs per disc)
-or use a combination of the two methods
I've always used TDK and I recently bought a new batch and they stopped working. The old ones still work everytime. I don't know enough about the system to guess what the difference is.
side note: CDRW 2000 will finalise discs from the cdrw 5000 but not the other way around.
Hope that helps "
Jan 30, 2011 | Philips CDR760 CD Player
I have a Philips CDR 778 audio cd recorder. I try
you prbly need to replace the burning laser which i would imagine is still avail however the cost of the laser may not b a prblm but fitting it could b
Apr 17, 2010 | Philips CDR778 2-Disc CD Recorder
PHILIPS CDR 870 FLASHING "OPCFAIL" AND WON'T RECORD
I HAVE A PHILIPS CDR 870 "OPC FAIL" PROBLEM. I HAVE RECORDED ONTO CD-RW, AND NOT YET FINALISED THE DISK AFTER RECORDING, IN ORDER THAT I CAN GO BACK LATER TO ADD FURTHER RECORDINGS. AFTER SWITCHING THE MACHINE BACK ON OPC THEN OPC FAIL FOLLOWS, EVEN WITH NEW DISKS CD-R AND CD-RW. MGHT THE MACHINE ITSELF REQUIE CLEANING OR IS THIS A FAULT? I AM USING MAXCELL DISKS, BOTH TYPES. THANKS. JEREMY. GATESHEAD.
Mar 19, 2010 | Philips CDR870 CD Recorder
Why do disks register an opc error on my philips cdr 770 cd recorder
depends on what discs you are trying do you use philips own brand audio if not try them best bet
Dec 14, 2009 | Philips Audio Players & Recorders
Disc won't initialize or record, keeps saying no disc or opc erro
I suggest you try cleaning the lens...
If the wrong disc was inserted, say a music disc, there would surely be a message to that effect. If no such message is displayed I would guess the unit is faulty.
Apr 13, 2017 | Philips CDR778 2-Disc CD Recorder
I have a Phillips 775 CD Recorder, and can only get it to record using Maxell CD-R Music Pro brand blank discs. They usually come in packs of 10 and are in full-size jewel cases. Haven't bought any in awhile and am not sure about availability.Hope this helps.
Jun 23, 2008 | Philips CDR760 CD Player
Won't record
I've just spoken to a friend who also has one of these older Philips recorders & he has the same problem.
As per my previous post, he fixed his problem by locating old stocks of blanks. New audio discs seem to have been manufactured & optimised for fast writing speeds (up to 32x speed) & this is causing the problem (you can't write at x1 or x2 speed to these new speedy discs).
Trying a few different brands of discs to try out is a whole lot cheaper than a repair. I suggest when you find a brand that works, you stock up on these discs as it seems they will become ever rarer.
Dec 11, 2007 | Philips CDR785 3-Disc CD Recorder
RECORD DROP OUT
Just bought this CDR 570 and not use yet.
Reading the instruction manual - yes, life experience has taught me some really useful stuff! -
Under 'Discs for recording' on page 7 it says at end of section
IMPORTANT:
To ensure proper working of the set we recommend the use of PHILIPS audio CDR and audio CDRW discs only'
Roughly translated I read this to me - 'don't blame us if the set don't work using other (non-compatible) discs' !!
Oct 02, 2007 | Philips CDR570 CD Recorder
LG (CRD-8400CB) CD-ROM Drive Logo
186 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
