Question about Asko Washing Machines
Asko 20605 replace motor
How to replace Asko 20605 washing machine motor
  • 1294 Answers
SOURCE: Asko washing machine door not closing
Changing the door lock is one of the easiest things to do in a washing machine. Just note which wires go where & get a new door switch.
Posted on Jun 11, 2007
  • 3 Answers
SOURCE: asko front loader washer w620
Check your motor brushes. They may need to be replaced.
Posted on Aug 05, 2008
  • 351 Answers
SOURCE: Asko W640 Front Loading Washing
may be carbons in motor and or board
Posted on Aug 27, 2008
SOURCE: asko 10625 will not spin
it is probably the belt, take off the back of the machine and look at the black rubber belt that spins the cleaning drum. The belts break after about 5 years, you can get a replacement belt at you local Asko dealer, I recall that is was pretty easy to change, like doing a bike chain, Talk to you Asko dealer about how to change it.
Posted on Jul 13, 2009
Macmarkus
  • 2605 Answers
SOURCE: F6 CODE
F6 on an asko washer means a fault was detected with the motor. What this means 99% of the time is the brushes in the motor are worn. As long as the armature isn't damaged, (visual inspection while turning motor shaft should identify damage) you'll be fine replacing the brushes.
part # 764414, 2 required, about $40US each (better than $400US plus for a motor).
hope that helps
good luck
Posted on Sep 29, 2009
Where are the brushes located on an asko washing machine ??? I'm fairly handy, can I replace myself ???
hi, I used to fix asko's when I was as work and found the motor brushes really easy to fix on the older machines. I found it best to drop the motor down and change the brushes at the back of the motor on the bench. hope this helps. remember to change both brushes though.
Mar 25, 2013 | Asko Washing Machines
Where can i buy a motor for the Asko w600 in Ballarat
Hi just read your posting.Now the place to buy all spare parts for ASKO washing machines is in MELBOURNE. Asko has their factory in Moorabbin.If you ring up directory assistance and ask for Asko"s phone number they will provide it.Then you can buy the motor over the phone and it will take a couple of days for delivery.Unfortunately I do not have the phone number off hand.By the way why are you replacing the motor,maybe I could help with the problem.Please reply to let me know how you got on.Looking forward to your reply.
Aug 28, 2010 | Asko W600
Asko 20605 washer stopped mid-cycle, now no power?!
The ECU should be tested. Look for the service manual inside the chassis for troubleshooting procedures.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 04, 2010 | Asko Washing Machines
I stopped my Asko 20605 washer midcycle and it went dead. Can't turn it back on. Power turns on in the drier, but not the washer. If it's a fuse problem, where is the fuse? How do I get to it and what do I...
Do you still have washer? Where are you located? Give me a call i also have washer and i am looking for parts or might be able to give you parts.
410.926.7006
Dec 03, 2009 | Asko Washing Machines
Model 20605; problem, F-3 fault in pumping out
Usually cleaning out the pump will correct the problem.
Oct 06, 2009 | Asko Washing Machines
F6 CODE
hope that helps
good luck
May 30, 2008 | Asko W6021 Front Load Washer
Motor Fault
check the carbon brushes on the motor or it can be a motor fault also change the belt at the same time
Apr 25, 2008 | Asko W6021 Front Load Washer
ASKO Washing Machine WM220(ASKO 20605)-Control Panel
IS 2 looks like a MOSFET on my machine
I'm not sure on the Manufacturer - Their logo appears to be a large streaked "I"
The numbers on my mosfet read:-
H542
TOP200YAI (this last digit could also be a 1)
PC0288
Cheers from a fellow busted ASKO consumer.. :(
Mine appears to be motor or motor controller related, so if you don't fix yours, I'd be happy to take a few parts off your hands. ;)
Nov 06, 2007 | Televison & Video
Washing Machines Logo
19 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
marley mcelhinney
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
